0.110: Speed! OpenZWave beta, HomeKit Cameras, ONVIF, Calendars
The following integrations and platforms could not be set up:
automation
Please check your config.
I get this error now. Automations hasn’t change reverted back with the same automation file back to 0.110.1 and it works fine
if using packages you need to check them
Upgraded from .109 and have several issues when booting. Here are the specifics:
Running Ubuntu 20.04 and Homeassistant supervised for generic Linux in Docker.
Had no errors in log before the upgrade.
After upgrading I get the following Notification:
Invalid config
recorder
history
logbook
default_config
Log has many errors regarding websocket. Portion below:
20-05-23 03:00:41 ERROR (MainThread) [supervisor.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
20-05-23 03:00:46 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
20-05-23 03:00:46 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
20-05-23 03:00:46 ERROR (MainThread) [supervisor.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
20-05-23 03:00:51 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
20-05-23 03:00:51 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
20-05-23 03:00:51 ERROR (MainThread) [supervisor.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
20-05-23 03:00:56 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
20-05-23 03:00:56 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
20-05-23 03:00:56 ERROR (MainThread) [supervisor.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
20-05-23 03:01:01 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
20-05-23 03:01:01 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
20-05-23 03:01:01 ERROR (MainThread) [supervisor.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
20-05-23 03:01:06 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
20-05-23 03:01:06 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
20-05-23 03:01:06 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
20-05-23 03:01:08 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-05-23 03:03:42 INFO (SyncWorker_19) [supervisor.docker.interface] Stop addon_a0d7b954_nodered application
20-05-23 03:03:42 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
20-05-23 03:03:46 INFO (SyncWorker_19) [supervisor.docker.interface] Clean addon_a0d7b954_nodered application
20-05-23 03:04:00 INFO (SyncWorker_17) [supervisor.docker.interface] Restart homeassistant/qemux86-64-homeassistant
20-05-23 03:04:47 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-05-23 03:09:14 INFO (SyncWorker_16) [supervisor.docker.interface] Restart homeassistant/qemux86-64-homeassistant
20-05-23 03:10:02 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-05-23 03:10:34 INFO (SyncWorker_6) [supervisor.docker.interface] Remove image hassioaddons/node-red-amd64 with latest and 6.2.0
20-05-23 03:10:35 INFO (MainThread) [supervisor.addons.addon] Remove add-on data folder /data/addons/data/a0d7b954_nodered
20-05-23 03:10:35 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-05-23 03:10:35 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for a0d7b954_nodered
20-05-23 03:10:35 INFO (MainThread) [supervisor.addons] Add-on 'a0d7b954_nodered' successfully removed
20-05-23 03:11:05 INFO (SyncWorker_5) [supervisor.docker.interface] Restart homeassistant/qemux86-64-homeassistant
20-05-23 03:11:53 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
Any hints would be appreciated.
Frank
Have you done a restart since update?
bug in 0.110.0 and 0.110.1 - there is a fix coming.
Thank you, will keep that in mind for the future. I got mine up and running after restoring snapshot. Although I never understood why they deprecated docker installation method for “Home Assistant Supervised
My Home-assistal.log file is full with these lines:
2020-05-23 08:30:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 111, in _handle_refresh_interval
    await self.async_refresh()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 177, in async_refresh
    update_callback()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 297, in async_write_ha_state
    self._async_write_ha_state()  # type: ignore
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 320, in _async_write_ha_state
    state = self.state
  File "/usr/src/homeassistant/homeassistant/components/upnp/sensor.py", line 201, in state
    return format(value, "d")
TypeError: unsupported format string passed to NoneType.__format__
It found two upnp devices after upgrade:
  1. ExperiaBox-V10
  2. GS908E
Looks like theses errors are coming from them.
[edit]
Removing both integrations, removed the errors from the log
[/edit]
Glances can also not be ignored
Thanks for the update.
I have this problem on large numbers.
Thanks.
Schermata 2020-05-23 alle 11.17.38
Schermata 2020-05-23 alle 11.22.26
502 or 504? Just ignore it and wait. I get that and it still does the updates OK. Takes a while so go make a cuppa.
No, it is not. Do you see any error messages in the logs?
