ZWN-RSM2-PLUS Z-Wave Relay
I recently installed a ZWN-RSM2-PLUS relay (link below to those unfamiliar) . They are working great so far.
I am using these with standard wall switches. If the relay is toggled via HA, the switch on the wall, shows as off but the light is on. I can live with that. What I want to try doing is if HA sees it already on and the relay is activated via the switch (switch on wall is moved to on but since HA took action this will turn the light off), no action is taken or HA cancels out the action by keeping the light on. So when the switch is up again its on and down its off. The reverse physical switch status only happens if HA initiated an ON, is there a macro or tasks I can automate within HA to do what I want?
If this isnt clear, ask questions :slight_smile:
