Is this possible to add Zway as an alternative to OpenZWave?
API calls will help to use it on different devices over the net having zway on a stand-alone server.
Here’s a description of API https://zwayhomeautomation.docs.apiary.io/
Also, if it’s possible to do without auto discovery (each node manually configured is a preferred way).
I have tried to make a simple thermostat control for Danfoss LC13 (get/set setpoint and get current temperature from a separate sensor which is HA entity, but I am not a developer and don’t know Python.
https://github.com/ardeus-ua/custom_components/blob/master/climate/zway.py
