I’m tying to add a Fibaro Smoke Sensor FGSD-002 Firmware: 3.3.
The node appears to have been added correctly and if I requery it I get “node is ready to use”. However, no configuration parameters are visible. There is an entry in the device database for firmware 3.2 and above.
log:
2021-10-09T16:39:34.756Z CNTRLR « [Node 011] Received updated node info
2021-10-09T16:39:34.761Z CNTRLR [Node 011] The node is now awake.
2021-10-09T16:40:03.289Z CNTRLR [Node 011] Beginning interview - last completed stage: None
2021-10-09T16:40:03.291Z CNTRLR [Node 011] new node, doing a full interview...
2021-10-09T16:40:03.294Z CNTRLR » [Node 011] querying protocol info...
2021-10-09T16:40:03.333Z CNTRLR « [Node 011] received response for protocol info:
basic device class: Routing Slave
generic device class: Notification Sensor
specific device class: Notification Sensor
node type: Routing End Node
is always listening: false
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2021-10-09T16:40:03.339Z CNTRLR [Node 011] The node is now asleep.
2021-10-09T16:40:03.346Z CNTRLR [Node 011] Interview stage completed: ProtocolInfo
2021-10-09T16:40:03.348Z CNTRLR » [Node 011] querying node info...
2021-10-09T16:40:18.043Z CNTRLR « [Node 011] Received updated node info
2021-10-09T16:40:18.046Z CNTRLR [Node 011] The node is now awake.
2021-10-09T16:40:18.115Z CNTRLR « [Node 011] node info received
supported CCs:
· Z-Wave Plus Info
· Version
· Manufacturer Specific
· Association Group Information
· Powerlevel
· Battery
· Application Status
· Multilevel Sensor
· CRC-16 Encapsulation
· Security
· Firmware Update Meta Data
controlled CCs:
2021-10-09T16:40:18.138Z CNTRLR [Node 011] Interview stage completed: NodeInfo
2021-10-09T16:40:18.146Z CNTRLR [Node 011] Interviewing Manufacturer Specific...
2021-10-09T16:40:18.147Z CNTRLR » [Node 011] querying manufacturer information...
2021-10-09T16:40:18.245Z CNTRLR « [Node 011] received response for manufacturer information:
manufacturer: Fibargroup (0x010f)
product type: 0x0c02
product id: 0x1003
2021-10-09T16:40:18.250Z CNTRLR [Node 011] Interviewing Version...
2021-10-09T16:40:18.253Z CNTRLR » [Node 011] querying the CC version for Version...
2021-10-09T16:40:18.366Z CNTRLR [Node 011] supports CC Version (0x86) in version 2
2021-10-09T16:40:18.367Z CNTRLR » [Node 011] querying node versions...
2021-10-09T16:40:18.444Z CNTRLR « [Node 011] received response for node versions:
library type: Enhanced Slave (0x03)
protocol version: 4.24
firmware versions: 3.3, 3.3
hardware version: 2
2021-10-09T16:40:18.445Z CNTRLR » [Node 011] querying CC versions...
2021-10-09T16:40:18.447Z CNTRLR » [Node 011] querying the CC version for Z-Wave Plus Info...
2021-10-09T16:40:18.499Z CNTRLR [Node 011] supports CC Z-Wave Plus Info (0x5e) in version 2
2021-10-09T16:40:18.501Z CNTRLR » [Node 011] querying the CC version for Manufacturer Specific...
2021-10-09T16:40:18.559Z CNTRLR [Node 011] supports CC Manufacturer Specific (0x72) in version 2
2021-10-09T16:40:18.562Z CNTRLR » [Node 011] querying the CC version for Association Group Information...
2021-10-09T16:40:18.632Z CNTRLR [Node 011] supports CC Association Group Information (0x59) in version 1
2021-10-09T16:40:18.634Z CNTRLR [Node 011] skipping query for Powerlevel (0x73) because max implemented vers
ion is 0
2021-10-09T16:40:18.638Z CNTRLR » [Node 011] querying the CC version for Battery...
2021-10-09T16:40:18.698Z CNTRLR [Node 011] supports CC Battery (0x80) in version 1
2021-10-09T16:40:18.700Z CNTRLR [Node 011] skipping query for Application Status (0x22) because max implemen
ted version is 0
2021-10-09T16:40:18.702Z CNTRLR » [Node 011] querying the CC version for Multilevel Sensor...
2021-10-09T16:40:18.758Z CNTRLR [Node 011] supports CC Multilevel Sensor (0x31) in version 8
2021-10-09T16:40:18.759Z CNTRLR [Node 011] skipping query for CRC-16 Encapsulation (0x56) because max implem
ented version is 1
2021-10-09T16:40:18.762Z CNTRLR [Node 011] skipping query for Security (0x98) because max implemented versio
n is 1
2021-10-09T16:40:18.764Z CNTRLR » [Node 011] querying the CC version for Firmware Update Meta Data...
2021-10-09T16:40:18.825Z CNTRLR [Node 011] supports CC Firmware Update Meta Data (0x7a) in version 3
2021-10-09T16:40:18.876Z CNTRLR [Node 011] Embedded device config loaded
2021-10-09T16:40:18.883Z CNTRLR [Node 011] Interviewing Z-Wave Plus Info...
2021-10-09T16:40:18.884Z CNTRLR » [Node 011] querying Z-Wave+ information...
2021-10-09T16:40:18.997Z CNTRLR « [Node 011] received response for Z-Wave+ information:
Z-Wave+ version: 1
role type: SleepingReportingSlave
node type: Node
installer icon: 0x0c01
user icon: 0x0c01
2021-10-09T16:40:19.027Z CNTRLR [Node 011] Interviewing Association Group Information...
2021-10-09T16:40:19.032Z CNTRLR [Node 011] Interviewing Battery...
2021-10-09T16:40:19.036Z CNTRLR » [Node 011] querying battery status...
2021-10-09T16:40:19.146Z CNTRLR « [Node 011] received response for battery information:
level: 100
2021-10-09T16:40:19.151Z CNTRLR [Node 011] Interviewing Multilevel Sensor...
2021-10-09T16:40:19.153Z CNTRLR » [Node 011] retrieving supported sensor types...
2021-10-09T16:40:19.224Z CNTRLR « [Node 011] received supported sensor types:
· Air temperature
2021-10-09T16:40:19.225Z CNTRLR » [Node 011] querying supported scales for Air temperature sensor
2021-10-09T16:40:19.285Z CNTRLR « [Node 011] received supported scales:
· Celsius
2021-10-09T16:40:19.288Z CNTRLR » [Node 011] querying Air temperature sensor reading...
2021-10-09T16:40:19.349Z CNTRLR « [Node 011] received current Air temperature sensor reading: 26.3 °C
2021-10-09T16:40:19.351Z CNTRLR [Node 011] Interview stage completed: CommandClasses
2021-10-09T16:40:19.354Z CNTRLR [Node 011] Interview stage completed: OverwriteConfig
2021-10-09T16:40:19.390Z CNTRLR [Node 011] Interview completed
2021-10-09T16:40:19.392Z CNTRLR [Node 011] The node is ready to be used
Any suggestions?
Adam
