ZWaveJS UI with Keymaster-Basic
I am using a ZWaveJS UI combination with Yale Zwave locks using the steps defined in the Keymaster Basic (GitHub - desertblade/Keymaster-Basic: Simple Home Assistant Lock Manager) design.
When i set a PIN/Username, the PIN codes are not sent and i don’t see any traffic in the Zwave debug monitor.
My setup is the following:
I setup a dashboard with the https://github.com/desertblade/Keymaster-Basic/blob/c666200c0e2883da52562fca020b624769b5563d/lovelace-keymaster-basic.yaml design in it. No changes ot the code.
in /config/configuration.yaml
# Keymaster
homeassistant:
  packages: !include_dir_named packages
/config/packages/keymaster_basic.yaml
# Add your locks here
lock:
  - platform: group
    entities:
      - lock.FrontDoor
      - lock.GarageDoor
      - lock.OfficeDoor
# Add notification services
notify:
  - name: "Lock Notify Group"
    platform: group
    services:
      - service: mobile_app_DEVICE
Update Oct 15
the problem was the home_locks group entity IDs. I assumed (novice!) that i could use the entity names as the entity IDs. Oops
lock:
  - platform: group
    entities:
      - lock.node_12 #FrontDoor
      - lock.assure_lever_keypad_with_z_wave_plus #GarageDoor
      - lock.assure_touchscreen_deadbolt #OfficeDoor
Was that the only change you made? I’m also struggling to get the pin codes updated onto the lock from the dashboard.
