0.115: B-Day release! Media browser, tags, automations & WTH
I upgraded to 0.115.4 and my issues are resolved. I coulnā€™t upgrade to 0.115.3 but no issues with 0.115.4
Depends what kind of issues you had. What I described is Broadlink devices not detected in HA with multiple network interfaces. As far as I understand, this was solved in the broadlink library 5 days ago BUT NOT MERGED into 0.115.4ā€¦ which is rather disappointing.
Excelent release filled with lots of goodies. However I believe Amazon Polly integration broke somewhere between 0.115.3 or 0.115.4. Because it was working perfectly on 0.115.2 and on 0.115.4 itā€™s not.
Iā€™m getting this error whenever I call on a service: tts.amazon_polly_say :
2020-09-28 17:10:22 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140658621668560] Invalid MultiSpec data: TextFrame(encoding=<Encoding.UTF8: 3>, text=['Miguel'])
  File "/usr/local/lib/python3.8/site-packages/mutagen/easyid3.py", line 124, in setter
    frame = id3[frameid]
  File "/usr/local/lib/python3.8/site-packages/mutagen/_util.py", line 537, in __getitem__
    return self.__dict[key]
KeyError: 'TPE1'
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 137, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1315, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1350, in _execute_service
    await handler.func(service_call)
  File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 168, in async_say_handle
    url = await tts.async_get_url(
  File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 341, in async_get_url
    filename = await self.async_get_tts_audio(
  File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 368, in async_get_tts_audio
    data = self.write_tags(filename, data, provider, message, language, options)
  File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 471, in write_tags
    tts_file["artist"] = ID3Text(encoding=3, text=artist)
  File "/usr/local/lib/python3.8/site-packages/mutagen/_file.py", line 74, in __setitem__
    self.tags[key] = value
  File "/usr/local/lib/python3.8/site-packages/mutagen/easyid3.py", line 222, in __setitem__
    return func(self.__id3, key, value)
  File "/usr/local/lib/python3.8/site-packages/mutagen/easyid3.py", line 126, in setter
    id3.add(mutagen.id3.Frames[frameid](encoding=3, text=value))
  File "/usr/local/lib/python3.8/site-packages/mutagen/id3/_frames.py", line 65, in __init__
    setattr(self, checker.name,
  File "/usr/local/lib/python3.8/site-packages/mutagen/id3/_frames.py", line 76, in __setattr__
    self._setattr(name, checker.validate(self, value))
  File "/usr/local/lib/python3.8/site-packages/mutagen/id3/_specs.py", line 533, in validate
    raise ValueError('Invalid MultiSpec data: %r' % value)
ValueError: Invalid MultiSpec data: TextFrame(encoding=<Encoding.UTF8: 3>, text=['Miguel'])
2020-09-28 17:10:31 WARNING (MainThread) [homeassistant.components.automation.forced_sensor_updates_ticker_every_1_seconds] Forced Sensor Updates_ticker every 1 seconds: Already running
2020-09-28 17:10:31 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140658621668560] Invalid MultiSpec data: TextFrame(encoding=<Encoding.UTF8: 3>, text=['Miguel'])
KeyError: 'TPE1'
    task.result()
2020-09-28 17:10:56 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140658621668560] Invalid MultiSpec data: TextFrame(encoding=<Encoding.UTF8: 3>, text=['Miguel'])
KeyError: 'TPE1'
    task.result()
2020-09-28 17:11:01 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140658621668560] Invalid MultiSpec data: TextFrame(encoding=<Encoding.UTF8: 3>, text=['Miguel'])
KeyError: 'TPE1'
    task.result()
I tried different known Amazon Polly voices and its the same, upon return to 0.115.2 Amazon_polly_say works as intended.
Anybody else experiencing this?
updating to 115.4 throws completely new errors:
Unexpected error for call_service at pos 8: Invalid MultiSpec data: TextFrame(encoding=<Encoding.UTF8: 3>, text=['nl'])
and
KeyError: 'TPE1'
this seems to be happening when trying to use tts and send a notification to the google Home speakersā€¦ didnt change anything in the scripts, automations or anything else related to the setup.
anyone else seeing this?
edit
@mondomx we cross posted :wink:
and yes 115.3 was still working, so this is definitely from 115.3 to 115.4
well, gotta call it a night, will downgrade to 115.3, and hope to create an issue. Or will you do so?
