2020-03-18 23:39:11 WARNING (MainThread) [hacs.deprecated] The '/community_plugin/*' is deprecated and will be removed in an upcomming version of HACS, it has been replaced by '/hacsfiles/*', .....
What exactly do I need to update/fix to get rid of it?
in 107 the resources are not in the lovelace yaml anymore so unclear what you are asking⌠If you use yaml you will edit them in yaml. If you use the GUI you edit the GUI as per the above.
I have resources in both yaml and GUI , I edit via GUI asper above but it doesnât make any change in the yaml and also the same warning message in the log section, do I need to remove the resources from yaml
Yeah⌠Iâm interested in that too.
Why do we need to use aliases instead of real path? Itâs really misleading.
TBH I donât understand the change. âcommunity_pluginâ was as bad as âhacsfilesâ right now. What is the real income of this change?
It isnât referencing the folder - itâs an endpoint and HACS sets the browser to not cache that endpoint. The real directory is /local/community/* Even local is an endpoint/alias for www.
