I’ve tried to search, but everyone seems to complain about not having a color wheel (which I had earlier). But today I rebuilt the whole Z-wave network, and now I’m not able to get adjust the light in any way.
All the switches and levels are gone.
I’m using zwavejs2mqtt with MQTT disabled and exposing everything over the zwave-js-server. This is the same setup as I had before.
I’m able to adjust the light from the control panel of zwavejs2mqtt, but all the toggles are gone from the HA implementation.
I’m running latest version of HA, zwavejs2mqtt and zwave-js-server.
Latest zwavejs2mqtt (node-zwave-js actually) is not compatible with the current HA release, with respect to some RGB and thermostat devices. You’ll have to wait for the next HA release or downgrade zwavejs2mqtt.
It’s not a battery device. And everything is available from the control panel of Zwavejs2mqtt, but not from HA. I guess @freshcoast is right about incompatible-issues with node-zwave-js and HA.