My upgrade is keep rollbacking :frowning:
20-05-23 09:48:20 INFO (MainThread) [supervisor.host.info] Update local host information
20-05-23 09:48:20 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-05-23 09:48:21 INFO (MainThread) [supervisor.host.services] Update service information
20-05-23 09:48:21 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-05-23 09:48:22 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-05-23 09:48:22 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-05-23 09:48:22 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
Failed to load cookie file from cookie: No such file or directory
20-05-23 10:13:42 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.110.1
20-05-23 10:13:43 INFO (SyncWorker_13) [supervisor.docker.interface] Update image homeassistant/raspberrypi3-64-homeassistant:0.109.6 to homeassistant/raspberrypi3-64-homeassistant:0.110.1
20-05-23 10:13:43 INFO (SyncWorker_13) [supervisor.docker.interface] Pull image homeassistant/raspberrypi3-64-homeassistant tag 0.110.1.
20-05-23 10:18:16 INFO (SyncWorker_13) [supervisor.docker.interface] Stop homeassistant application
20-05-23 10:19:18 INFO (SyncWorker_13) [supervisor.docker.interface] Clean homeassistant application
20-05-23 10:19:18 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-05-23 10:19:19 INFO (SyncWorker_16) [supervisor.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-64-homeassistant with version 0.110.1
20-05-23 10:19:49 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-05-23 10:20:44 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-05-23 10:21:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-05-23 10:21:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-05-23 10:21:43 INFO (MainThread) [supervisor.store] Load add-ons from store: 65 all - 0 new - 0 remove
20-05-23 10:30:48 WARNING (MainThread) [supervisor.homeassistant] Don't wait anymore of Home Assistant startup!
20-05-23 10:30:48 CRITICAL (MainThread) [supervisor.homeassistant] HomeAssistant update fails -> rollback!
20-05-23 10:30:48 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.109.6
20-05-23 10:30:48 INFO (SyncWorker_18) [supervisor.docker.interface] Update image homeassistant/raspberrypi3-64-homeassistant:0.110.1 to homeassistant/raspberrypi3-64-homeassistant:0.109.6
20-05-23 10:30:48 INFO (SyncWorker_18) [supervisor.docker.interface] Pull image homeassistant/raspberrypi3-64-homeassistant tag 0.109.6.
20-05-23 10:30:49 INFO (SyncWorker_18) [supervisor.docker.interface] Stop homeassistant application
20-05-23 10:30:53 INFO (SyncWorker_18) [supervisor.docker.interface] Clean homeassistant application
20-05-23 10:30:54 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-05-23 10:30:55 INFO (SyncWorker_14) [supervisor.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-64-homeassistant with version 0.109.6
20-05-23 10:31:25 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-05-23 10:32:20 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-05-23 10:33:40 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-05-23 10:33:40 INFO (MainThread) [supervisor.homeassistant] Successful run Home Assistant 0.109.6
20-05-23 10:33:40 INFO (SyncWorker_14) [supervisor.docker.interface] Cleanup images: ['homeassistant/raspberrypi3-64-homeassistant:0.110.1']
Great update overall!
Only issue was that it broke my COVID-19 integration, I tried re-adding it and any attempt to do so leads to this error:
Logger: aiohttp.server
Source: components/coronavirus/config_flow.py:30
First occurred: 1:48:09 PM (4 occurrences)
Last logged: 1:49:44 PM
Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 73, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 125, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 112, in post
    return await super().post(request)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 54, in wrapper
    result = await method(view, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 72, in post
    "show_advanced_options": data["show_advanced_options"],
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 129, in async_init
    flow, flow.init_step, data, init_done
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 201, in _async_handle_step
    result: Dict = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/coronavirus/config_flow.py", line 30, in async_step_user
    coordinator.data.values(), key=lambda case: case.country
AttributeError: 'NoneType' object has no attribute 'values'
Similar problem, all of my Font Awesome icons are missing in .110.1.
Anyone know of a fix?
Facing the same issue. The minor update did not fix the issue.
Also on a side note, on Tuya my Fan which is in my Tuya app does not appear on HA. Is anyone else facing the issue?
Same issue for me. The Lovelace bar disappears after half a second
Anyone is having random restarts in 0.110 with this in logs:
2020-05-23 13:00:42 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=13 from 2020-05-23 10:56:56.587616)
In 0.109.6 everything was working just fine… :frowning:
I am running it on Raspberry Pi 4. I got HACS fixed by deleting the HACS folder from the custom_components and replacing with the latest release from the HACS repo
Yes. Several.
Re: hue tap devices disappearing;
I logged https://github.com/home-assistant/core/issues/36030 and should be fixed under https://github.com/home-assistant/core/pull/35977
