Same here! Exactly the same setup as OP.
· StopWatchdog (0xd3)
· SetMaximumRoutingAttempts (0xd4)
· undefined (0xee)
· undefined (0xef)
2024-09-12T15:20:28.400Z CNTRLR querying additional controller information...
2024-09-12T15:20:28.514Z CNTRLR received additional controller information:
Z-Wave API version: 8 (legacy)
Z-Wave chip type: ZW050x
node type Controller
controller role: primary
controller is the SIS: true
controller supports timers: false
Z-Wave Classic nodes: 1, 2, 3, 4, 5, 7, 8, 9, 10, 11, 12, 15, 16, 17,
18, 19, 20, 21, 22, 24, 26, 28, 35, 39, 45, 47, 48, 49, 51, 53, 54, 55, 59, 60
, 61, 62, 63, 64, 65, 66, 67, 70, 71, 73, 74, 75, 76, 78, 82, 83, 84, 89, 91,
94, 95, 99, 100, 101, 104, 105, 114, 115, 116, 120, 122, 123, 129, 130, 133, 1
35, 136
2024-09-12T15:20:28.514Z CNTRLR querying version info...
2024-09-12T15:20:28.524Z CNTRLR received version info:
controller type: Static Controller
library version: Z-Wave 6.07
2024-09-12T15:20:28.524Z CNTRLR querying protocol version info...
2024-09-12T15:20:28.531Z CNTRLR received protocol version info:
protocol type: Z-Wave
protocol version: 6.7.0
appl. framework build no.: 97
2024-09-12T15:20:28.531Z CNTRLR querying controller capabilities...
2024-09-12T15:20:28.541Z CNTRLR received controller capabilities:
controller role: Primary
is the SUC: true
started this network: true
SIS is present: true
was real primary: true
2024-09-12T15:20:28.541Z CNTRLR querying serial API setup capabilities...
2024-09-12T15:20:28.547Z CNTRLR supported serial API setup commands:
· GetSupportedCommands
· SetTxStatusReport
· SetPowerlevel
· GetPowerlevel
· GetMaximumPayloadSize
2024-09-12T15:20:28.547Z CNTRLR querying max. payload size...
2024-09-12T15:20:28.554Z CNTRLR maximum payload size: 46 bytes
2024-09-12T15:20:28.554Z CNTRLR supported Z-Wave features:
· SmartStart
2024-09-12T15:20:28.555Z CNTRLR Performing soft reset...
2024-09-12T15:20:28.558Z CNTRLR Waiting for the controller to reconnect...
2024-09-12T15:20:30.060Z CNTRLR Waiting for the Serial API to start...
2024-09-12T15:20:35.064Z CNTRLR Did not receive notification that Serial API has started, checking if it respo
nds...
2024-09-12T15:20:35.066Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2024-09-12T15:20:35.168Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2024-09-12T15:20:36.271Z CNTRLR Serial API did not respond, trying again in 2 seconds...
2024-09-12T15:20:38.274Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2024-09-12T15:20:38.375Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2024-09-12T15:20:39.477Z CNTRLR Serial API did not respond, trying again in 5 seconds...
2024-09-12T15:20:44.482Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2024-09-12T15:20:44.583Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2024-09-12T15:20:45.685Z CNTRLR Serial API did not respond, trying again in 10 seconds...
2024-09-12T15:20:55.690Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2024-09-12T15:20:55.791Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2024-09-12T15:20:56.894Z CNTRLR Serial API did not respond, trying again in 15 seconds...
2024-09-12T15:21:11.910Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2024-09-12T15:21:12.010Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2024-09-12T15:21:13.112Z CNTRLR Serial API did not respond, giving up
2024-09-12T15:21:13.113Z DRIVER Failed to initialize the driver: ZWaveError: The Serial API did not respond af
ter soft-reset (ZW0100)
at Driver.softResetInternal (/usr/src/node_modules/zwave-js/src/lib/driver
/Driver.ts:2900:11)
at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src
/lib/driver/Driver.ts:1539:5)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Dr
iver.ts:1322:5)
Error in driver ZWaveError: Failed to initialize the driver: ZWaveError: The Serial API did not respond after soft-reset (ZW0100)
at Driver.softResetInternal (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:2900:11)
at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1539:5)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1322:5) (ZW0100)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1342:6) {
code: 100,
context: undefined,
transactionSource: undefined
Shutting down
[15:21:13] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Restore backup and reload integration solves it.
