After starting to migrate from ST to the new ZwaveJS integration I am having an issue where an Inovelli LZW36 is randomly turning the light off. I did not have the same problem when the light was used ST. I am using the direct integration(not mqtt). Not sure what additional logging I can enable to figure out where this is coming from except what I have indicated below. Any help is appreciated.
Couple of things I noticed:
- HA simply logs “turned off” in the history as opposed to it being turned off by a service or user
- In the zwavejs logs I can see the following log showing the value change but nothing else useful as to where the change came from
2021-03-02 23:46:54.502 INFO ZWAVE: Node 7: value updated: 38-1-currentValue 55 => 0
