ZWP Dimmer - status not correct
I have a few ZWP dimmer switches. They are the same as the Homeseer WD-100+ dimmers and they support instant status. The dimmers update within a second or two, but the UI is showing weird values. If I turn off the dimmer from the UI, the light goes off but the UI shows that it’s dimmed to 10% or 20% instead of being completely off.
This occurs even after I add “refresh_value: true” and “delay: 3” to each device in the zwave section of my config. How do I fix this?
