Thanks for the link. But since I have a Nabucasa subscription, cloud: was already enabled in my configuration. However, I’ve tried if the problem could be solved by deleting it, restarting, add it again and restart again. But this makes no difference…
So, that means i.m.h.o. that we need to wait for an update of the app…
Yes, the hass_nabucasa python module was missing.
In my setup, I’m using Python virtual environment, so all I had to do was to activate the environment and simply run $ pip install hass_nabucasa. And reboot.
100.1 somehow broke my hassio. It was running for 10min and then always stopped. Nothing in the logs. 99.3 is stable again, even though i had to delete and resinstall some addons after the snapshot.
## checks the installed version of Home Assistant
- platform: version
## checks for the latest available version of Home Assistant
- platform: scrape
resource: https://www.home-assistant.io
name: HA Online Version
select: ".current-version h1"
value_template: '{{ value.split(":")[1] }}'
automation:
- alias: HASS Update Available Display
platform: time_pattern
hours: '/1'
minutes: 00
seconds: 00
service_template: >-
{% if (states.sensor.ha_online_version.state != states.sensor.current_version.state) %}
homeassistant.turn_on
{% else %}
homeassistant.turn_off
{% endif %}
entity_id: input_boolean.bool_3
then I just use a conditional card to display the status of the input boolean in the frontend when it’s on.
Well, i’d love to provide more details… but as i said… the logs were not showing anything out of the ordinary. Actually, they were not even updated anymore. The System starts up fine, runs for some random 10 - 20min and then suddenly frontend/automation etc. stops working. I still have access to my samba shares and my other hassio addons, but the main thing (Hassio) is not working anymore. As i need my system online i reverted back for the time being. If you have any pointers on what i can do to provide a better report please let me know, so i can file it @github.
Thanks, I ended up fixing mine by simply changing it to check if the installed version is not equal to the latest version (rather than being less than it) which looks like what you are doing there.
I’ve notice something strange, I’m not sure if is something I’m doing wrong, but on hassio system log I have a time that is not correct, (1 hour earlier) and on Developer tools - Logs I have the correct time…
File "/usr/src/homeassistant/homeassistant/components/google_assistant/smart_home.py", line 58, in _process
result = await handler(hass, data, inputs[0].get("payload"))
File "/usr/src/homeassistant/homeassistant/components/google_assistant/smart_home.py", line 168, in handle_devices_execute
await entities[entity_id].execute(data, execution)
File "/usr/src/homeassistant/homeassistant/components/google_assistant/helpers.py", line 294, in execute
await trt.execute(command, data, params, challenge)
File "/usr/src/homeassistant/homeassistant/components/google_assistant/trait.py", line 956, in execute
if self.state.state == params["armLevel"]:
KeyError: 'armLevel'
