Looks really great. Love the theme. Looking currently for inspirations
That looks amazing! Could you share your config please?
I’m very jealous that you have a Nest dev account, I’d love to be able to include my Hello on my dashboard.
Thank you, I’ll share it soon. I actually purchased the Nest Hello after the API change was made. I use the badnest integration which doesn’t require a Nest dev account.
Oh my god, thank you. Not just for releasing you config in the future but for letting me know about badnest. I didn’t even know it was a thing!
I don’t understand. Can you explain?
Thanks! That did the trick for me!
Is it possible to use template instead of value
e.g
color_thresholds:
- value: ‘{{ states(’‘sensor.min_kwh_idag’’) | float }}’
color: green - value: ‘{{ states(’‘sensor.max_kwh_idag’’) | float }}’
color: red - value: 21.5
color: “#c0392b”
Please format your pasted code.
It is only possible with something like this:
I’m showing bar charts to track activities like so:
based on these
- platform: history_stats
name: fridge open for
entity_id: binary_sensor.fridge_contact
state: 'on'
type: time
start: '{{ now().replace(hour=0, minute=0, second=0) }}'
end: '{{ now() }}'
name: tv playing for
entity_id: media_player.shieldtv
state: 'playing'
type: time
end: '{{ now() }}'
so that’s great, but when I hover over the far right column (today), it shows the “real” value for how long the TV has been on today:
I can’t sort out the discrepancy.
heres the yaml for the cards
entities:
- entity: sensor.fridge_open_for
name: Fridge Open For
hours_to_show: 168
name: Fridge Door Open
group_by: date
icon: 'mdi:fridge'
show:
fill: fade
state: true
icon: true
graph: bar
type: 'custom:mini-graph-card'
entities:
- entity: sensor.watching_tv_for
hours_to_show: 168
group_by: date
icon: 'mdi:youtube-tv'
show:
fill: fade
state: true
icon: true
graph: bar
Sellerone:
if you put deaths on a different axis you can see the trend more clearly
also if you sort by date it will smooth out the graph significantly:
entities:
- entity: sensor.canada_coronavirus_current
unit: Infected
- entity: sensor.canada_coronavirus_recovered
unit: Recovered
- entity: sensor.canada_coronavirus_deaths
show_state: true
unit: dead
y_axis: secondary
hours_to_show: 168
name: Covid-19 Infections in Canada (7 days)
group_by: date
show:
fill: fade
state: true
Thanks for the suggestion, I changed to the group_by: date (I forgot that), regarding the deaths on a secondary axis I don’t agree too much because, as per you graph, it looks like the deaths are as much as the infectet.
But for the smoothness of it yes, that it is something I wanted to fix but I forgot to change that option, thanks!
I think you need to add “points: false” to the “show:” list if you don’t want to have the “mouse-over” functionality
I’m having a strange problem for the last few versions that I can’t seem to figure out. This code used to work fine:
entities:
- entity: sensor.current_power_use
points_per_hour: 3
unit: W
show:
labels: true
color_thresholds:
- value: 2000
color: '#0FE8DD'
- value: 4000
color: '#65E80F'
- value: 6000
color: '#E8AC0F'
- value: 10000
color: '#E8350F'
Lately though, it gives me this error:
Cannot assign to read only property '0' of object '[object Array]'
I can resolve the error by removing all but one of the color_thresholds:
members.
Any idea what I’m doing wrong?
I have a problem with the group_by: date function. When I want to plot gas consumption for the past 7 days (168 hrs) it always has value ‘0’ for the first day. When I switch to 6 days (144 hrs) I have the same issue.
Am I doing something wrong? This is my configuration:
- type: custom:mini-graph-card
name: Gas (7 days)
icon: mdi:fire
entities:
- entity: sensor.daily_gas
aggregate_func: max
color: "#0da035"
group_by: date
hours_to_show: 168
hour24: true
decimals: 1
animate: true
show:
graph: bar
labels: true
name: Gas (6 days)
icon: mdi:fire
entities:
aggregate_func: max
color: "#0da035"
group_by: date
hours_to_show: 144
hour24: true
decimals: 1
animate: true
show:
graph: bar
labels: true
I have history data retention already set to 8 days but that is not solving it.
recorder:
purge_keep_days: 8
Update the card, HA 0.106.0 introduced a breaking change.
Known issue
D’oh! Thanks for that, I had updated the HACS card, but there was another button to “install” or “deploy” or something like that which I failed to notice at first!
Thanks for putting me straight!
Fantastic addon! I really love how smooth and well everything looks, and it has so much configuration options I have one question that documentation was not able to answer (from my searches). Is it possible to disable title/name change when hovering over measure points? Here is quick example:
I manually assign title of the card/graph but it changes to the sensor name when hovering over data points. I know that that might be the desired behavior but still I would prefer to have control over it and disable this function if possible. Any ideas are welcome
Try to use the same name for your card and your entity:
name: Air Purifier Pro
entities:
- entity: sensor.home_aqi
Maaan! It works! I can’t imagine I didn’t think about something as simple as this:) Thank you
