This is attempting to exclude that same device:
Subscribed to Z-Wave JS Log Messages…
2022-02-20T17:16:25.828Z CNTRLR « [Node 056] Association group #1 has name "Lifeline"
2022-02-20T17:16:25.828Z CNTRLR » [Node 056] Association group #1: Querying command list...
2022-02-20T17:16:26.351Z CNTRLR « [Node 078] parameter #6 has value: 0
2022-02-20T17:16:26.352Z CNTRLR » [Node 078] querying parameter #8 value...
2022-02-20T17:16:26.959Z CNTRLR « [Node 056] received response for node versions:
library type: Enhanced Slave (0x03)
protocol version: 5.3
firmware versions: 4.0
hardware version: 2
2022-02-20T17:16:26.959Z CNTRLR » [Node 056] querying CC versions...
2022-02-20T17:16:26.960Z CNTRLR » [Node 056] querying the CC version for Binary Switch...
2022-02-20T17:16:31.428Z CNTRLR starting exclusion process...
2022-02-20T17:16:33.216Z CNTRLR » [Node 056] Association group #2: Querying name...
2022-02-20T17:16:33.227Z CNTRLR The controller is now ready to remove nodes
2022-02-20T17:16:33.237Z CNTRLR The controller response indicated failure after 1/3 attempts. Scheduling next
try in 100 ms.
2022-02-20T17:16:33.348Z CNTRLR The controller response indicated failure after 2/3 attempts. Scheduling next
try in 1100 ms.
2022-02-20T17:16:45.533Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:16:45.650Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:16:45.907Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:16:45.971Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:16:45.977Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:16:46.082Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:16:46.422Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:16:48.435Z CNTRLR [Node 078] Timed out while waiting for a response from the node (ZW0201)
2022-02-20T17:16:48.436Z CNTRLR « [Node 078] received no value for parameter #8
2022-02-20T17:16:48.436Z CNTRLR » [Node 078] querying parameter #9 value...
2022-02-20T17:16:51.987Z CNTRLR [Node 056] supports CC Binary Switch (0x25) in version 1
2022-02-20T17:16:51.988Z CNTRLR [Node 056] skipping query for All Switch (0x27) because max implemented vers
ion is 0
2022-02-20T17:16:51.991Z CNTRLR » [Node 056] querying the CC version for Z-Wave Plus Info...
2022-02-20T17:16:55.628Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:16:56.208Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:16:56.532Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:16:56.613Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:16:56.669Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:16:56.752Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:16:56.930Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:01.050Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:01.150Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:01.159Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:01.918Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:02.117Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:03.153Z CNTRLR [Node 056] Timed out while waiting for a response from the node (ZW0201)
2022-02-20T17:17:03.153Z CNTRLR » [Node 056] Association group #2: Querying command list...
2022-02-20T17:17:05.540Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:06.661Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:07.351Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:07.381Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:07.403Z CNTRLR « [Node 078] parameter #9 has value: 0
2022-02-20T17:17:07.404Z CNTRLR » [Node 078] querying parameter #10 value...
2022-02-20T17:17:07.413Z CNTRLR The controller response indicated failure after 1/3 attempts. Scheduling next
try in 100 ms.
2022-02-20T17:17:08.395Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:08.554Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:08.793Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:09.109Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:10.569Z CNTRLR [Node 056] supports CC Z-Wave Plus Info (0x5e) in version 2
2022-02-20T17:17:10.570Z CNTRLR » [Node 056] querying the CC version for Association...
2022-02-20T17:17:17.243Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:17.280Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:17.438Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:17.886Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:18.150Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:18.715Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:19.619Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:20.715Z CNTRLR [Node 056] Timed out while waiting for a response from the node (ZW0201)
2022-02-20T17:17:20.715Z CNTRLR » [Node 056] Association group #3: Querying name...
2022-02-20T17:17:20.733Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-02-20T17:17:20.857Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-02-20T17:17:24.821Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:25.152Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:25.216Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:25.395Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:25.477Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:29.692Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:29.911Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:29.993Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:31.732Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:31.951Z CNTRLR [Node 073] treating BasicCC::Set as a report
2022-02-20T17:17:32.134Z CNTRLR [Node 078] Timed out while waiting for a response from the node (ZW0201)
2022-02-20T17:17:32.135Z CNTRLR « [Node 078] received no value for parameter #10
2022-02-20T17:17:32.135Z CNTRLR » [Node 078] querying parameter #11 value...
2022-02-20T17:17:32.152Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-02-20T17:17:33.169Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:33.233Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:33.299Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:33.330Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:33.549Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:33.684Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:33.725Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:33.772Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:34.114Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:35.552Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:36.969Z CNTRLR « [Node 062] TODO: no handler for application command
2022-02-20T17:17:37.647Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:38.003Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:38.041Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:38.281Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:38.398Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:38.623Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:39.104Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:39.487Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:39.645Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:39.909Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:40.114Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:17:42.460Z CNTRLR [Node 056] Timed out while waiting for a response from the node (ZW0201)
2022-02-20T17:17:42.461Z CNTRLR [Node 056] CC version query for Association timed out - assuming the node supp
orts version 1...
2022-02-20T17:17:42.461Z CNTRLR » [Node 056] querying the CC version for Multi Channel Association...
2022-02-20T17:17:56.950Z CNTRLR [Node 056] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2022-02-20T17:17:57.128Z DRIVER the node is unknown or not initialized yet, discarding...
2022-02-20T17:18:10.009Z CNTRLR stopping exclusion process...
2022-02-20T17:18:10.418Z CNTRLR [Node 056] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2022-02-20T17:18:10.820Z CNTRLR [Node 073] treating BasicCC::Set as a report
