Same issue with different package after adding the first one:
Sep 20 14:49:32 RPiSmartHome systemd[1]: Started Home Assistant.
Sep 20 14:49:36 RPiSmartHome hass[29116]: 2020-09-20 14:49:36 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for fasthue which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
Sep 20 14:49:36 RPiSmartHome hass[29116]: 2020-09-20 14:49:36 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
Sep 20 14:50:26 RPiSmartHome hass[29116]: 2020-09-20 14:50:26 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Unable to import component: libtiff.so.5: cannot open shared object file: No such file or directory
Sep 20 14:50:26 RPiSmartHome hass[29116]: 2020-09-20 14:50:26 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
Sep 20 14:50:26 RPiSmartHome hass[29116]: 2020-09-20 14:50:26 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
Sep 20 14:50:26 RPiSmartHome hass[29116]: 2020-09-20 14:50:26 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: person
Sep 20 14:50:26 RPiSmartHome hass[29116]: 2020-09-20 14:50:26 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
Sep 20 14:50:26 RPiSmartHome hass[29116]: 2020-09-20 14:50:26 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
Sep 20 14:50:26 RPiSmartHome hass[29116]: 2020-09-20 14:50:26 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
Sep 20 14:50:58 RPiSmartHome hass[29116]: 2020-09-20 14:50:58 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend
Sep 20 14:50:58 RPiSmartHome hass[29116]: 2020-09-20 14:50:58 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
Sep 20 14:50:58 RPiSmartHome hass[29116]: 2020-09-20 14:50:58 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
Sep 20 14:50:58 RPiSmartHome hass[29116]: 2020-09-20 14:50:58 ERROR (MainThread) [homeassistant.setup] Setup failed for map: Could not set up all dependencies.
Sep 20 14:50:58 RPiSmartHome hass[29116]: 2020-09-20 14:50:58 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of hacs. Setup failed for dependencies: frontend
Sep 20 14:50:58 RPiSmartHome hass[29116]: 2020-09-20 14:50:58 ERROR (MainThread) [homeassistant.setup] Setup failed for hacs: Could not set up all dependencies.
Sep 20 14:51:30 RPiSmartHome hass[29116]: 2020-09-20 14:51:30 ERROR (MainThread) [homeassistant.components.weather] The openweathermap platform for the weather integration does not support platform setup. Please remove it from your config.
Sep 20 14:52:52 RPiSmartHome hass[29116]: 2020-09-20 14:52:52 WARNING (SyncWorker_46) [pyhomematic._hm] Failed to initialize proxy for homeassistant-wireless
Sep 20 14:52:57 RPiSmartHome hass[29116]: 2020-09-20 14:52:57 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: synology_dsm
Sep 20 14:53:23 RPiSmartHome hass[29116]: 2020-09-20 14:53:23 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: person
Sep 20 14:53:23 RPiSmartHome hass[29116]: 2020-09-20 14:53:23 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: Could not set up all dependencies.
Sep 20 14:53:23 RPiSmartHome hass[29116]: 2020-09-20 14:53:23 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: frontend, logbook, map, mobile_app, person
Sep 20 14:53:23 RPiSmartHome hass[29116]: 2020-09-20 14:53:23 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
Sep 20 14:54:00 RPiSmartHome hass[29116]: 2020-09-20 14:54:00 WARNING (MainThread) [custom_components.fasthue.sensor] sensor.hue_polling_interval: Modifying the scan_interval from 0:00:05 to 0:00:01
Sep 20 14:54:00 RPiSmartHome hass[29116]: 2020-09-20 14:54:00 WARNING (MainThread) [custom_components.fasthue.sensor] sensor.hue_polling_interval: Added to HASS with update interval: 0:00:01
Sep 20 14:54:09 RPiSmartHome hass[29116]: 2020-09-20 14:54:09 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform mvglive is taking over 10 seconds.
Sep 20 14:54:13 RPiSmartHome hass[29116]: 2020-09-20 14:54:13 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating safe mode
Sep 20 14:54:13 RPiSmartHome hass[29116]: 2020-09-20 14:54:13 WARNING (SyncWorker_54) [pyhomematic._hm] ServerThread.proxyDeInit: Not performing de-init for homeassistant-wireless
Sep 20 14:54:13 RPiSmartHome hass[29116]: 2020-09-20 14:54:13 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Unable to import component: libtiff.so.5: cannot open shared object file: No such file or directory
Sep 20 14:54:13 RPiSmartHome hass[29116]: 2020-09-20 14:54:13 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
Sep 20 14:54:13 RPiSmartHome hass[29116]: 2020-09-20 14:54:13 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
Sep 20 14:54:13 RPiSmartHome hass[29116]: 2020-09-20 14:54:13 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: person
Sep 20 14:54:13 RPiSmartHome hass[29116]: 2020-09-20 14:54:13 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
Sep 20 14:54:13 RPiSmartHome hass[29116]: 2020-09-20 14:54:13 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
Sep 20 14:54:13 RPiSmartHome hass[29116]: 2020-09-20 14:54:13 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
Sep 20 14:54:14 RPiSmartHome hass[29116]: 2020-09-20 14:54:14 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of safe_mode. Setup failed for dependencies: frontend
Sep 20 14:54:14 RPiSmartHome hass[29116]: 2020-09-20 14:54:14 ERROR (MainThread) [homeassistant.setup] Setup failed for safe_mode: Could not set up all dependencies.
Unfortunately I don’t have much time for testing at the moment, so I’ll give up and stick with 0.113.
I feel your pain. Are you saying you can’t even upgrade because your existing system has this config error? Or these are changes made after upgrading and you just can’t restart?
This is almost certainly a syntax error in the action: of an automation calling a service with data:, correct? Can you grep for “action:” recursively from your config directory? Then narrow down to automations fitting the mold. If it won’t break anything, trigger them manually and see if you throw an error or if the automation succeeds.
If this is from changes made while an instance is running, reload automations first of course.
You could narrow it down to a particular config file by commenting them out one by one and checking config.
Obviously, I’ve never had to do any of the above… but I believe most times I’ve seen issues like this it hasn’t actually been real errors, it’s been indenting.
New user here! I’m using hassio, and have been using linux in general for 25 years.
Thanks for the awesome work. I just started fiddling with the new media browser.
Will there be a way to mount a classic NFS share (typically with music) from inside the container? Maybe by forwarding the volume from the docker host? I guess this will be a popular feature now that media browsing is simpler.
When I have a vague config error like this in an automation that I can’t track down I just restart HA from the CLI (to skip the config check). After it restarts the offending automation will usually show as unavailable in the configuration entities panel (sort them by status) and that is where your problem will be.
Unfortunately, this doesn’t work for scripts because if HA can’t load one script, it won’t load the integration at all.
Jinja2 doesn’t allow curly brackets inside another curly brackets, if i’m not mistaken. (at least if it’s not in quotation marks) That’s probably the reason and then it shouldn’t be that hard to find it.
