Hi, what is this error and how to get rid? It is in the core-log:
Logger: homeassistant.components.zwave_js
Source: components/zwave_js/discovery.py:1140
Integration: Z-Wave (documentation, issues)
First occurred: 19:28:41 (2 occurrences)
Last logged: 19:28:41
Discovery for value Value(value_id='21-49-0-UNKNOWN (0x83)') on device 'Motion Sensor - Hal Zijkant' (Node(node_id=21)) will be skipped: Value Value(value_id='21-49-0-UNKNOWN (0x83)') has unknown data in the following location: metadata.cc_specific.sensorType. A reinterview of node Node(node_id=21) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
Discovery for value Value(value_id='21-49-0-Water acidity') on device 'Motion Sensor - Hal Zijkant' (Node(node_id=21)) will be skipped: Value Value(value_id='21-49-0-Water acidity') has unknown data in the following location: metadata.cc_specific.scale. A reinterview of node Node(node_id=21) may correct this issue, but if it doesn't, please report this issue as it may be caused by either an upstream issue with the driver or missing support for this data in the library
(I have re-interviewd)