NM, made it: https://github.com/home-assistant/core/issues/40731
please add to this with your info/issue
Do wish these builds are tested more thoroughly before they are releasedā€¦
Same here. TTS didnā€™t work today using Google Translate Say.
Looks like they are working on the fix for the google cloud fix. Just gotta be patient :slight_smile:
This should be fixed in 0.115.4
  • Pin gRPC to 1.31.0 to workaround amrv7 issues (@frenck - #40678)
Am On 0.115.4
Just as i posted this 0.115.5 came out and the TTS is working again thanks @frenck.
Some observations that I have since 0.115:
  • after each version update initiated under Supervisor in UI I have to reboot, because a lot of sensors remain unavailable
  • the new media library is not working for Sonos. When I click on it I get an (assumed) endless spinner and screen is freezed then, even need to kill and restart the app on iOS
  • broadlink remotes worked after I made the required breaking changes, but now they are not responding anymore Solved this one. Seemed that the remote was turned off , probably a default after restart.
After updating to 115.x Iā€™ve seen a significant increase in CPU usage. Iā€™ve updated to the most recent update (v115.5) and it is still an issue.
It was so bad that Iā€™ve had to downgrade back to v114.2 to fix it.
For anyone experiencing the same issue here is the bug report I just submitted:
if you are experiencing the same thing then please feel free to add your input there.
EDIT:
I didnā€™t know there was already an issue that was still open.
I thought that issue had been closed already. Added my info to that one and closed mine.
Yes. But no info on a sollution.
Motion worked with my camera and suddenly it didnt and ā€œFailed to fetch ONVIF PullPoint subscription messages forā€ started appearing in log.
Has your manufacturer disabled onvif in a firmware upgrade? This seems to be a different error but refers to manufacturers disabling onvif https://github.com/home-assistant/core/issues/37101
please let me ask another thing, since weā€™ve now got the expand() function working very nicely in the new template engine. This new way of templating is proving costly when templates use the {{states|ā€¦}} variants, creating listeners on all states, which are updated constantly. Bdraco is working hard on improving on that.
Yet, Iā€™ve found this related issue, also very costly now, and it has to do with automations using
      platform: event
      event_type: state_changed
also creating listeners on all states.
example:
  - alias: GitHub boolean updates sensor
    id: GitHub boolean updates sensor
#      platform: state
#      entity_id: >
#        {{expand('group.github_repo_updates')|map(attribute='entity_id')|join(',')}}
      platform: event
    condition:
        {{trigger.event.data.entity_id in
            state_attr('group.github_repo_updates','entity_id')}}
the condition checks if the triggering state_change is for one of the input_booleans made for each repo used in the HA instance, which is quite the numberā€¦ so you can imagine I donā€™t like to write them all out individually
In the commented section, Ive illustrated a way to do the same, using the expand() function, if allowed for triggering, (which it nw obviously isnā€™t). very elegant, foolproof, and no further conditions needed. It would need to allow a template for the state trigger. this point work for template trigger, since that needs an evaluation to ā€˜Trueā€™.
long story short: will you allow this to happen, and/or is it already in development. Do think I made a FR earlier, but would gladly do so once more if needed.
btw below the reason for not writing the entities individually:
thanks for having a look if you would.
Awsome update!! Many thanks to all who contributed to it and of course all the historic ones.
This is really a great piece of software. And itā€™s so much fun to spend my time here.
:bouquet: :champagne: :birthday:
any chance of the ping errors are going to be fixed making 0.115 unusable.
Hi All,
I have a button that automatically navigate to the media_browser but i want to know if itā€™s possible to navigate straight into kodi. For example: /media_browser/kodi_player/movies
Is that possible?
If there is an issue posted to GitHub about it, then most likely.
If there is not an issue for it, then most likely not.
After the 115.5 update Onkyo and SamsungTV Tizen show errors
Platform error remote.onkyo - No module named ā€˜homeassistant.components.onkyo.remoteā€™
Platform error remote.samsungtv_tizen - No module named ā€˜custom_components.samsungtv_tizen.remoteā€™
any Idea why??
Is this a custom component? I donā€™t see a integration for onkyo remotes, only the integration for the onkyo receiver.
The SamsungTV Tizen integration is a custom one, you should open a separate topic for this as it is not a problem with Home Assistant Core.
Anyway, do you have the folder ā€œcustom_componentsā€ and the needed files are in there in the folder ā€œsamsungtv_tizenā€?
