0.116: Entities card row editor, restore snapshots and performance metrics
Why not just let your super cheap little RPi be dedicated to HA? What I mean is that they are SO cheap and use such little power that surely you can have a second one for Raspbian to do whatever else it is you want to do…? It will save you a lot of headaches and time wasted when HAOS works very well without jumping through hoops to upgrade.
Care to name some examples?
You can still install Home Assistant in Docker (Home Assistant Container) or Home Assistant Supervised on top of Raspbian.
I don’t know why but, after the update to 0.116, my system monitor gauges stopped working and turned into following yellow background alerts:
  • Entity is non-numeric: sensor.processor_use
  • Entity is non-numeric: sensor.disk_use_percent
  • Entity is non-numeric: sensor.memory_use_percent
Notifications tab reports that:
The following integrations and platforms could not be set up:
  • sensor.systemmonitor
Please check your config.
And my config is:
  - platform: systemmonitor
    resources:
      - type: processor_use
      - type: disk_use_percent
        arg: /
      - type: memory_use_percent
      - type: process
      - type: last_boot
…everything worked perfectly up to release 0.115
Any idea guys?
Solution is here: 0.116: Entities card row editor, restore snapshots and performance metrics - #330 by anon43302295
…and the reason why is here: 0.116: Entities card row editor, restore snapshots and performance metrics - #334 by tom_l
Process requires an argument (for which process to monitor)
Well, not for all the processes (ref. to following specific link and check the table):
systemmonitor
The table lists an argument as mandatory for the process option. You have none.
Oh yes… I’ve misunderstood mf_social reply and I’m very sorry for that.
Problem solved guys.
What I cannot understand is why it stopped working with release 0.116… Is this a brand new requirement?
Thanks for your help.
Cheers
Yes the release notes had this to say:
System Monitor
Not really a breaking change, since the overall logic did not change. Arguments that were previously mandatory for sensors of this integration are still mandatory and optional arguments remain optional.
However, we now enforce those mandatory arguments to be present, since otherwise this integration creates entities that cannot do anything, e.g., the sensor for IPv4 addresses cannot do anything if no network interface is specified from which to take the IP.
If the integration fails to load, check the log to see which arguments are missing in your configuration. The documentation also has been updated to clearly show which arguments are mandatory.
See: 0.116: Entities card row editor, restore snapshots and performance metrics - Home Assistant
Please mark mf’s post as the solution to assist others with this issue when searching.
What did you do exactly. I´m currently stuck here.
If that were the case, i would have several Pi devices - not such a good strategy!
  1. One possibility might be to provide a useful guide for the installation (HA with Python 3.8 and Pi, see Installation - Home Assistant)
  2. We could wait and skip all updates until python 3.8 is deployed with raspberry OS
  3. Best strategy: HA supports python 3.7 until python 3.8 is available with raspberry OS
Btw. will the instructions be updated?
Or
4. Install Home Assistant Container
5. Install Home Assistant Supervised on top of Raspbian
A guide to upgrade is included here 0.116: Entities card row editor, restore snapshots and performance metrics
Perhaps you could put the contents in the community guides section of the forum.
anyone else seeing all Bluetooth devices being not_home only?
have I missed a breaking change anywhere…?
not sure if this happened after updating to 116.xx or supervisor maybe.
2020-10-22 12:33:45 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 177, in update_bluetooth
    await perform_bluetooth_update()
  File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 140, in perform_bluetooth_update
    devices = await hass.async_add_executor_job(discover_devices, device_id)
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 57, in discover_devices
    result = bluetooth.discover_devices(
  File "/usr/local/lib/python3.8/site-packages/bluetooth/bluez.py", line 26, in discover_devices
    device_id = _bt.hci_get_route()
OSError: [Errno 19] No such device
filling the logs
there is a problem with the last HassOs 4.14 that broke the bluetooh on raspberry pi 3 only.
This is fixed in the new version 4.15.
thanks! glad to hear its not me :wink:
dont see the release yet, so guess we’ll have to wait a bit more? or would it be safe to issue a cli command
Have a look here:
But i don’t know how to install in hassio! The upgrade is still not notified to me…
no it’s not there yet:
Schermafbeelding 2020-10-22 om 13.26.22
You should be able to upgrade with:
ha os update --version 4.15
yes I know, but the info shows its not yet available?
Yes because only available for beta user currently
