I cannot set zwave parameters on zwavejsmqtt in most recent version using the “zwave_js.set_config_parameter” service. Also cannot set it using the “Custom Configuration” dialog in zwavejsmqtt settings.
Using the Configuration menu for the device (screen shot above), I can get the value using the green “GET” box, which then creates a setting with the little “Arrow” for that parameter. Using that “Arrow” dialog, I can then set the device. Here is the log output when that works:
2022-09-06 08:41:12.539 INFO ZWAVE: Calling api writeValue with args: [
{ nodeId: 19, commandClass: 112, property: 32 },
1345,
[length]: 3
2022-09-06 08:41:12.545 INFO ZWAVE: Writing 1345 to 19-112-0-32
However, using the “Custom Configuration” dialog with the blue “SET” dialog, I get an error:
50-0-value-66049 13.415 => 13.568
2022-09-06 08:21:39.262 INFO ZWAVE: Calling api sendCommand with args: [
{ nodeId: 19, commandClass: 112 },
'set',
[ 32, 1345, 1, [length]: 3 ],
[length]: 3
2022-09-06 08:21:39.269 INFO ZWAVE: options is not a ConfigurationCCAPISetOptions (ZW0322) sendCommand undefined
I get a similar error when I try to use the “zwave_js.set_config_parameter” service.
Did you figure this out? I am having the same issue, sorta. I am going through Node red and using mosquitto to set parameters, but I get same error now
Even with the image being clipped, I can see that you are setting the args incorrectly. The set function takes a single object, not a list of parameters. That was a change to the driver, sometime over a month ago. When using the CC API sometimes you have to look at the source code (and understand TypeScript) to figure out what the parameters are.
