I just upgraded to 0.39.0. I had to install the following packages manually since they would not load as HA started up.
17-02-25 19:50:15 ERROR (Thread-1) [homeassistant.bootstrap] Not initializing discovery because could not install dependency netdisco==0.8.3
17-02-25 19:53:07 ERROR (Thread-6) [homeassistant.bootstrap] Not initializing wink because could not install dependency pubnubsub-handler==1.0.1
17-02-25 20:06:39 ERROR (Thread-5) [homeassistant.bootstrap] Not initializing zeroconf because could not install dependency zeroconf==0.18.0
17-02-25 20:18:47 ERROR (Thread-5) [homeassistant.bootstrap] Not initializing sensor.systemmonitor because could not install dependency psutil==5.1.3
17-02-25 20:20:27 ERROR (Thread-3) [homeassistant.bootstrap] Not initializing media_player.apple_tv because could not install dependency pyatv==0.1.4
17-02-25 20:20:43 ERROR (Thread-11) [homeassistant.bootstrap] Not initializing media_player.cast because could not install dependency pychromecast==0.8.0
database not ready errors again
install mysqlclient current version
Configuration pages AWESOME!!!
Next feature, add and delete entities in groups (including support for other groups (nested groups))
You renamed the log file from homeassistant.log to home_assistant.log ???
Just created a fresh docker container for version 0.39.0, everything seems to have installed fine:
17-02-26 10:26:22 INFO (Thread-1) [homeassistant.util.package] Attempting install of pychromecast==0.8.0
17-02-26 10:26:34 INFO (MainThread) [homeassistant.bootstrap] Setting up media_player
17-02-26 10:26:34 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.cast
17-02-26 10:26:42 INFO (Thread-3) [pychromecast] Querying device status
I have a separate file cutomize.yaml (i guess a lot do like that otherwise configuration.yaml would be too long)
where i have customized only the entitites like below. And now tih all the globs, e.t.c - quite lost. And the online conversion tool requires different yaml spacing. So converting will need a whole lot of work to do.
binary_sensor.motion_sensor_xxxd0001254xxx:
friendly_name: Movement kitchen
or the z-wave
light.fibaro_system_fgd211_universal_dimmer_500w_level_6_0:
friendly_name: Kitchen Main
assumed_state: false
0.39 broke my Limitless LED setup.
Checked out the Configuration Option and it is heading in the right direction esp the simple buttons to restart the core etc.
The config checker is awesome and saves going online to the YAML Validator.
After playing around with the views things got funky so had to downgrade back to 0.38.3 to get the lights working again.
Having a bit of trouble understanding the customize and group changes. I see that there is a util to convert customize but I don’t know if I get how group works.
It mentions creating an empty groups.yaml, but does it then populate it for you or what?
I haven’t done any changes in my customize configuration since i don’t use domain and global customizations. And I have activated the “config:” since I’m not going to use the gui for configuring anything.
I did the upgrade in my AIO with fab upgrade_homeassistant as usual and now my HA is totally dead. I don’t get anything in the log even with the logger in debug mode.
Looks like I’m going to go offline and image the SD card and then copy over configs before even thinking of upgrading. First time I ever considered not doing an upgrade on release…
Then it is something that everyone that use zwave needs to add and not just the ones that are using the new config: It’s not so clear in the release notes
Edit: I just saw that you wrote don’t So no need to add that
I read the release notes, somehow added device_config into configuration.yaml and included my zwave configuration file. Afterwards I tried a lot of small variations on top of that.
So from what I understand the “device_config” part of zwave is only needed if you are turning config on. I wasn’t using any customizing in zwave yet but I added it in there just to be safe. I got it to work by having a separate line, the usb_path, etc, does not go in the zwave_device_config.yaml. The below component is working for me right now though I haven’t tried actually using the config panel yet.
