Continue Discussion 265 replies
July 2019
Eatoff
That was quick for the raspberry pi 4 support! I just got it up and running on Raspbian Buster last night, might just move it all across anyway
Edit: actually, no USB boot support yet. I moved my raspbian to a USB SSD
July 2019
RyanRayNeff
Thanks for all your hard work! Regarding pi 4 support, is the 32 bit version recommended, or the 64 bit version?
July 2019
DavidFW1960
Actually, no it doesn’t if you are on a tablet in landscape mode it shows the minimized sidebar.
1 reply
July 2019
allan
re the sidebar, what about us poor souls who specifically asked during the original twitter thread started by JuanMTech mockup that we wanted to keep the ability to completely turn off the sidebar?
“The sidebar will now always be visible” feels like you just ignored us.
Please don’t take this the wrong way. I love the work you guys do, and appreciate the effort that is involved. But this feels like you just made a pretty big choice for all users about how their HA system is going to look. :frowning:
July 2019
3vasi0n
When’s the official android mobile app gonna drop?
1 reply
July 2019 ▶ allan
apop
I believe if you want to hide the sidebar, you can still do that with Compact Custom Header.
1 reply
July 2019 ▶ apop
DavidFW1960
How then do you unhide it to access say the dev-tools? (answer: you can’t easily)
1 reply
July 2019 ▶ DavidFW1960
apop
Not certain - I haven’t upgraded to 0.96 yet so I can’t test it out, but in prior versions you can use CCH to hide the sidebar but still optionally be able to swipe from left to reveal it.
July 2019 ▶ apop
tom_l
If it does operate that way then it sounds like an acceptable solution.
July 2019
DavidFW1960
I have upgraded and it doesn’t
July 2019 ▶ apop
mayker
I will not be adding any more features related to the sidebar. Since CCH only operates inside of Lovelace I need to keep any interaction with the sidebar to a minimum. The sidebar is required for navigation outside of Lovelace, so any modification of it should be handled with an addon that is available across the entire frontend. Something like this doesn’t exist yet, but I’m sure it will in time.
Talked about it a bit here: Compact Custom Header
July 2019
aneisch
Anyone else?
Testing configuration at /opt/homeassistant/
Failed config
  General Errors:
    - Platform not found: device_tracker.nmap_tracker
device_tracker:
  - platform: nmap_tracker
    home_interval: 10
    hosts:
      - 10.0.1.13/32
      - 10.0.1.59/32
July 2019
smccoy
I’m seeing the same error with nmap_tracker and unifi. Unifi was giving the same error in 0.95.4 as well (but runs fine).
July 2019 ▶ aneisch
aneisch
Was going to open an issue but seems to be resolved after a restart of HASS.
1 reply
July 2019
123 Regular
Where is Config Check now?
I don’t see it in the usual place (Configuration > General) in between where you select your location and Server Management.
Screenshot%20from%202019-07-17%2023-01-54
July 2019
ccmacaluso
My ecobee climate objects have lost the ‘operation’ attribute in this release. I don’t see any documented change on that, though, so could this be a bug?
1 reply
July 2019 ▶ 123
aidbish
Have you enabled advanced mode?
1 reply
July 2019 ▶ aidbish
123 Regular
Thanks! I overlooked to do that.
Kind of odd that if you don’t enable Advanced mode, you still get the menu to restart the server! :thinking:
… and here we go again. My perfectly functional custom component from 0.94.2 isn’t loaded in 0.96.0. No complaints in the log during startup but no component created. Only when I run Config Check does it report: Platform not found: climate.my_mqtt
Looks like I have my work cut out for me.
I don’t know what exactly transpired on the discord channel but the new menu’s inability to be hidden is not to my liking.
July 2019 ▶ 123
aidbish
First stab of it, maybe get added in later release. I know they removed another part when not in advanced mode after feedback
July 2019 ▶ 123
aidbish
Possibly due to the changes for climate 1.0. I would check out the GitHub pr on the changes
Smartir climate had same issue and was resolved by Dev of it
1 reply
July 2019 ▶ aidbish
123 Regular
I was monitoring the beta and didn’t see anything dramatically different in MQTT HVAC. Of course, all it takes is just one little change in just the right place …
Unrelated to my custom component but I just noticed i0.96.0 can’t find the toggle-lock-entity-row card. Weird. More digging to be done.
Screenshot%20from%202019-07-17%2023-28-49
July 2019
tom_l
Ditto. Though using CCH to hide it on tablets and for users who I don’t want to access it at all is possible. So no drama.
July 2019
DavidFW1960
Nor mine. All objections dismissed.
The ability of CCH to hide it isn’t adequate IMO.
1 reply
July 2019
sparkydave Know-it-All
I’m really looking forward to this update (cloud fix):
really happy that the HassIO version is out so quickly too! Awesome :grin:
July 2019 ▶ sparkydave
DavidFW1960
I’m seeing 0.96 there
nickrout Solution Institution
I had to relead the browser page, old page must have been cached.
1 reply
July 2019 ▶ nickrout
I stand corrected. my bad
July 2019
Noahma
whoooo buddy… I am not even sure where to start with this lol. This is what the config tester gives me.
I am currently running 95.4
  copying cffi/_embedding.h -> build/lib.linux-armv7l-3.7/cffi
    copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.7/cffi
    running build_ext
    building '_cffi_backend' extension
    creating build/temp.linux-armv7l-3.7
    creating build/temp.linux-armv7l-3.7/c
    gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/include/ffi -I/usr/include/libffi -I/usr/local/include/python3.7m -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.7/c/_cffi_backend.o
    unable to execute 'gcc': No such file or directory
    error: command 'gcc' failed with exit status 1
    ERROR: Failed building wheel for cffi
    Running setup.py clean for cffi
    Building wheel for pycparser (setup.py): started
    Building wheel for pycparser (setup.py): finished with status 'done'
    Stored in directory: /root/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511
  Successfully built pycparser
  Failed to build cffi
  Installing collected packages: setuptools, wheel, pycparser, cffi
    Running setup.py install for cffi: started
      Running setup.py install for cffi: finished with status 'error'
      ERROR: Complete output from command /usr/local/bin/python -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-728nqkv3/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-5sb4lqs2/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-gbqe3dil/overlay --compile:
      ERROR: unable to execute 'gcc': No such file or directory
          No working compiler found, or bogus compiler options passed to
          the compiler from Python's standard "distutils" module.  See
          the error messages above.  Likely, the problem is not related
          to CFFI but generic to the setup.py of any Python package that
          tries to compile C code.  (Hints: on OS/X 10.8, for errors about
          -mno-fused-madd see http://stackoverflow.com/questions/22313407/
          Otherwise, see https://wiki.python.org/moin/CompLangPython or
          the IRC channel #python on irc.freenode.net.)
          Trying to continue anyway.  If you are trying to install CFFI from
          a build done in a different context, you can ignore this warning.
      running install
      running build
      running build_py
      creating build
      creating build/lib.linux-armv7l-3.7
      creating build/lib.linux-armv7l-3.7/cffi
      copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/verifier.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/lock.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/api.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/model.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/recompiler.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/__init__.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/cparser.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/error.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/commontypes.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.7/cffi
      running build_ext
  ERROR: Command "/usr/local/bin/python -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-728nqkv3/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-5sb4lqs2/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-gbqe3dil/overlay --compile" failed with error code 1 in /tmp/pip-install-728nqkv3/cffi/
ERROR: Command "/usr/local/bin/python /usr/local/lib/python3.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-gbqe3dil/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --find-links https://wheels.home-assistant.io/alpine-3.9/armv7/ -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; python_implementation != '"'"'PyPy'"'"''" failed with error code 1 in None
[23:01:18] ERROR: An error occurred while installing Home Assistant:
Looking in links: https://wheels.home-assistant.io/alpine-3.9/armv7/
Collecting homeassistant
  Downloading https://files.pythonhosted.org/packages/15/85/89cc12c8d9d6969bdc394e56aae8107cfc7112255b346ffa7fb6f575ce64/homeassistant-0.96.0-py3-none-any.whl (5.0MB)
Collecting python-slugify==3.0.2 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/c1/19/c3cf1dc65e89aa999f85a4a3a4924ccac765a6964b405d487b7b7c8bb39f/python-slugify-3.0.2.tar.gz
Collecting aiohttp==3.5.4 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/0f/58/c8b83f999da3b13e66249ea32f325be923791c0c10aee6cf16002a3effc1/aiohttp-3.5.4.tar.gz (1.1MB)
  Installing build dependencies: started
  Installing build dependencies: finished with status 'done'
  Getting requirements to build wheel: started
  Getting requirements to build wheel: finished with status 'done'
    Preparing wheel metadata: started
    Preparing wheel metadata: finished with status 'done'
Collecting attrs==19.1.0 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/23/96/d828354fa2dbdf216eaa7b7de0db692f12c234f7ef888cc14980ef40d1d2/attrs-19.1.0-py2.py3-none-any.whl
Collecting astral==1.10.1 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/ff/5d/261f49822b7f77c265197d46cdbaaaaf06f458734e9ac55a140dd75bdf29/astral-1.10.1-py2.py3-none-any.whl
Requirement already satisfied: pip>=8.0.3 in /usr/local/lib/python3.7/site-packages (from homeassistant) (19.1.1)
Collecting pytz>=2019.01 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/3d/73/fe30c2daaaa0713420d0382b16fbb761409f532c56bdcc514bf7b6262bb6/pytz-2019.1-py2.py3-none-any.whl (510kB)
Collecting pyyaml==5.1.1 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/a3/65/837fefac7475963d1eccf4aa684c23b95aa6c1d033a2c5965ccb11e22623/PyYAML-5.1.1.tar.gz (274kB)
Collecting cryptography==2.7 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/c2/95/f43d02315f4ec074219c6e3124a87eba1d2d12196c2767fadfdc07a83884/cryptography-2.7.tar.gz (495kB)
  Installing build dependencies: finished with status 'error'
July 2019
BlinkyLights
I haven’t updated yet as I suspect I am going to need to re-check all my climate stuff but I can’t think of ANY reason I would always want the sidebar visible even if it was more compact. It mostly contains functions the admin is considered with not a typical user.
And on mobile I have completely removed both menus with the compact header mode as most of the time they are BOTH not necessary since they are mostly edit functions.
1 reply
July 2019
aidbish
Can be done with CCH.
1 reply
July 2019 ▶ aidbish
BlinkyLights
Sounds like I should wait a few days for the custom lovelace components to update and I should be good to go.
Just hope the compact header can still allow the notification icon to be visible and not part of the side bar.
1 reply
July 2019
kostya
Not a big fan of UI items that stick out and can’t be hidden. This is kind of a step back from “clean” UI.
July 2019
tom_l
It can not.
Use the solution posed by @aidbish above.
July 2019 ▶ Noahma
eXtatic
Same here with Hass.io Docker install.
July 2019 ▶ Noahma
rosie
Same here, but history has taught me to always wait for the .1 release, so I’m not clicking upgrade just yet.
1 reply
July 2019
I don’t mind the new sidebar arrangement, but
  1. I have only tried on my desktop so far; and
  2. I agree you should be able to get rid of it.
July 2019 ▶ 123
thundergreen
There is a big blog about the climate rewrite. Please read the post above !
1 reply
July 2019
VDRainer
The new Dev Tools are awesome.
Going back to them and seeing the same states/templates is realy great!
Thanks for this!
July 2019
BlackChart
The Hue integration is broken after I updated to .96 - other that have this issue?
I see no errors in the logs, but every Hue light or sensor is unavailable.
July 2019 ▶ Noahma
nicknick
I get this too. Is the config tester broken again? I checked the breaking changed and saw nothing significant for me, so was somewhat surprised that this has happened again.
July 2019
BlackChart
Okay - after 5 restarts the Hue devices is back - strange that nothing is written to the log if the bridges (yes I have 2) were out of reach (which have never happend before)
July 2019 ▶ nicknick
aidbish
I don’t think the config checker would be able to check if there would be issues with installing dependencies in this case.
July 2019 ▶ BlackChart
Hue works here.
July 2019
homehacker
My enphase integration seems to be broken. No entities found following an update to 0.96 on hassio.
Log Details (ERROR)
Thu Jul 18 2019 00:30:30 GMT-0700 (Pacific Daylight Time)
Error while setting up platform enphase_envoy
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
    return fut.result()
  File "/usr/src/homeassistant/homeassistant/components/enphase_envoy/sensor.py", line 45, in async_setup_platform
    from envoy_reader.envoy_reader import EnvoyReader
  File "/usr/local/lib/python3.7/site-packages/envoy_reader/envoy_reader.py", line 8, in <module>
    import requests_async as requests
ModuleNotFoundError: No module named 'requests_async'
July 2019 ▶ homehacker
Yet you provide no logs, no config. No one can help!
