I installed ZwaveJS2MQTT and when all nodes are loaded i add the ZwaveJS integration.
After that i reboot and after that i removed ZwaveJS Add-on. When i reboot this add-on isn’t coming back.
The role of ZwaveJS2MQTT add-on is to replace the ZwaveJS add-on, if you decide to install it and not go the official way. This is what I mean. I was not proposing that my way is the official way.
Thank you for confirming that I am supposed to remove the ZwaveJS add-on, that makes sense.
Now if someone can help me finding why the add-on « magically » reappear when I explicitly delete it, I would appreciate!
I’m going to assume that when you installed the zwave-js integration that you selected the checkbox to use the supervisor add-on?
If so that’s why it is coming back automatically.
you need to re-add the zwave-js intagration (but don’t remove your existing integration first).
When you configure the new integration DO NOT select the checkbox.
And then make sure that you select the same hardware (zwave controller) that the existing integration used. then you need to ensure it uses the zwavejs2mqtt add-on as the host instead of the zwavejs add-on.
Then when you submit it the old integration should be replaced by the new integration and using the zwvejs2mqtt add-on and it should stop the zwavejs add-on from reinstalling itself.
I’ve never done it (I don’t use add-ons) but I have it on good authority that should be the way it should work.
This is the error I made. Since it’s not possible to remove it after the integration is installed, I did not see it. My friend did the same error also!
