Well, hello!, Home Assistant Core 0.106! We are happy to see you đ
A great release that improves stability, reliability and a lot of helpful additions to make everything much more friendly and easier to use. So letâs dive in!
Safe Mode improvements
In Home Assistant 0.105, we introduced Safe Mode. Our goal is to make sure Home Assistant always starts and provide you an interface to work with. No matter what.
@balloob has been busy this release to improve on this feature even more, and Home Assistant is now able to overcome issues when things in the core system get into trouble and even when the Lovelace configuration isnât readable. Besides that, the way Safe Mode is presented has changed, so you instantly know you are in Safe Mode:
 Screenshot of Home Assistant running in Safe Mode.
Stepping up and down the brightness of lights
Ever tried to make an automation to brighten or dim your lights? Or tried to hook up a remote to control the brightness of a light? If you have, you probably know that doing that was pretty painful and involved some additional templating to get that going.
This release just made that a lot easier. An example device automation:
 Screenshot of a device automation with dimming lights.
We have also added this functionality to the light.turn_on service. You can now change the brightness, based on the current brightness,
using the brightness_step (-255, 255) and brightness_step_pct (-100, 100) parameters.
Good to know, when the brightness hits 0, it will turn off the light. If the light is already off, and you step the brightness up, it will turn on. This is awesome, because if you have a rotating dimmer button (for example, an IKEA SYMFONISK), you can rotate it to change the brightness, but also turn the light on/off by just rotating it.
Person more info dialogs improvements
Persons have a new more info dialog. They now show the location of the person on the map and if the person is not in a zone, you can create a zone with the current location of that person with one click.
 Screenshot of the new more info for a person.
Entities configuration panel now shows all entities
The entities configuration panel previously only contained entities that were uniquely identifiable by Home Assistant (they have a so-called: unique ID). However, those are not provided by all integrations of Home Assistant, confusing since the entities panel did not show all of your entities.
In this version, we now include all entities in the panel, giving you a nice complete overview of all available entities in your system. You canât edit all entities, since that requires an entity to be uniquely identifiable. If an entity doesnât have a unique ID, the pencil icon will be striked through.
 Screenshot of uneditable entities in the configuration panel.
Since all entities are now available in this panel, it does not only provide you a clear overview of all the available entities; you can also make use of the ârelated itemsâ feature introduced in release 0.105 to see where they are being used!
Updates to the developer tools panels
The developer tools panel also got some nice little touches. In the âInfoâ tab you can now find a list of all integrations you are using and the logs are now aware of the integrations as well.
Both now include links to the documentation and our GitHub issue tracker. This allows you to dive in quickly when you run into troubles with an integration.
 Screenshot of the integrations list and an example log message.
Sensor card
Our sensor card has had a style update. We initially got the design from the Lovelace Mini Graph Card and now updated to match the improved new look of that card.
 Screenshot of the updated sensor card.
Other noteworthy changes
But wait⊠there is more! Some other smaller noteworthy changes in this release:
In the zone editor that was introduced in the previous release, you can now change the location of your home zone. The radius of the home zone cannot be changed yet (we will work on that!), but you can drag the home zone on the map.
Also an improvement on a feature introduced in the previous release, the
state_coloroption is now also available for other cards, so you can override the defaults of the cards. -
New automations now default to device automations instead of state triggers and service calls. Device automations are so much easier and clearer to create from the UI. You can, of course, still use the old triggers and actions like you are used to.
In the generated Lovelace we no longer include automations and battery entities. You can find these in the automation configuration panel and the battery in the device configuration page. If you want to have your automations and/or battery in your Lovelace UI, you can always take control and add them.
Scripts and scenes now have the ability to set a custom icon. Previously, you would have to create a customization to do this, now, you can just set them in your configuration.
scene: - name: Movies icon: mdi:movie-open entities: light.tv_back_light: state: on brightness: 125 light.ceiling: off
Custom cards
Are you the creator of an awesome custom card for Lovelace?