1 reply
July 2019
cameron
I have No Lights they are all unavailable. I Am using Deconz Conbee it was working in 95.4.
The logs show no errors. And the config Configuration valid!
Will try and keep rebotting HA As @BlackChart has done.
July 2019 ▶ cameron
Logs!!! Why do people ignore providing basic info?
1 reply
cameron
Like i said there are No Errors in the Logs.
1 reply
July 2019 ▶ cameron
rendili
Hi @cameron
I don’t think this could be it, but if you use the custom component, did you update the custom component files from GitHub for this release?
1 reply
July 2019 ▶ Noahma
Sweetpants
I am getting excactly the same when checking 0.95.4 -> 0.96 using: Check Home Assistant configuration Add-on
partial log:
copying cffi/pkgconfig.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/ffiplatform.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/cparser.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/lock.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/__init__.py -> build/lib.linux-x86_64-3.7/cffi
copying cffi/_cffi_include.h -> build/lib.linux-x86_64-3.7/cffi
copying cffi/parse_c_type.h -> build/lib.linux-x86_64-3.7/cffi
copying cffi/_embedding.h -> build/lib.linux-x86_64-3.7/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-x86_64-3.7/cffi
running build_ext
creating build/temp.linux-x86_64-3.7
creating build/temp.linux-x86_64-3.7/c
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/include/ffi -I/usr/include/libffi -I/usr/local/include/python3.7m -c c/_cffi_backend.c -o build/temp.linux-x86_64-3.7/c/_cffi_backend.o
July 2019 ▶ Sweetpants
DavidFW1960
How are you checking?
July 2019
cameron
Hi @rendili
No i have not updated the Hive Component yet because the wife needs the lights back on.
I Found the probem it was a Custom Component Call Light Proxy by @OttoWinter
I have uninstalled it and now my lights are back…
July 2019 ▶ cameron
rendili
@cameron, ok, good to hear all is working for you and that is was not a Hive issue :slight_smile:
July 2019
klogg
Me too (Same here and not upgrading yet).
I thought carefully about not adding to a flood of “me too” posts but then decided that it was probably the only way to get issues noticed on this forum. Although I suspect the issue is with the checker add-on rather than the latest version of HA).
1 reply
July 2019
DavidFW1960
That’s why I was asking… I don’t think that checker addon has worked for a while and I deleted it. There is a breaking-changes custom component but I have not used that either. I generally just check for the breaking changes in the release notes.
July 2019
frenck
Do you know this is now natively supported by HA itself?
1 reply
July 2019
wummeke
The new OpenTherm Gateway component does not create a climate device (see https://github.com/home-assistant/home-assistant/issues/25239) , but it does add a dozen sensors. Most of them are useless for me, as my central heater does not support all those features. Is there a way to limit that behaviour?
July 2019 ▶ frenck
cameron
Thank you @frenck i have not seen that . Thanks for all your work on HA as well, and love the youtube blogs. :+1:
July 2019 ▶ Noahma
erika.mason24
Seeing exactly the same. I’m on 0.94.4.
July 2019
IK0ADR
Hi all.
Unfortunately broadlink switch seems broken (was OK in 95):
2019-07-18 11:47:25 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
    return fut.result()
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/broadlink/switch.py", line 80, in setup_platform
    broadlink_device = broadlink.rm((ip_addr, 80), mac_addr, None)
  File "/srv/homeassistant/lib/python3.7/site-packages/broadlink/__init__.py", line 529, in __init__
    device.__init__(self, host, mac, devtype)
  File "/srv/homeassistant/lib/python3.7/site-packages/broadlink/__init__.py", line 171, in __init__
    self.update_aes(key)
  File "/srv/homeassistant/lib/python3.7/site-packages/broadlink/__init__.py", line 184, in update_aes_crypto
    backend=default_backend())
  File "/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/backends/__init__.py", line 15, in default_backend
    from cryptography.hazmat.backends.openssl.backend import backend
Config:
  - platform: broadlink
    host: 192.168.1.222
    mac: 'C8:F7:42:16:F3:73'
    type: rm_mini
    switches:
      condizionatore_pwr1:
        friendly_name: "condizionatore1"
        command_on: 'JgBAAAABGYkVMhUPFQ8VDxUzFQ8VDxUPFQ8VDxUPFQ8VDxUPFQ8VDxUPFTMUEBQQFBAUMx$...'
        command_off: 'JgBAAAABGYkVMxUPFQ8VDxUyFQ8VDxUPFTMVMxUPFQ8VDxUPFQ8VDxUPFBAUEBQQFBAUM$....'
