Hi folks,
I am installing Zwavejs2mqtt on a separate RPI3+ to use as a controller in a separate house.
Installed in a container using this guide:
But - I have issues with Fibaro devices, for example, a Smoke Detector.
I can include it without problems, but only two entities on the sensor are discovered: ID: sensor_battery_level and binary_sensor_battery_islow. BTW, it seems to always show battery 100%, no matter the actual level.
No other entities, such as temperature and alarms are found. The controller and the Home Assistant integration Mosquitto broker MQTT show the same info.
A push on the sensor’s B button is immediately picked up as a TX command in the Zwavejs2mqtt GUI so there is connection. I have tried this in Zwavejs2mqtt control panel:
- Rediscover Entities - No more entities found
- Re-interview Node - Nothing
- Heal Node - took a while but no change
When connecting the same Smoke Detector (and the same Z-wave usb stick) directly to HS using ZWaveJS all entities are found.
Any ideas?
