This forum has been a great resource with many people helping me out over the years, so I thought I would try to contribute back on something that took many hours of research. If you’re using Podman for your container management (I’m running Fedora 36), and need Z-wave support, you’ll likely end up putting together a command like this:
mkdir ~/store
podman run --rm -it -p 8091:8091 -p 3000:3000 -v ~/store:/usr/src/app/store:Z --device=/dev/serial/by-id/usb-XXXX:/dev/serial/by-id/usb-XXXX zwavejs/zwavejs2mqtt:latest
The container will launch, but upon connecting to the web and going into Settings > Zwave and setting serial port to the appropriate path (/dev/serial/by-id/usb-XXXX if you did the same as above) and hitting Save, you’ll soon notice Permission Denied errors near the top as the container doesn’t have access to the device.
/dev/serial/by-id/usb-XXXX is just a link to /dev/ttyACM0, which on my system was owned by root:root. So I changed that to root:dialout, then added my user to the dialout group.
Note: Logging out was for some reason insufficient to get the group privileges to show up, I had to completely reboot the system. You can check your current groups by just typing ‘groups’.
Then you need to add two parameters to the Podman command: --security-opt label=disable --group-add keep-groups
Final command:
podman run --rm -it -p 8091:8091 -p 3000:3000 -v ~/store:/usr/src/app/store:Z --security-opt label=disable --group-add keep-groups --device=/dev/serial/by-id/usb-XXXX:/dev/serial/by-id/usb-XXXX zwavejs/zwavejs2mqtt:latest
Hope this helps.
