ZWaveToMQTT help
I’m trying to setup ZWaveToMQTT and seem to be having an issue with Mosquito(I think). I can see my devices in ZWaveToMQTT. I have the MQTT integration setup under Configuration --> Integrations.
If I go into the MQTT integration, click “configure”, enter “#” into “Listening to” and click “Start Listening” I see a bunch of JSON fly by when I move the motion sensor, so messages appear to be flowing from ZWaveToMQTT to Mosquito, however I am not seeing any new devices or entities listed under Configuration in Home Assistant. What do i need to do to get the zwave devices to register there? As far as I can tell I have my MQTT broker and gateway configured correctly, and the devices are showing up in ZWaveToMQTT, what am I missing to get the sensors to show up in Home Assistant?
nevermind, restarted the services a few times and now I’m seeing it under devices and entities. Apparently I just need to be patient and reboot. Anyone know what I can do to force the devices/entities to show up quicker in the future?
I believe Home Assistant starts processing stuff when the Z-Wave status is “driverAllNodesQueried” or “driverAllNodeQueriedSomeDead”
You can check this by for example using MQTT-Explorer to read topic OpenZWave/1/status
I’m not sure how the ZWave2MQTT addon handles this specifically, but I guess it’s worth a try :slight_smile:
My Z-Wave network takes about 25 minutes to start (30 nodes approx), so give it time :slight_smile:
Actually think I found my issue in the docs
There have been reports of the Aeotec stick not working on the Raspberry Pi 4.
The devices will show up, report into HA a couple times and then go dead. I’m running a pi4 so I’m assuming this is the issue others have been facing. Ordered a different zwave stick and will try that. Should have done my homework before buying the stick. On the plus side though I have a much better handle on zwave and mqtt after a few days of trying to get this working.
Reading through that link, the work around seems to be to plug the z-stick in via a usb2.0 hub
Tried that with a hub I had laying around, didn’t work, though the hub may be “too smart” for the work around.
Either way, I’d prefer not to have extra cables hanging off the PI if I don’t need them. For the price of the new stick, minus what I’ll sell the aeotec for on Craiglist at a loss, plus the cost savings of not buying another USB hub, I figure it cost me at most an extra $15, maybe less, to buy a different stick, which I can live with.
