I have the enerwave zwn-rsm2 which is a 2 relay in wall switch. Unfortunately it only reports when one of the relays gets switched from the switch. They both work when activated from HASS. I think it might be because it is seen by HASS as the single relay device because they both share the same device id. this issue is a known issue and fixed in the main openzwave files as documented (https://github.com/OpenZWave/open-zwave/issues/801) on the openzwave github issues page. It is fixed there but I tried copying the files that are changed but it does not seem to help. HASS still sees it as the single relay module. How can we get HASS to see this as the dual channel relay and then hopefully it will work properly with HASS?
Thanks.
Hi Sam. Is this still a problem with the ZWN-RSM2?
Can anyone confirm that this relay is functioning properly with HASS?