Many thanks!!
July 2019 ▶ IK0ADR
aidbish
Have you done another restart, it maybe needing to install some dependecies and needs to reboot. worth a try if you haven’t already
1 reply
July 2019 ▶ aidbish
IK0ADR
same after reboot
thanks…
July 2019 ▶ thundergreen
123 Regular
I am 100% aware of it and have been following it from its early days in the GitHub architecture repo to the PR by pvizeli.
July 2019
HypnoToad
Anyone else using Firefox noticing some wierdness with the sidebar?
I click the minimise button in the top left, and everything move to the left, but the bar doesn’t minimise, it stays full size like this:
sidebar
July 2019
123 Regular
Yes.
What I’m seeing is that it won’t minimize until I move the mouse pointer away from the menu.
July 2019 ▶ aneisch
woody4165
I’m having same issue, but I haven’t solved after few restarts
My config is
    home_interval: 5
    hosts: 192.168.1.0/24
    # interval_seconds: 30
    # consider_home: 180
before 0.96 I had also the two commented lines active, and no issue.
Looking at the integrations description I don’t see those two parameters.
Are these still active?
Where should I open the issue?
1 reply
July 2019 ▶ 123
DavidFW1960
I’m seeing similar on my iPad… it’s not snapping back properly (iOS app and chrome) but not 100% sure it’s HA and not the iOS 13 beta causing it…
1 reply
July 2019 ▶ woody4165
aidbish
they are part of the device_tracker
see link at the bottom of the page you referenced
July 2019 ▶ 123
HypnoToad
Thanks, nice to know it’s not just happening to me. I guess this is ‘v1’ of the new sidebar, hopefully ‘v2’ will work out a few of these issues :slight_smile:
xdss
I have the exact same log error using the enphase integration as well. Was looking forward to mapping out individual inverter numbers…
July 2019
Simon_Button
installed hassio on pi4, but getting “… add-on is not available on your system.” for all add-ons? Any ideas?
1 reply
July 2019
123 Regular
Ditto.
I don’t see why there has to be a tradeoff. You want icons? Then you gotta lose the ability to hide the menu!
Eh?
I’m not fond of the workaround which is install and configure a completely different menu.
Car Customer: I don’t like this new triangular steering wheel. I prefer the round one.
Car Dealer: It’s the latest thing. It’s better. Trust me.
Car Customer: Can I get a round one?
Car Dealer: Sure. Just replace it yourself.
1 reply
July 2019
Adorem
Yep you are not alone:
July 2019
ZioTitanok
Same here. Got similar error, but there are some differences.
Also I’ve tried to:
Any suggestion!?
July 2019 ▶ ZioTitanok
Ernst
Having similar issues on my xiaomi vacuum cleaner here too, with the same ImportError about OPENSSL_1_1_1.
xiaomi_miio: Error on device update!
ImportError: /usr/lib/arm-linux-gnueabihf/libssl.so.1.1: version `OPENSSL_1_1_1' not found (required by /srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so)
July 2019
Greg
I’ve lost the ability to use ‘boost’ for my Hive :grimacing: I can set the device to on (on), off (off), and eco (which seems to map to ‘schedule’ on the Hive) - any ideas @rendili?
1 reply
July 2019 ▶ aneisch
frelew
nmap_tracker issues with 0.96
I will comment some options and see if it works.
1 reply
July 2019
voydz
Anyone else got issues trying to update?
My hassio log spits out something along the lines:
19-07-18 11:49:41 INFO (SyncWorker_9) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.95.4 to homeassistant/qemux86-64-homeassistant:0.96.0
19-07-18 11:49:41 INFO (SyncWorker_9) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.96.0.
