I am running the config checker addon for Hass.io going from .74.0- .77.1 and man its throwing a butt ton of errors. I dont even know where to go from here except start from scratch.
The log:
running build_py
creating build
creating build/lib.linux-armv7l-3.6
creating build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/http_writer.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/payload_streamer.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/client_ws.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_exceptions.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_request.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_routedef.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/pytest_plugin.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/http_exceptions.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_ws.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_runner.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/cookiejar.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/client_proto.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/signals.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_urldispatcher.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/client_reqrep.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/hdrs.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/multipart.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_response.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_protocol.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_app.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/frozenlist.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/typedefs.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/streams.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/log.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/client_exceptions.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/base_protocol.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_middlewares.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/http_parser.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/http_websocket.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/tcp_helpers.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_server.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/__init__.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/client.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/abc.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/connector.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/locks.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/formdata.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/resolver.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/http.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/worker.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/helpers.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/payload.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/tracing.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/test_utils.py -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/web_fileresponse.py -> build/lib.linux-armv7l-3.6/aiohttp
running egg_info
writing aiohttp.egg-info/PKG-INFO
writing dependency_links to aiohttp.egg-info/dependency_links.txt
writing requirements to aiohttp.egg-info/requires.txt
writing top-level names to aiohttp.egg-info/top_level.txt
reading manifest file 'aiohttp.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching 'aiohttp' anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.pyd' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
warning: no previously-included files matching '*.lib' found anywhere in distribution
warning: no previously-included files matching '*.dll' found anywhere in distribution
warning: no previously-included files matching '*.a' found anywhere in distribution
warning: no previously-included files matching '*.obj' found anywhere in distribution
warning: no previously-included files found matching 'aiohttp/*.html'
no previously-included directories found matching 'docs/_build'
writing manifest file 'aiohttp.egg-info/SOURCES.txt'
copying aiohttp/_cparser.pxd -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_find_header.c -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_find_header.h -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_find_header.pxd -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_frozenlist.c -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_frozenlist.pyx -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_headers.pxi -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_helpers.c -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_helpers.pyi -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_helpers.pyx -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_http_parser.c -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_http_parser.pyx -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_http_writer.c -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_http_writer.pyx -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_websocket.c -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/_websocket.pyx -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/frozenlist.pyi -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/py.typed -> build/lib.linux-armv7l-3.6/aiohttp
copying aiohttp/signals.pyi -> build/lib.linux-armv7l-3.6/aiohttp
running build_ext
building 'aiohttp._websocket' extension
creating build/temp.linux-armv7l-3.6
creating build/temp.linux-armv7l-3.6/aiohttp
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/local/include/python3.6m -c aiohttp/_websocket.c -o build/temp.linux-armv7l-3.6/aiohttp/_websocket.o
In file included from aiohttp/_websocket.c:17:0:
/usr/local/include/python3.6m/Python.h:11:20: fatal error: limits.h: No such file or directory
#include <limits.h>
compilation terminated.
error: command 'gcc' failed with exit status 1
The only thing that is gone is the Python wrapper for the Rest API that was bundled in Home Assistant. The Rest API is still available. You can copy the old homeassistant.remote source code into your scripts.
Yes, that page is obsolete. I thought I removed it
Itās a good thing a authentication system is introduced. But it would be great if there was a possibility to go back the way the āpreviousā system works: visiting the page gives you direct access to Home Assistant. Passwords were optional.
Why? Security is good!
Yes, security is good. And for most people the auth system is a good start.
But users like me are already securing their networks (and Home Assistant) with firewalls, vlans, vpn access etc.
Also, my browser automatically deletes cookies and cached files after closing the browser and changes agent every tab change. Everytime I access Home Assistant from my desktop, I am forced to login with a username and passwordā¦
What do you suggest?
I think it could be solved quite easily. How about the following optional configuration variable:
Specify a default user account to automatically login with (user account can have password, but will not be prompted since youāre on a trusted network)
The user you login with can be set permissions to (read-only or read-wite)
I had a few problems getting this to work, perhaps specific to my setup. But just in case it helps anyone elseā¦
I couldnāt complete the Auth process and ended up locked out - getting 403 from every browser, even clearing the cache and deleting the .auth folder wouldnāt restart the process. This turned out to be because my internal docker IP wasnāt in my trusted networks. This never mattered before, but now that IP was getting banned before the Auth setup finished.
Not certain itās the best solution but adding 172.0.0.0/8 to my trusted networks seemed to solve it. I really appreciate the devs work on this - my setup isnāt exposed to the internet, but now I might finally look into it.
In my users list I now have me, my wife, and two instances of āHass.ioā. Is this right? Iād have thought only one instance were required? If thatās the case, how do I know which to delete?
Iām in 0.77.2 and at least the trusted_network is still working with Node.JS that accesses the Home Assistant API. For that, I do apologize for my resentment about the change in new authentication system. Iāve added a user for Home Assistant, opted to make use of Trusted Network, and once Iām logged in, itās working. Playing a movie in Plex turns off my light and when I pause or stop the movie, the lights come back on, so everything is working as it should using the trusted_networks.
TL;DR: I was worried about my Node.JS (Javascript) code failing due to trusted_networks not working at all starting with 0.77.
This discussion about security breaking functionality would not have been started from this whole mess had I not seen trusted_networks listed in breaking changes. In the future, Iām going to wait for .2 to stabilize before I upgrade. Well, at least I did when I upgraded from 0.74.2 to 0.77.2.
Since this new release, I have to type my login and password each time I go to Home Assistant. Their is no remember me option. Tested on Desktop Firefox and Android Chrome. I cannot see any cookie set when login.
Any idea on how to resolve this?
What you proposed is ātrusted networks authentication providerā, which is default enabled if you configured ātrusted_networksā option in http config.
Got it up and running. I completely forgot the changeover to Hassos.
The only issue I have now is that on Mobile Edge or Chrome on Android it is not asking to save the passwords under the new user system. It is under the legacy password though.
