0.72: Lovelace UI, KIWI Doorlocks, Wireless Tags, Insteon X10
I am super excited about this release as it brings some great examples of how we are refining the system to become more customizable and, at the same time, user friendly. The first thing that I am really excited about is a new experimental user interface that we call Lovelace. Check this awesome rundown of all the features by @ciotlosm. The TL;DR: a faster, more customizable and more extensible UI with the same look and feel as the old one.
Be aware, this is experimental, so things will change. However, we felt like we didn’t want to keep this away from you any longer. Check the Lovelace UI docs on how to get started. Make sure to share your creations!
Thanks to all the people that have been hanging out in the #beta channel on Discord helping development, finding and squashing bugs and making suggestions. Especially thanks to @c727 for all his development work and @arsaboo for being the first guinea pig.
![](upload://yBNFgPyq9WKykswDv6w2Ro7n3W4.png) Example user interface created using Lovelace (source)
Another change is that Nest, Sonos and Cast will now have to be configured using a config entry. Config entries can be created via the integrations page in the config panel. This is a concept that we have been developing for a couple of months now and it’s our goal to eventually use this as the way to configure all components.
![](upload://omSFWiBwJi9XaMkobiFDVnik5L4.png) Screenshot of the Nest config entry.
And as if this releases even needs more cool stuff, the Insteon integration now supports X10 thanks to @teharris1. It was a frequent requested feature from the Insteon community.
And finally, we’ll be extending the open beta for Home Assistant Cloud until the first of September.
Enjoy this release and have a good weekend all!
New Platforms
If you need help…
…don’t hesitate to use our very active forums or join us for a little chat. The release notes have comments enabled but it’s preferred if you use the former communication channels. Thanks.
Reporting Issues
Experiencing issues introduced by this release? Please report them in our issue tracker. Make sure to fill in all fields of the issue template.
Breaking Changes
Beta Fixes
All changes
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2018/06/22/release-72/
Sweet. I’ve been refreshing pages all day waiting for this release. I’ve got an epson projector that needs controlling.
The new “Home Security State” seems to be ignoring my attempts to hide it using customize.yaml:
sensor.home_security_state:
  hidden: true
I can successfully change its name using “friendly_name” but “hidden” doesn’t do anything.
Amazing work with lovelace! Tried it for a while and love it! Looking forward to it being implemented for real! :heart_eyes:
Where is the Cast, Sonos, and Nest configs located once they are loaded? Is there a file that is created?
EDIT: Never mind, I think I found it in .config_entries.json
Excellent work.
A small suggestion. Although all this work greatly benefits the old users, we need to consider a bit more the learning curve for Home Assistant. Even keeping up with the new developments requires a bunch of time and keeping an eye on the git.
A new user will be overwhelmed - especially when there are parallel options and nothing is phased out. I would highly recommend that the frontend should also provide friendly configuration options (from the frontend) and not using exclusively more and more yaml files.
I can’t find the calendar panel…can someone help?
HI,
fantastic work.
BTW, I’ve seen that themes had disapear from costumization and no longer working. Was it removed ?
On mine themes reappeared after a few minutes. And it took about the same time for the “Try Lovelace” link to come up in dev-info.
Lovelace looks awesome can’t wait to have a play.
So I see I can’t specify my 4 google homes/mini’s under the media players by IPs. I tried to specify them as indicated on the warning/info log under the cast piece it still wouldn’t work. I ended up having to turn on discovery for them and they showed up but now I still can’t specify them by IP if I turn discovery off. Any workarounds other than rolling back a version?
Looks like it throws an error if I a specify an IP even for just one of the speakers:
Error while setting up platform cast
File “/usr/src/app/homeassistant/helpers/entity_platform.py”, line 129, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/src/app/homeassistant/components/media_player/cast.py”, line 205, in async_setup_entry
async_add_devices, None)
File “/usr/src/app/homeassistant/components/media_player/cast.py”, line 214, in _async_setup_platform
pychromecast.IGNORE_CEC += config.get(CONF_IGNORE_CEC, [])
AttributeError: ‘NodeListClass’ object has no attribute ‘get’
After a restart I was prompted to add a new google cast device. Once i’d done that my 2 Google Minis appeared.
I did that as well to get them configured but then when I turn discovery back off and specify the IPs of each it throws the errors. I’ll open an issue on github.
Loving the play I am having with Lovelace.
Particularly like the fact you don’t need to restart HA to make changes appear.
I think the forum will soon need another category for Lovelace questions.
But why did you name it after a porn star?
thanks @nickrout.
you are right. it’s now showing .
will play with it as it seams it’s a great quality increase on frontend
My Lovelace cards are rendering in one big vertical column, not three cards across like the pic in post one. Any ideas? Updated to 0.72 via hassbian-config today. Everything else seems to be working. My very simple Lovelace config file is:
  - name: Test
    theme: dark-mode
    cards:
      - type: entity-filter
        title: Lights
        filter:
          - domain: light
            state: 'on'
        card: glance
        card_config:
          title: Lights which are on
        filter:
          - domain: light
            state: 'off'
        card: glance
        card_config:
          title: Lights which are off
      - type: media-control
        entity: media_player.kitchen
  - tab_icon: mdi:settings
    cards:
        filter: [{}]
        card_config:
          title: All entities
I suppose it’s more aimed at Ada Lovelace since we’re rather technical here with HASS. Except maybe for the people automating their sexy-times. :smiley:
Remove title: Lights
Huh - this worked for me. I was able to hide it with the same entry in customize.yaml…
Apparently it only works if you have a Nest security product, when it first updates the attribute is set. I only have a thermostat so it never updates.