19-07-18 11:50:33 ERROR (SyncWorker_9) [hassio.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.96.0 -> 404 Client Error: Not Found ("no such image: homeassistant/qemux86-64-homeassistant:0.96.0: No such image: homeassistant/qemux86-64-homeassistant:0.96.0").
19-07-18 11:50:33 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
Reading the “404 - not found” error I thought the image might be taken down, so I tried pulling the image locally (docker pull homeassistant/qemux86-64-homeassistant:0.96.0) but this works just fine.
1 reply
July 2019 ▶ Greg
rendili
@Greg
Unfortunately we had to move the hotwater device from climate to water_heater, and at the moment water_heater does not support any boost functionality and does not have a an auto mode, so for now in the short term we have had to map this to eco.
1 reply
July 2019
skaker1
ASUSWRT stopped working.
Error during setup of component asuswrt
13:51 components/asuswrt/init.py (ERROR)
Thu Jul 18 2019 13:51:35 GMT+0200 (centraleuropeisk sommartid)
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py”, line 153, in _async_setup_component
hass, processed_config)
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/asuswrt/init.py”, line 45, in async_setup
from aioasuswrt.asuswrt import AsusWrt
File “/srv/homeassistant/lib/python3.7/site-packages/aioasuswrt/asuswrt.py”, line 9, in
from aioasuswrt.connection import SshConnection, TelnetConnection
File “/srv/homeassistant/lib/python3.7/site-packages/aioasuswrt/connection.py”, line 6, in
import asyncssh
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/init.py”, line 31, in
from .agent import SSHAgentClient, SSHAgentKeyPair, connect_agent
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/agent.py”, line 35, in
from .public_key import SSHKeyPair, load_default_keypairs
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/public_key.py”, line 43, in
from .encryption import get_encryption_params, get_encryption
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/encryption.py”, line 23, in
from .crypto import BasicCipher, GCMCipher, ChachaCipher, get_cipher_params
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/crypto/init.py”, line 27, in
from .ec import ECDSAPrivateKey, ECDSAPublicKey, ECDH
File “/srv/homeassistant/lib/python3.7/site-packages/asyncssh/crypto/ec.py”, line 24, in
from cryptography.hazmat.backends.openssl import backend
File “/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/backends/openssl/init.py”, line 7, in
File “/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/backends/openssl/backend.py”, line 74, in
from cryptography.hazmat.bindings.openssl import binding
File “/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/openssl/binding.py”, line 15, in
from cryptography.hazmat.bindings._openssl import ffi, lib
ImportError: /usr/lib/arm-linux-gnueabihf/libssl.so.1.1: version `OPENSSL_1_1_1’ not found (required by /srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so)
1 reply
July 2019
woody4165
have you find a solution?
still looking for it, since I get error during “Check Home Assistant configuration”
Failed config
  General Errors:
July 2019
cyn
I’ve never installed or updated numpy, is this something I should attempt to fix or is this something the developers of the IQVIA platform need to address?
IQVIA Platform Error
2019-07-18 06:06:12 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform iqvia.sensor: Platform not found (
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the multiarray numpy extension module failed. Most
likely you are trying to import a failed build of numpy.
Here is how to proceed:
Original error was: libf77blas.so.3: cannot open shared object file: No such file or directory
July 2019 ▶ voydz
voydz
Replying to my own problem here.
In case anyone gets this issue, check your disk usage %, after running docker pull homeassistant/qemux86-64-homeassistant:0.96.0 ssh’d onto hassio it told me there is no disk space left.
Sadly the error output from hassio is a bit misleading here.
July 2019
IK0ADR
eq3btsmart error also in 0.96…
2019-07-18 13:56:17 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform eq3btsmart
    return fut.result()
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/eq3btsmart/climate.py", line 69, in setup_platform
    devices.append(EQ3BTSmartThermostat(mac, name), True)
TypeError: append() takes exactly one argument (2 given)
In config:
climate:
  - platform: eq3btsmart
    devices:
      salotto:
        mac: !secret salotto_mac
July 2019 ▶ HypnoToad
daneberryman1
I’m also having the same issue. chrome seems to be doing it as well but only randomly
July 2019
Paaland
All my Netatmo sensors only shows “unknown”. Does it work for anyone else?
daneberryman1
also having same same issue, also running iPad OS 13 Beta
1 reply
July 2019 ▶ daneberryman1
petro Great contributor
You guys using a browser for this or the iOS app? I’ve noticed that the app fully hides the sidebar. I’ll be honest. I like the way the iOS app does it over this new shrinking side bar.
