Mine too…
If you roll back to 0.81.0 the Id’s get generated automatically.
0.81.0 was never installed on my system, but something higher and lower. So I can’t do a roll back to this Version. Maybe it is planned to re-add the automatic ID creation in a later release again?
With a quick copy paste (changing the ids) it will take you a minute
I just rolled back to 0.81.0 restarted and then went to latest with a restart and was done rather quickly.
Thanks for this!! I have it working again.
Just updated from 0.80.3 to 0.82.0. I have no problems with Z-Wave, but my Lovelace UI is a bit weird.
For starters, this blog claims a lot has changed in Lovelace, but the releasenotes at https://www.home-assistant.io/lovelace/changelog/ mention nothing? It still thinks 0.81.0 is the most recent version.
My problem is that since the upgrade all card titles are suddenly in a very small, not header-like font. Why?
This custom card can add the ID’s for you.
I see there’s an approved pull request for improved Koogeek support, any chance we can see those changes in the next version?
Is anyone else having an issue with asuswrt SSH not updating the status of the devices? I am not seeing any error messages in the logs.
Yes, asuswrt device tracker is broken in 0.82.
Yes, I have the same problem since 0.82.0, not updating!
I’ve just update to 82 from 81 and got “onkyo: Error on device update!”
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 251, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/media_player/onkyo.py", line 223, in update
self._attributes["video_out"] = ','.join(hdmi_out_raw[1])
TypeError: 'bool' object is not subscriptable
this is my conf:
media_player:
- platform: onkyo
host: !secret onkyo_host
sources:
pc: 'PC'
game: 'ChromeCast'
I tried to comment sourses, but nothing.
What’s goin on and what can i do?
Now back to 0.81 and onkyo work normal.
known issue, fix is in progress it seems: https://github.com/home-assistant/home-assistant/issues/18353
always a good idea to check github for issues.
Thanks, to check github for issues it’s really good idea.
After this update 0.82.1 I have lots of problems with embedded MQTT. After a while all my arduinos are disconnected and they can’t connect anymore. They don’t stop work all together but one after the other…
They start working only after I reset them.
I don’t think the problem is in my arduinos’ software because they worked until today like a charm!
Any suggestion?
Yes, logs. We do not have crystal balls.
looking at home-assistant.log I don’t find anything useful:
enabling MQTT debugging and looking at the log file I see only received and sent topic
tail -f /home/homeassistant/.homeassistant/home-assistant.log | grep mqtt
any other log file to look at?
Only what is generated by the arduino code, which I am guessing will be a PITA to retrieve.
Does the built in MQTT server continue to run?
Have you tried mosquitto (which I must say, I have always had better luck with!)
Agree with @nickrout, the embedded mqtt broker is very limited and I also had problem. Since I moved to mosquitto I didn’t have any issue (in a docker container)
