Borgy
June 22, 2020, 3:23am
213
thanks @DavidFW1960 - so ended up removing all signs of Coronavirus integration and rebooting…
then it allowed me to re-add countries (the country entry did not appear b4).
Now have added a few countries - still same issue with WW 2 sensors.
THanks!
Yeah that PR you linked needs to be merged. For now I just disable those specific sensors.
Borgy
June 24, 2020, 11:07am
215
did the WW Deaths sensor also just stop working ??
0.112.x It’s fixed and all 4 WW sensors are working. (Beta version now)
Borgy
June 26, 2020, 1:32am
218
interesting notice the sensors are now showing a 0 and i am still on 0.111.4!
Borgy
June 26, 2020, 3:24am
220
doesnt seem so - just started showing 0 approx 4 hrs ago i think - no reboots
viktak
(viktak)
July 6, 2020, 10:53am
221
I just updated to 0.112.2 and all my covid entries are unavailable, even after several restarts…
Borgy
July 9, 2020, 7:28am
222
i have seen that also - ended up having to remove all and re add integration
viktak
(viktak)
July 9, 2020, 7:54am
223
I have since updated to 0.112.3, and now life is good again!
filippos
(Filippos)
July 11, 2020, 12:33pm
224
humm… whenever i try to add the integration i get this:
Logger: homeassistant.components.coronavirus
Source: helpers/update_coordinator.py:140
Integration: Coronavirus (COVID-19) (documentation, issues)
First occurred: 3:29:49 μ.μ. (1 occurrences)
Last logged: 3:29:49 μ.μ.
Timeout fetching coronavirus data
what goes?
dicko
(Martyn)
September 3, 2020, 7:28am
225
Hi
Did anyone manage to create a sensor to know the actual daily numbers rather than cumulative ? ie daily confirmed cases, daily deaths, etc ?
I saw an automation with variable.coronavirus_united_kingdon_yesterday but Ive tried a couple of ways to do it and not succeded in getting the figure as I am not sure how to create a variable of yesterdays figure
thanks
Martn
+1 I’m also interested in the daily numbers.
scstraus
September 26, 2020, 12:56pm
227
Hi @dicko @schumi2004 , here’s how I do daily numbers and display with a custom lovelace card:
Step 1) Install custom hass-variables component, probably with HACS
Step 2) Define variables
Step 3) Make automations to save yesterday’s numbers to variables
(You now have the daily numbers in the variables, you can continue if you want the lovelace card)
Step 4) Install custom text element
Step 5) Add this transparent image to your www/images directory
Step 6) Add lovelace card
Step 7) Remove units on active cases number:
in customize.yaml:
sensor.czechia_coronavirus_current:
unit_of_measurement:
(Of course, change the name to the name of your sensor.)
Step 8) See if it works with Czech numbers (takes 48 hours to calculate all the numbers)
Step 9) Customize for your country/theme
Et voila:
Revamp my corona info…
type: vertical-stack
cards:
- type: horizontal-stack
cards:
- entities:
- entities:
- entity: sensor.worldwide_corona_percentage_recovered
- entity: sensor.worldwide_corona_percentage_deceased
entity: sensor.worldwide_corona_percentage_infected
icon: 'mdi:biohazard'
state_header: Infected
type: 'custom:multiple-entity-row'
show_header_toggle: false
title: Covid Infection Worldwide
type: entities
cards:
- type: glance
entities:
- entity: sensor.worldwide_coronavirus_current_dot_separated
icon: 'mdi:virus'
- entity: sensor.worldwide_coronavirus_confirmed_dot_separated
- entity: sensor.worldwide_coronavirus_deaths_dot_separated
icon: 'mdi:grave-stone'
- entity: sensor.worldwide_coronavirus_recovered_dot_separated
icon: 'mdi:shield-check'
cards:
cards:
cards:
- entities:
color: yellow
hours_to_show: 48
points_per_hour: 1
type: 'custom:mini-graph-card'
show:
state: false
icon: false
cards:
- entities:
hours_to_show: 48
points_per_hour: 1
show:
state: false
icon: false
cards:
- entities:
color: red
hours_to_show: 48
points_per_hour: 1
show:
state: false
icon: false
cards:
- entities:
color: green
hours_to_show: 48
points_per_hour: 1
show:
state: false
icon: false
cards:
- entities:
- entities:
- entity: sensor.indonesia_corona_percentage_recovered
- entity: sensor.indonesia_corona_percentage_deceased
entity: sensor.indonesia_corona_percentage_infected
title: Covid Infection indonesia
type: entities
cards:
- type: glance
entities:
- entity: sensor.indonesia_coronavirus_current_dot_separated
icon: 'mdi:virus'
- entity: sensor.indonesia_coronavirus_confirmed_dot_separated
- entity: sensor.indonesia_coronavirus_deaths_dot_separated
- entity: sensor.indonesia_coronavirus_recovered_dot_separated
cards:
cards:
cards:
- entities:
color: yellow
hours_to_show: 48
points_per_hour: 1
show:
state: false
icon: false
cards:
- entities:
hours_to_show: 48
points_per_hour: 1
show:
state: false
icon: false
cards:
- entities:
color: red
hours_to_show: 48
points_per_hour: 1
show:
state: false
icon: false
cards:
- entities:
color: green
hours_to_show: 48
points_per_hour: 1
show:
state: false
icon: false
freekeys
September 27, 2020, 12:35pm
229
Nice @KingRichard ! Fancy sharing the YAML?
how do i get the new confirmed cases within the last 24h or since the last update (wich is equal cause they update once a day)? i tried using trigger_from wich doesn’t work no do i have a plan to save the actual number becoming yesterdays number to calculate it.
palex
(Pavel Alexandrov)
December 2, 2020, 9:15am
233
That’s worked for me:
- platform: statistics
entity_id: sensor.bulgaria_coronavirus_confirmed
sampling_size: 20000000
max_age:
hours: 43
sensors:
covid_today:
value_template: '{{ state_attr("sensor.covid","change")|int }}'
friendly_name: 'CovID today'
Tnx Pavel, it works. I didn’t see the possibility to solve this over the statistics, you opened my eyes. greetings, chris
