was using it, removed it and restarted but no change.
expand the all changes at the bottom of blog. there are a number of squeezebox changes
Cleared browser cache?
Thanks for this new release.
@ludeeus I know that it is a detail but I find that the updates from supervisor has a lack of visibility/readability. Could you make a full blue background instead of this little line ?
What happens is arming_time is set to 0 in Manual Alarm Panel?
Does the state go directly from armed_away to triggered?
Same for me with alarm_control_panel not working.
I read this and configured it like it is shown there!
Make a detailed Feature request on GitHub.
If you need inspiration look at the feature requests by @SeanM
https://github.com/home-assistant/frontend/issues?q=is%3Aissue+is%3Aopen+label%3A"feature+request"+author%3ASeanPM5
I will, thanks !
Thanks for the new release!
The ONVIF integration works great when adding the first camera, when adding the second (and onwards) camera all is fine but in the log the following shows up:
2020-05-20 13:06:55 WARNING (Thread-362) [daemon] could not find handler for: _handle_probe
Thanks to all devs that has been working hard on this! <3
(Edited)
Same issue here, using Docker. Updated, but the setup never completes and never starts listening on 8123. Logs:
Attaching to home-assistant
home-assistant | [s6-init] making user provided files available at /var/run/s6/etc...exited 0.
home-assistant | [s6-init] ensuring user provided files have correct perms...exited 0.
home-assistant | [fix-attrs.d] applying ownership & permissions fixes...
home-assistant | [fix-attrs.d] done.
home-assistant | [cont-init.d] executing container initialization scripts...
home-assistant | [cont-init.d] udev.sh: executing...
home-assistant | starting version 3.2.9
home-assistant | [13:54:08] INFO: Update udev information
home-assistant | [cont-init.d] udev.sh: exited 0.
home-assistant | [cont-init.d] done.
home-assistant | [services.d] starting services
home-assistant | [services.d] done.
home-assistant | 2020-05-20 13:54:10 INFO (MainThread) [homeassistant.bootstrap] Config directory: /config
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_0) [homeassistant.loader] Loaded hacs from custom_components.hacs
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_5) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_1) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
home-assistant | 2020-05-20 13:54:10 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
home-assistant | 2020-05-20 13:54:10 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
home-assistant | 2020-05-20 13:54:10 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
home-assistant | 2020-05-20 13:54:10 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_10) [homeassistant.loader] Loaded upnp from homeassistant.components.upnp
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_13) [homeassistant.loader] Loaded stream from homeassistant.components.stream
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_8) [homeassistant.loader] Loaded logger from homeassistant.components.logger
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_11) [homeassistant.loader] Loaded digital_ocean from homeassistant.components.digital_ocean
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_2) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_12) [homeassistant.loader] Loaded updater from homeassistant.components.updater
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_15) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_14) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_19) [homeassistant.loader] Loaded smartthings from homeassistant.components.smartthings
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_16) [homeassistant.loader] Loaded spotify from homeassistant.components.spotify
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_17) [homeassistant.loader] Loaded timer from homeassistant.components.timer
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_20) [homeassistant.loader] Loaded rest_command from homeassistant.components.rest_command
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_21) [homeassistant.loader] Loaded automation from homeassistant.components.automation
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_18) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_23) [homeassistant.loader] Loaded met from homeassistant.components.met
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_25) [homeassistant.loader] Loaded ifttt from homeassistant.components.ifttt
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_26) [homeassistant.loader] Loaded image_processing from homeassistant.components.image_processing
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_22) [homeassistant.loader] Loaded weather from homeassistant.components.weather
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_24) [homeassistant.loader] Loaded script from homeassistant.components.script
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_27) [homeassistant.loader] Loaded tts from homeassistant.components.tts
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_28) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_31) [homeassistant.loader] Loaded ipp from homeassistant.components.ipp
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_30) [homeassistant.loader] Loaded climate from homeassistant.components.climate
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_0) [homeassistant.loader] Loaded scene from homeassistant.components.scene
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_10) [homeassistant.loader] Loaded esphome from homeassistant.components.esphome
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_33) [homeassistant.loader] Loaded camera from homeassistant.components.camera
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_37) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_9) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_35) [homeassistant.loader] Loaded duckdns from homeassistant.components.duckdns
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_34) [homeassistant.loader] Loaded zone from homeassistant.components.zone
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_38) [homeassistant.loader] Loaded emulated_hue from homeassistant.components.emulated_hue
home-assistant | 2020-05-20 13:54:10 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_3) [homeassistant.loader] Loaded alert from homeassistant.components.alert
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_14) [homeassistant.loader] Loaded coronavirus from homeassistant.components.coronavirus
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_15) [homeassistant.loader] Loaded nest from homeassistant.components.nest
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_19) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_6) [homeassistant.loader] Loaded config from homeassistant.components.config
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_28) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_24) [homeassistant.loader] Loaded vacuum from homeassistant.components.vacuum
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_17) [homeassistant.loader] Loaded intent_script from homeassistant.components.intent_script
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_16) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_1) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_29) [homeassistant.loader] Loaded proximity from homeassistant.components.proximity
