Is there any tricks to getting zwave2mqtt setup? I followed the github instructions, but the docker container is just hanging with the following message:
ozwd | [ozwdaemon]: Waiting until the MQTT broker at 192.168.86.28:1883 is available…
ozwd | [ozwdaemon]: Starting…
ozwd | [ozwdaemon]: Executing: /usr/local/bin/ozwdaemon
Nothing ever occurs after that, no GUI, no other errors. nothing. My MQTT is properly setup (I have many other mqtt devices, etc.). It doesn’t have a UN or PW, so not sure if that is messing it up. Is there a guide out there, or can anyone help with this issue?
The message means it has connected to the broker. You won’t see anything else. There is a logs directory in the config directory that you should have mapped.
You should follow the documentation to get the HA part configured.
Yeah, both containers were running. I think I realized the problem. I had both z-wave integrations running in parallel, I didn’t realize it was one or the other. So at this point, until there is an easier migration path, I’ll stick with the main z-wave integration.
You could try overriding the usb path in configuration.yaml to a bogus one, which should keep the z-wave integration intact but no usable, then use the OZW Beta container. I’ve never tried it w/o deleting it entirely.
Does the Beta only work with powered devices at this point? I tested the OpenZwave integration and it’s only reporting my powered devices, none of my sensors
