I just wanted to say that I upgraded to this version and I am really loving how this project is coming along. All of these little things like the calendar being redone and the user friendliness in the UI is greatly appreciated!
Now I set the name to “Rundum”, host to “192.168.178.32”, port to “5000”, username to the same username, password to the same password, extra options to: “-rtsp_flags none -rtsp_transport udp -q:v 2” and transport to “udp”.
But it doesn’t work!
Might have nothing to do with 110, but since I wanted to use openzwave (beta) I uninstalled zwave2mqtt add-on but the left menu item is not going away. Any hint?
Invalid config for [alarm_control_panel.manual]: [arming_time] is an invalid option for [alarm_control_panel.manual]. Check: alarm_control_panel.manual->triggered->arming_time. (See ?, line ?).
Invalid config for [http]: [external_url] is an invalid option for [http]. Check: http->http->external_url. (See /config/configuration.yaml, line 4).
Have or haven’t these functions been updated correctly?
For the new Tuya integration from the yaml … I’m clicking the integration for Tuya but not getting any action or result. I have tried with the exisiting Tuya yaml code in config (username etc) and with that deleted. Same thing. No install of the integration.
This update looks great, thank you devs for all of your hard work! I’m particularly excited about the not condition, it’s a small thing but it will allow me to convert a few automatons with template conditions to the automation editor.
Can someone please elaborate on what the benefits of the new openzwave platform are or will be? I’m using the current z-wave integration, so I’ll probably migrate once there’s an easy path and a compelling reason to do so (e.g. When it is indeed deprecated in a year )
I have been a user since 0.17. I have seen this break so many times when major updates happen. I completely appreciate the work that goes in this but I sometimes feel they rush releases. My frustrations come out in my reposnses because I rely on Home Automation too much and it stresses me when it’s down. It’s my fault. I will turn off watchtower because I cannot control my environment with it turned on and surprising me with an update. I need a production and testing server though but my point is I shouldn’t really.
