Same here, and it broke my dashboard on my tablet view
I can’t tell if this means my existing Zwave setup will break when I install or not.
Is the transition to the new Zwave integration optional? Or do I need to plan on completely rebuilding the my Zwave devices, sensors, and automations when I upgrade?
The current built in zwave system isn’t going anywhere right now. Upgrading won’t break your setup.
Yes. No clue what is causing it. Lots of av errors. Running Home Assistant Supervised.
did it ever appear?
Unable to configure GoControl CECOMINOD016164 HUSBZB-1 USB Hub
SOLVED:
You must manually configure Z-Wave first in Configuration.yaml
(it won’t configure via the Integrations GUI) then you can add the Zigbee Home Automation Integration via the Integrations GUI.
I’m attempting to configure my HUSBZB-1 on a brand new install of v0.110.1
Previous install had the following that worked without trouble:
zha:
usb_path: /dev/ttyUSB1
database_path: /home/homeassistant/.homeassistant/zigbee.db
When attempting to connect using serial device path from my previous Configuration.yaml
I receive an error:
I’ve also attempted using the full device path:
Changing to ttyUSB1
and /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_81300EA4-if00-port0
had no affect.
Has anybody had success added the HUSBZB-1 through the new Integration UI?
What port speed did you use? I’ve searched online and can’t determine appropriate values for this setting.
Out of curiosity, are you running the RPI3 disk-image installation of Home Assistant?
Am I missing something or we can no longer configure Onvif via yaml ? This breaks our whole cicd promotion pipeline. We better wait for a fix before updating prods environnements.
I believe the fix for the hue tap devices (and potentially others mistakenly cleaned up by the device clearup routine) is in the 0.110.2 fix. I’m awaiting that to be released to confirm.
Picture entity cards no longer seem to be reporting their correct height and end up in one long column.
Possibly something to do with the time it takes to load the picture as a subsequent revisit to the view displays the cards correctly.
The /community_plugin/ bit in the resource folder isn’t working for my custom header and auto-entities installs. I had to point to the local www folder directory direction (https://xxxx.duckdns.org/local/community/lovelace-auto-entities/auto-entities.js
It is not community_plugin anymore. The endpoint is hacsfiles not community_plugin now (and for some time)
I don’t use this integration, but the docs of the intrgration say nothing about YAML configuration, so I’d assume you are now only able to configure through the GUI.
If this is true, YAML config will not come back, as you can read in this blogpost, the future for integration config is UI based and YAML is slowly removed. The devs promised that automations, etc. will stay in YAML, but to be honest, after all the decisions they took recently, I don’t believe anything they say anymore.
First release I had to back out of, due to breaking changes on missing icons.
Little cuts and little lies!
Never did see this before: Home Assistant made a booboo and left a core dump…
And it keeps appearing after the av/* stuff I already replied on earlier. I truly never ever did see this happen with HA!
2020-05-24 12:05:31 ERROR (SyncWorker_8) [root] Uncaught exception
File "av/container/output.pyx", line 22, in av.container.output.close_output
File "av/container/core.pyx", line 267, in av.container.core.Container.err_check
File "av/error.pyx", line 328, in av.error.err_check
File "av/container/pyio.pyx", line 39, in av.container.pyio.pyio_write_gil
TypeError: 'NoneType' object is not callable
tail: /etc/homeassistant/home-assistant.log: file truncated
And throw in a little censorship…
I thought they would have postponed this kind of silly decisions… Time to leave or time to fork.
Same issue here.
Has anyone filed an issue already?
I’m a little embarassed to say that having said (on numerous occasions) that I will not be moving forward with new releases here I have in fact done so and (surprise, surprise) I found that (for my config) this release is proving to be (by far) the best release I have moved to since leaving 0.94.2.
I approached this upgrade from a totally different direction than my usual method. Initially I was just interested to see what a new install from scratch was like really and I had no intention of moving my config across. So, I set this up as a brand new docker with a blank /config folder. After the onboarding I switched the new container to a different port so it could run along with my production system (running 0.107.7) on the same network.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
http:
server_port: 8125
# Text to speech
tts:
- platform: google_translate
lovelace:
mode: yaml
arch x86_64 dev false docker true hassio false installation_type Home Assistant Core on Docker os_name Linux os_version 4.2.8 python_version 3.7.7 timezone Australia/Brisbane version 0.110.1 virtualenv false
Once I was satisfied how well it was running I installed a couple of the minor built-in UI installed integrations and let it run for a few days. It ended up running so well I edited the config.yaml to enable lovelace and added my full (unedited) ui-lovelace.yaml and checked how that went.
No problems with all the views except no entities were available due to the config being unpopulated with my config at that time.
So…with my interest pricked I just added my complete config (and a few other required folders)…restarted my container and with great surprise I found literally everything worked with minimal errors and warnings in the log.
The only errors pertained to the one and only ‘custom_component’ I run and that is the safepay Fronius Component.
These errors have existed since 0.107.7 and pertain to not generating unique ID’s.
## Log Details (ERROR)
Logger: homeassistant.components.sensor
Source: helpers/entity_platform.py:436
Integration: Sensor ([documentation](https://www.home-assistant.io/integrations/sensor), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+sensor%22))
First occurred: 7:15:11 PM (9 occurrences)
Last logged: 7:15:11 PM
* Entity id already exists - ignoring: sensor.fronius_ac_current. Platform fronius_inverter does not generate unique IDs
* Entity id already exists - ignoring: sensor.fronius_ac_voltage. Platform fronius_inverter does not generate unique IDs
* Entity id already exists - ignoring: sensor.fronius_ac_frequency. Platform fronius_inverter does not generate unique IDs
* Entity id already exists - ignoring: sensor.fronius_dc_current. Platform fronius_inverter does not generate unique IDs
* Entity id already exists - ignoring: sensor.fronius_dc_voltage. Platform fronius_inverter does not generate unique IDs
So its now been about 5 days and I can not fault how this release is running so ‘hats off’ to all who had anything to do with it really.
I would like to ask the developers to please consider halting the removal of YAML as for me the total removal of YAML functionality would be a dealbreaker to me moving further forward with new releases.
Failing that I would ask you to consider ensuring that Nabu Casa remains 100% compatible with ALL releases back to say 0.90.xx as it seems clear to me that a great many users are still running installations at least back to there. No doubt many of those may also be using Nabu Casa as well?
If at all possible could the quality and quantity of communication between developers and the wider user base be improved significantly as right now it is at an unsustainably low level IMHO.
If you must continue to remove YAML functionality I personally will stop on whatever release suits my purposes best. In fact I am right now working on finding the best place to dig in.
That is of course UNLESS you remove Nabu Casa backwards compatibility as at that point I will totally abandon this project.
Thanks for listening!
