Yesterday I did the upgrade to :
Home Assistant 2022.9.1
Supervisor 2022.08.6
Operating System 8.5
Frontend 20220907.0 - latest
… and suddenly my ZwaveJS integration stopped working :
“Retrying setup: Invalid server version: Z-Wave JS Server version is incompatible: 1.21.0 a version is required that supports at least api schema 22”
I run a ZwaveJS2MQTT server on a separate RasPi on the network (snap installed).
I can perfectly log in to it’s control panel and see all Zwave activity just fine, so it seems to be a problem in HA not connecting to the remote “Zwave server” anymore …
any solution ?
Do I need to upgrade the ZwaveJS2MQTT snap package on the remote RasPi to 7.00 or higher ?
HA Release notes say : “* If you use the zwavejs2mqtt Docker container, you need to have at least version 7.0.0
(I see on the ZwaveJS2MQTT Github page that 7.1.0 is the latest version)
(Releases · zwave-js/zwavejs2mqtt · GitHub)
Release 7.1.0Latest
3 days ago
When I click on the update button in the ZwaveJS2MQTT control panel it says :
"Config updates
No updates available yet. Press on CHECK to trigger a new check.
By default checks are automatically done daily at midnight"
… huh ?
why doesn’t ZwaveJS2MQTT (auto-) upgrade itself to the latest version ?
is this why my HA isn’t able to read my Zwave devices anymore ?
