0.108: Logos, Area Pages, Lovelace Entity Card, Lovelace Map History
yeah, nabucasa user? just connec with local IP
load “cloud” as custom, then it works
Just noticed that, thanks. Also noticed the other replies above stating exactly the same. Apologies.
what does this mean?
download 108.6 from github, extract the folder "cloud’ from the components directory
place that “cloud” folder in your custom_components
if you dont know about customs, its better to rollback :slight_smile:
do you know if someone is working on a fix for that ?
probably, just wait
only if this is reported as an issue on the GitHub repo for core… thanks for doing so :wink:
I have been trying to update for several days now… Same error
I have similar issues from time to time. If you have SSH installed try from CLI.
HA core info
to verify the update
and
HA host reboot
to reboot system
Mine fails to reboot at a minimum of every other time.
I now do the update and reboot from CLI.
I also have the same but where it shows .108.7 installed and the latest as .108.6. I see that .108.8 has just been released, hopefully this fixes the update version issue.
After upate to 0.108.7 HA says: update 0.108.6 available current version 0.108.7
108.7 has been removed due to an issue with the cloud integration. 108.8 will be available soon
Thanks clear
It always does that when the json version file hasn’t updated…
nabucasa fixed in 108.8
This happen to me as well until I disabled Adblock extension in Chrome and then it went through.
I just updated to 108.8 - Notification tab in sidebar shows 1 new notification (number 1 in orange circle) but clicking does nothing! :frowning:
Anyone else found the same?
Attempting to upgrade a Rasp Pi 4 from 108.6 to 108.8. Throws errors:
20-04-22 16:23:45 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.108.8
20-04-22 16:23:45 INFO (SyncWorker_4) [supervisor.docker.interface] Update image homeassistant/raspberrypi4-64-homeassistant:0.108.6 to homeassistant/raspberrypi4-64-homeassistant:0.108.8
20-04-22 16:23:45 INFO (SyncWorker_4) [supervisor.docker.interface] Pull image homeassistant/raspberrypi4-64-homeassistant tag 0.108.8.
20-04-22 16:23:45 ERROR (SyncWorker_4) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi4-64-homeassistant:0.108.8 -> 500 Server Error: Internal Server Error (“readlink /mnt/data/docker/overlay2: invalid argument”).
20-04-22 16:23:45 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
Starting using HA in the last couple of days on the Pi. Otherwise, no issues.
I can’t update 107 and 108 on RPI4 too. HA frontend response - ERR_CONNECTION_REFUSED
Just a quick update on my 0.108.+install.
After I installed 0.108.8 the memory usage shown in the Portainer Container Statistics seem to stabilize around 250MB (plus another 130MB for the cache).
The processor use still seems high at 26-36% while the 15min load hovers at around 1.5 - also still not great, but unlike before the system stays at least usable.
After upgrading to 108.8 my zwave sensors are showing up twice now and the original sensors are no longer updated?
Any help appreciated.