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_20) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_14) [homeassistant.loader] Loaded light from homeassistant.components.light
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_7) [homeassistant.loader] Loaded speedtestdotnet from homeassistant.components.speedtestdotnet
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_19) [homeassistant.loader] Loaded shell_command from homeassistant.components.shell_command
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_15) [homeassistant.loader] Loaded person from homeassistant.components.person
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_32) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_21) [homeassistant.loader] Loaded map from homeassistant.components.map
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_4) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_11) [homeassistant.loader] Loaded dialogflow from homeassistant.components.dialogflow
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_8) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_23) [homeassistant.loader] Loaded http from homeassistant.components.http
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_6) [homeassistant.loader] Loaded plant from homeassistant.components.plant
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_25) [homeassistant.loader] Loaded history from homeassistant.components.history
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_13) [homeassistant.loader] Loaded cast from homeassistant.components.cast
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_28) [homeassistant.loader] Loaded octoprint from homeassistant.components.octoprint
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_24) [homeassistant.loader] Loaded sun from homeassistant.components.sun
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_17) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_16) [homeassistant.loader] Loaded alarm_control_panel from homeassistant.components.alarm_control_panel
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_36) [homeassistant.loader] Loaded notify from homeassistant.components.notify
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_2) [homeassistant.loader] Loaded media_extractor from homeassistant.components.media_extractor
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_18) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_29) [homeassistant.loader] Loaded xiaomi_aqara from homeassistant.components.xiaomi_aqara
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_22) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_26) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_39) [homeassistant.loader] Loaded google from homeassistant.components.google
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_1) [homeassistant.loader] Loaded switch from homeassistant.components.switch
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_12) [homeassistant.loader] Loaded group from homeassistant.components.group
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_20) [homeassistant.loader] Loaded netatmo from homeassistant.components.netatmo
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_14) [homeassistant.loader] Loaded owntracks from homeassistant.components.owntracks
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_27) [homeassistant.loader] Loaded telegram_bot from homeassistant.components.telegram_bot
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_0) [homeassistant.loader] Loaded panel_iframe from homeassistant.components.panel_iframe
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_31) [homeassistant.loader] Loaded tplink from homeassistant.components.tplink
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_30) [homeassistant.loader] Loaded asuswrt from homeassistant.components.asuswrt
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_5) [homeassistant.loader] Loaded hue from homeassistant.components.hue
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_10) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_7) [homeassistant.loader] Loaded api from homeassistant.components.api
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_37) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_35) [homeassistant.loader] Loaded auth from homeassistant.components.auth
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_34) [homeassistant.loader] Loaded device_automation from homeassistant.components.device_automation
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_19) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
home-assistant | 2020-05-20 13:54:10 INFO (SyncWorker_15) [homeassistant.loader] Loaded search from homeassistant.components.search
home-assistant | 2020-05-20 13:54:10 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log', 'logger'}
home-assistant | 2020-05-20 13:54:10 INFO (MainThread) [homeassistant.setup] Setting up logger
home-assistant | 2020-05-20 13:54:10 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=98 from 2020-05-20 12:51:49)
home-assistant | 2020-05-20 13:54:13 WARNING (MainThread) [homeassistant.components.template] Template sensor 'race_deadline_day' has no entity ids configured to track nor were we able to extract the entities to track from the value template(s). This entity will only be able to be updated manually.
home-assistant | 2020-05-20 13:54:22 WARNING (MainThread) [homeassistant.components.vacuum] Setup of vacuum platform xiaomi_miio is taking over 10 seconds.
And then absolutely nothing else after that.
If you are so reliant on Home Assistant, maybe it is better not to upgrade to a x.0 release the same day it is released. Better waiting a couple of days and check if a bug slipped over.
Even huge corporates like Apple with thousands of testers sometimes have troubles on major releases.
I did from command line, first:
ha host shutdown. I waited until I could not ping it anymore and shut it off and back on.
Came up fine after. No errors in log
Like I said I had Watchtower running. I am going to turn it off. It kills me when this happens.
Regarding the ZHA config move to the UI: Will we be able to still use the “device_config:” setting for ZHA? Will that be added to the UI or will that stay in YAML? I use it to cast some ZHA devices that show up as switches to lights, so dimming controls work.
For those who have issues: for me Spotify and joao_join seemed to hang somewhere and prevented HA from starting it’s webserver. Without those two the rest seems to work fine for me.
I’ll investigate further and open a GitHub issue tonight unless someone beats me to it
something about date/time in that log snippet, is the date/time correctly set on the camera?
it may need to be in near sync with your HA host, if it is i suggest logging a github issue
Is this a frontend issue, OS issue or something else? How would I know?
log it in main github repository and the devs should move it if considered incorrectly filed to the correct place they believe it should be
@heartkingz I don’t know if this is for my comment, but I KNOW how much work is needed, I’m a developer in real life too, but I don’t have more information to share with the developers. The logs didn’t show any error.
I only added my message here searching for others with the same problem to see if someone has some idea of what can be wrong or someone smarter than me fixed it in some way.
Thanks to all the developers of this great software. My message was not a blame to them, only let them know that there is some problem at some place.