Not a fan of the never hiding sidebar on desktop.
July 2019
aidbish
If you have issues with climate integrations in 0.96 i suggest logging issue here
after checking if nobody else has logged, if they have add to their issue.
also the more info the better as opposed to “its broke” or “me too”
July 2019
Ernst
For all those people with OPENSSL issues, please follow the discussion here.
July 2019 ▶ 123
Wizbowes
Sorry - what is CCH?
I’ve had a play with the new menu and I am not a fan at all.
  1. It takes up screen real-estate for little benefit. 95% of the time I have the sidebar closed and only open it for config tasks. Why have something taking up screen space when I hardly use it?
  2. Nothing should interact on mouse-over. It’s not a design paradigm anywhere else in home-assistant. I’m a bit shakey on a mouse - and the first thing I did when messing about on the demo screen is try to open the top left camera - overshot a bit and suddenly the sidebar is open. Then over to the right to let it close - and then I did it again!
  3. At the most - if we have to have a slidey sidebar - why can’t it just slide in when you hover over the hamburger top left? Why take up all that space on the main screen?
It really looks like they thought it looked cool and just did it. Is this something somebody could make a custom component for like they did to de-clutter the top banner?
1 reply
July 2019
ChaoticUnreal
So not really related to the new version (haven’t updated yet)
But on the demo how do you get the weather map? is it just linking to an external site or is it a component I’m not aware of?
July 2019 ▶ 123
KennethLavrsen
@DavidFW1960 It is same on IOS12 on iPad. I have raised a bug report on it on github today
July 2019
KennethLavrsen
Can someone try and open HA 0.96 in Edge?
On the computer I have access to here at work NOTHING is displayed other than a blue bar.
I do not normally use Edge so I do not know how it worked in 0.95. I tried because I noticed issues with the new left bar in Google Chrome on Linux. The Google Chrome issue went away after a yum update on that Centos machine
But when I look at my Home Assistant in Edge in Windows 10 I cannot get the browser to display anything. I never get to the login prompt. Nothing. Can someone here confirm that problem?
July 2019
mig2008pt
Hi everyone, Great Work that you all do with Home Assistant, Love it!
Love Updates and all the changes, but this time after updating to 0.96, Cloud Component broke… And the problem seems to be the same as other people posted above for other broke components.
2019-07-18 12:00:28 ERROR (MainThread) [homeassistant.setup] Error during setup of component cloud
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 153, in _async_setup_component
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/cloud/__init__.py", line 142, in async_setup
    from hass_nabucasa import Cloud
  File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/__init__.py", line 16, in <module>
    from .remote import RemoteUI
  File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/remote.py", line 16, in <module>
    from .acme import AcmeClientError, AcmeHandler
  File "/srv/homeassistant/lib/python3.7/site-packages/hass_nabucasa/acme.py", line 9, in <module>
    import OpenSSL
  File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/__init__.py", line 8, in <module>
    from OpenSSL import crypto, SSL
  File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/crypto.py", line 16, in <module>
    from OpenSSL._util import (
  File "/srv/homeassistant/lib/python3.7/site-packages/OpenSSL/_util.py", line 6, in <module>
    from cryptography.hazmat.bindings.openssl.binding import Binding
  File "/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 15, in <module>
Tried to update and upgrade de OS, I’m running Hassbian Strech instillation, didn’t work.
Keep the good work, thanks.
1 reply
July 2019 ▶ KennethLavrsen
cyn
Edge stopped working for me awhile back.
Recently I installed the new Canary Version and with 96 it works perfectly
rendili
@KennethLavrsen
I have just checked and I have the same issue with edge.
With 0.94.2 it works in Edge (no so snappy in performance compared to Chrome), but with 0.96.0 I get just the bar at the top (Orange for me with this server :slight_smile: ) , no menu options / text
GaryK
Same here. For x86_64.
Update: Upgraded Check Config and errors went away.
July 2019 ▶ Wizbowes
cyn
CCH = Compact Custom Header what you are calling the top banner
I agree definitely not a fan.
warllo54
I am seeing this on chrome as well. On multiple computer as well.
1 reply