We have made some changes to Lovelace that might impact your custom card, so be sure to read the blog post on the developers site about this.
New Integrations
New Platforms
If you need helpâŠ
âŠdonât hesitate to use our very active forums or join us for a little chat.
Experiencing issues introduced by this release? Please report them in our issue tracker. Make sure to fill in all fields of the issue template.
Breaking Changes
Tesla - Tesla default scan interval has been raised to 660 seconds from 300 seconds. This is the result of new testing showing the prior default would not allow Tesla vehicles to fall asleep. You should reevaluate your scan interval if you have changed it, to avoid battery drain. The scan interval has had the minimum lowered to 60. - (@alandtse - #31194) (tesla docs)
Insteon - The Insteon entity device state attributes were changed to conform to naming standards. Insteon Address is now
insteon_addressand Insteon Group is nowinsteon_group. You may need to update automations and scripts that rely on these attributes. - (@teharris1 - #31183) (insteon docs) -
AVM FRITZ!DECT (Removed) - FRITZ!Dect is being removed and you should use the FRITZ!Box integration instead, which offers more features. - (@escoand - #31359) ([fritzbox docs])
Example YAML configuration:
switch: - platform: fritzdect username: YOUR_USERNAME password: YOUR_PASSWORDshould change to
fritzbox: devices: - host: fritz.box username: YOUR_USERNAME password: YOUR_PASSWORD -
Danfoss Air - The names of some danfoss_air sensors include a misspelling of the word Danfoss. This typo has been corrected and you will need to adjust all occurrences respectively. - (@KasperLK - #31344) (danfoss_air docs)
The following sensors are affected:
dandoss_air_dial_battery->danfoss_air_dial_battery -
dandoss_air_exhaust_fan_speed->danfoss_air_exhaust_fan_speed -
dandoss_air_supply_fan_speed->danfoss_air_supply_fan_speed
Météo-France - Météo-France now supports the configuration flow and is now available to be added as an integration from the integrations UI! There are no more
monitored_conditionsand all sensors will be added automatically. - (@Quentame - #29927) (meteo_france docs) -
Glances - Glances sensors are now dynamically added, which results in entities having new names, in particular sensors for mounted disks and temperature. You will need to remove the existing configuration and re-add it, and adjust for any automations you have using the new entity names. - (@engrbm87 - #28639) (glances docs)
Service Calls - Service calls that reference non-existing entities will now log a warning instead of silently being omitted. If you are using a template and want to select no entities, you need to pass
noneinstead. The TTS integration will no longer target all media players if no entity ID passed in. You need to specifyallinstead. - (@balloob - #31427) -
Light - It is no longer allowed to pass both
brightnessandbrightness_pcttolight.turn_onservice. Previously passing both would have usedbrightness_pct. - (@balloob - #31452) (light docs) -
DSMR - Added Belgian meter. Some DSMR sensors have been renamed to align with DSMR specifications. âPowerâ sensors are now properly âEnergyâ sensors and those which were previously using âlowâ and ânormalâ descriptions now use âtarif 1â and âtarif 2â, respectively. - (@dupondje - #30121) (dsmr docs)
Example of sensor changes:
Power Consumption (low)->Energy Consumption (tarif 1) -
Power Consumption (normal)->Energy Consumption (tarif 2)
Orange Livebox Play TV - The Orange Livebox Play TV integration has been removed. A change to the site scraped with this integration has changed, causing the integration to break. This integration violated our design decisions and is therefore removed. - (@frenck - #31525) (breaking change)
Core - Only administrator users can stop or restart Home Assistant. - (@balloob - #31509) (homeassistant docs)
Sure Petcare - Sure Petcare supports new features and has improved existing features. As a result, you will want to note that
household_idhas been removed from configuration options as it is no longer needed. - (@benleb - #31437) (surepetcare docs)Example YAML configuration:
surepetcare: username: YOUR_SURE_PETCARE_LOGIN password: YOUR_SURE_PETCARE_PASSWORD feeders: [12345, 67890] flaps: [13579] pets: [24680] -
Frontend -
frontend.set_themeandfrontend.reload_themesnow require admin access. This will not break automations that set themes because those are run with admin access. Also, athemes_updated eventno longer contains all theme data. - (@balloob - #31654) (frontend docs) -
Modbus - The Modbus Binary Sensor can now read data from discrete inputs. A new variable
input_typewas added to define if you want to read fromcoilordiscrete_input. Coil is the default option. - (@vzahradnik - #30004) (modbus docs)Example YAML configuration:
binary_sensor: - platform: modbus scan_interval: 10 inputs: - name: Sensor1 hub: hub1 slave: 1 address: 100 input_type: discrete_input -
Tado - Adding support of multiple Tado accounts has changed the unique ID generation of sensor and climate devices, and now includes the ID of the home.
