ZwaveJS2MQTT / Debug message
can’t find any posts about this, but is this normal when I turn on debug in the Control Panel of ZwaveJS2MQTT
2021-11-05 12:02:28.069 INFO ZWAVE: Connecting to /dev/ttyACM0
2021-11-05 12:02:28.073 WARN ZWAVE: Retry connection in 3 seconds…
2021-11-05 12:02:31.074 INFO ZWAVE: Connecting to /dev/ttyACM0
2021-11-05 12:02:31.079 WARN ZWAVE: Retry connection in 3 seconds…
2021-11-05 12:02:34.081 INFO ZWAVE: Connecting to /dev/ttyACM0
2021-11-05 12:02:34.085 WARN ZWAVE: Retry connection in 3 seconds…
2021-11-05 12:02:37.086 INFO ZWAVE: Connecting to /dev/ttyACM0
2021-11-05 12:02:37.090 WARN ZWAVE: Retry connection in 3 seconds…
2021-11-05 12:02:40.092 INFO ZWAVE: Connecting to /dev/ttyACM0
2021-11-05 12:02:40.096 WARN ZWAVE: Retry connection in 3 seconds…
2021-11-05 12:02:43.098 INFO ZWAVE: Connecting to /dev/ttyACM0
2021-11-05 12:02:43.102 WARN ZWAVE: Retry connection in 3 seconds…
2021-11-05 12:02:46.103 INFO ZWAVE: Connecting to /dev/ttyACM0
2021-11-05 12:02:46.108 WARN ZWAVE: Retry connection in 3 seconds…
2021-11-05 12:02:49.109 INFO ZWAVE: Connecting to /dev/ttyACM0
2021-11-05 12:02:49.114 WARN ZWAVE: Retry connection in 3 seconds…
2021-11-05 12:02:52.115 INFO ZWAVE: Connecting to /dev/ttyACM0
things work… but I’ve only migrated around 10 devices to the new Aeotec Stick Gen5+
Thanks,
mike
No, this is not normal. Zwavejs2mqtt is losing connection to the zstick. It is likely momentary and re-establishes it, which would explain why things are working for you.
However, it will likely cause issues if you don’t get to the route of the problem and fix it. If you post your install type - including how you installed Home Assistant, and what system/hardware it is running on, that could help with diagnosing where the connection could be failing.
Also are you using the community addon of zwavejs2mqtt or running it some other way (ie docker)?
using zwavejs2mqtt. Running The HA-OS install in a VM. Was presenting the USB stick… now after I rebooted everything the HA-OS is not even seeing the Aeotec stick.
I’ve read and searched for so many answers. Can’t seem to get the HA-OS to detect it or set it up properly.
DMESG shows this which is the proper stick, but it never creates /dev/ttyACM0 like it used to:
[ 1.786752] cdc_acm 2-2:1.0: ttyACM0: USB ACM device
[ 1.832119] usbcore: registered new interface driver cdc_acm
[ 1.871249] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
What’s the host OS the VM is running on and what VM are you using?
This is likely an issue with passing the USB through from the Host machine to the VM.
Running the linux VM, Host is Unraid KVM Platform. This has been running fine for a few weeks, but after rebooting can’t seem to get the USB stick to appear in /dev
This is what I get when I plug the device in:
[ 153.984033] usb 1-2: new full-speed USB device number 3 using xhci_hcd
[ 154.111923] usb 1-2: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
[ 154.111926] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 154.115962] cdc_acm 1-2:1.0: ttyACM0: USB ACM device
[ 154.116317] usbcore: registered new interface driver cdc_acm
[ 154.116318] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 156.653965] usb 1-2: USB disconnect, device number 3
It connects and then immediately disconnects. I can get the device to work in a win10 VM on the same Unraid, and can get it running in a docker, so I know it’s not the USB ports or the device. Something in the HA-OS causing it to immediately disconnect.
interesting… I have rebuilt an entirely new HA-OS and the USB device stays mapped and is accessible until I install the zwavejs2mqtt, once I enable this and point it to the /dev/TTYACM0 it crashes the /dev/TTYACM0.
If I configure zwave2JS, it has no issue. So it seems maybe a the updated version is broken? How do I revert to a prior version?
Yes, appears the new release may have created this issue
Documentation recomends using /dev/serial/by-id/xxx instead of paths like /dev/ttyACM0
The only way to downgrade an addon is to restore a snapshot/backup made prior to updating the addon.
The newer versions of ZWaveJS2MQTT (and indeed ZWaveJS) do have a note on the releases page that they now “soft reset” the stick before starting, and this may not be compatible with all sticks.
Release Release 5.10.1 · zwave-js/zwavejs2mqtt · GitHub Please read the notes.
If you feel that this is definitely the cause of the crashes, then go in to settings in the ZWaveJS2MQTT web interface, and turn off soft reset.
Appears you can disable the soft reset in the settings, that might fix this instead of downgradeing
confirmed that unchecking soft reset fixes the disappearing stick. (Aeotec zStick Gen5+)
What a darn day it has been tracking this bug down. I can also confirm now that by converting to /dev/serial/by-id/xxxxxx solves the original post of retry connection.
Thanks all… Hope this helps others.
mike
