I am having some problems with sonarr which I have set up via YAML. The documentation for Sonarr set up no longer mentions YAML set up.
I see that it’s now possible via UI, but would prefer to keep it via YAML where possible. Has this option been removed? If so, should it be mentioned as a breaking change?
Sonarr is only via GUI now. No YAML. It would have been automatically migrated except they renamed one of the sensors and none of them are enabled by default - you need to manually enable the entities. Yes I reported this in the beta but no one cared. Yes it was/should have been a breaking change and I did point it out.
My setup notified me on possible update from 0.111.1 to 0.111.2. After I start update, there is an error:
Error: 504 Gateway Time-out
nginx/1.14.0 (Ubuntu)
and in log I can see:
ERROR (SyncWorker_0) [supervisor.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.111.2 → 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.111.2: No such image: homeassistant/qemux86-64-homeassistant:0.111.2”).
Previous updates went without problem.
Have anyone encountered such problem?
My setup is ubuntu 18.04 on NUC, and HA runs as virtual machine in virtualbox.
Netmo integration stopped to work:
– All of my Netatmo sensors were gone (even from states view), like no integration configured. In logs only information about integration startup time exceeding 10 secs.
– After restart sensors are back in states view, but reporting any values (unavailable). Same error in logs:
2020-06-14 11:48:26 WARNING (MainThread) [homeassistant.components.climate] Setup of climate platform netatmo is taking over 10 seconds.
2020-06-14 11:48:26 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform netatmo is taking over 10 seconds.
Another, quite serious issue is that all my system history is gone. HA seems to remeber only events and states from recent restart (kept in memory, localy cached)? No history from MariaDB on my NAS is available. Not sure what to look for in log files to troubleshoot, just reviewing these I found no errors related to recorder…
EDIT: just checked Db using phpMy Admin and seems that last entries (states, events) were recorded just before installation of update. So somehow my HA got disconnected from DB.
@tom_l, not sure which release note are you referring to… Up to 0.111.1 everything was fine and for 0.111.2 the only DB relates change is: Fix history timezone with postgres and other dbs.
However issue mentioned is described as:
non breaking - it broke my history entirely
related to timestamps - so to my understanding it shoul eventually ‘shift’ reported times
I see some issue reported with the fix is it broke graphs/charts for MariaDB users… but in my case indeed there is no history displayed, but also there is no new history recorded in MariaDB.
@francisp Thanks. I was thinking that could be the problem.
I can see the image is available from docker hub (pulled without problem using some other docker installation), but image is almost the size of space left on VM.
Could you direct me to some instructions on growing vbox image? I would like not to damage my Hass OS setup
Also, are there any recommendations for disk usage maintenance, like removing/archiving old logs and so on?
I just thought I’d point out that for some people
"Fix command line sensors removing quotes with template ([@shenxn]- [#35559]) "
Is a breaking change, and should have been labelled as such.
If you were using \" in order to use quotes, then this change breaks it.
I had a number of command line sensors using curl that all broke as a result - no big deal, but it helps to know
Yes, don’t worry about the vacuum cleaner link. Its because the vacuum cleaner has had this method to get the token for a long time now. The integration config flow is correct and we just need to follow what it says to do.
When you see a breaking change get missed like this the most helpful thing you can do is update the blog post and mention this. Anyone can go on github and submit a quick update for this. Sometimes things slip through the cracks and we need to help identify that.
Next time that happens just submit an update to the blog post calling it out. I submitted an update to add Sonarr to the config flow but forgot about the breaking change part.
Same for me, checked the hardware list from the Supervisor/System page and it wasn’t there. Quick shutdown of VM, replugged the dongle on host to be sure and all is fine again.
I lost my Tibber Pulse (consumption, volt etc) after upgrading to 0-111-0.
[sensor.electricity_price_xxxxx] worked OK, but
[sensor.real_time_consumption_xxxxx] was Unavailable
Downgraded to 0-110-x and both were back OK.
Upgraded to 0-111-2 again today and consumption gone again.
Anyone using Tibber Pulse without problems in 0-111-x?
Not only is Wemo discovery broken. Even if you change to Static discovery and add the devices, when the devices are toggled on lovelace to on, the wemo device would turn on but the toggle on the lovelace ui will auto toggle off instantly for a few seconds before the ui is switched to on again
Since upgrading from 0.110.x to 0.111.x (currently on 0.111.2) I now get an error setting up panel_custom.
Log Details (ERROR)
Logger: homeassistant.setup
Source: components/http/init.py:376
First occurred: 14 June 2020, 11:23:01 (1 occurrences)
Last logged: 14 June 2020, 11:23:01
Error during setup of component panel_custom
File “/usr/src/homeassistant/homeassistant/setup.py”, line 190, in _async_setup_component
result = await asyncio.wait_for(task, SLOW_SETUP_MAX_WAIT)
File “/usr/local/lib/python3.7/asyncio/tasks.py”, line 442, in wait_for
return fut.result()
File “/usr/src/homeassistant/homeassistant/components/panel_custom/init.py”, line 180, in async_setup
hass.http.register_static_path(url, panel_path)
File “/usr/src/homeassistant/homeassistant/components/http/init.py”, line 376, in register_static_path
self.app.router.add_route(“GET”, url_path, serve_file)
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_urldispatcher.py”, line 1036, in add_route
expect_handler=expect_handler)
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_urldispatcher.py”, line 308, in add_route
“registered”.format(route=route_obj))
RuntimeError: Added route will never be executed, method GET is already registered
Discovery is acting weird but I have no way to show it since after switching to static discovery everything worked ( discovery wise) however the of behavior i was talking about is hard to describe so i posted an unlisted youtube video on it. https://youtu.be/Ixk68waLWy0
As you can see in the video, the wemo switch automatically turns off after i turn it on. The “desk” device does turn on btw its jsut the switch toggles itself back to off ( the light stays on). Then after a while it toggles to on again matching the true status of the light.
Side note: turning a device off doesn’t not produce the same effect. it is just for turning wemo devices on. also i found a github thread on this as well https://github.com/home-assistant/core/issues/36632