In addition, support for water heater zones has been added. Tado hot water zones with temperature control previously created a climate entity, e.g.,
climate.hot_water, and these will be replaced by awater_heater.hot_waterentity. This change is not breaking for hot water zones without temperature control as they do not have a climate zone.(@gorynychzmey - #31527) (@michaelarnauts - #30095) (tado docs)
tado: - username: [email protected] password: !secret tado_pwd1 - username: [email protected] password: !secret tado_pwd2If you have only one account this configuration will also work:
tado: username: [email protected] password: !secret tado_pwd -
UniFi - Changing tracking settings will no longer disable entities but will remove them completely from the state machine and entity registry. The SSID filter will now mark all wireless clients as
not_homeif they are connected to SSIDs that are not a part of the filter. - (@Kane610 - #31762) (unifi docs) -
Rest - Many devices continue to use XML for RESTful APIs. This change implements converting XML output to JSON via
xmltojsonso it can work with the existing rest sensor component.xmltojsontags may be confusing; if you are not familiar with the conversion, please use the xmltodict tool created by @balloob to identify the tags to be used to parse the resulting JSON.As the attributes that usually need to be scraped are deeper in the document, support for passing in a template to find the JSON attributes has been added. JSON APIs that do not have their attributes at the top level can also benefit from this change. - (@bdraco - #31809) (rest docs)
sensor: - platform: rest resource: http://192.168.1.20/status.xml authentication: basic username: username password: password json_attributes: - "htstatus" - "poolsp" - "spasp" - "pooltemp" - "spatemp" - "airtemp" json_attributes_path: "$.response.temp" value_template: "" - platform: rest resource: http://192.168.1.5/status.xml json_attributes: - "led0" - "led1" - "user0" - "temp0" - "btn0" json_attributes_path: "$.response" value_template: "OK" -
GreenEye Monitor (GEM) - Greeneye Monitor temperature readings are now correct (previously they would report as twice the actual value). If youâve compensated for this in your dashboards or displays, youâll need to undo that compensation with this release. - (@jkeljo - #31896) (greeneye_monitor docs)
Duke Energy - The Duke Energy integration has been removed. The website of Duke Energy changed, causing the integration to break because it relied on web scraping, which is no longer allowed to be used. - (@frenck - #31921) (breaking change)
deCONZ - deCONZ will no longer change entities to being disabled when using the integration configuration options but rather remove them completely from the state machine. Enabling the option will load all relevant entities again. - (@Kane610 - #31661) (deconz docs)
Ring - All Ring accounts require two-factor authentication. This means that it is no longer possible to configure it via YAML as this cannot support 2FA. - (@balloob - #32039) (ring docs) (breaking change) (beta fix)
Hue - The
filenameoption from the Hue bridge configuration has been deprecated in 0.104 and now removed. - (@frenck - #32027) (hue docs) (breaking change) (beta fix)
Beta Fixes
All changes
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2020/02/26/release-106/
