0.86: New Lovelace UI and Zigbee Management Panel!
There are actually many more than 3 solutions for controlling Zigbee devices with Home Assistant, but the ZHA component that is talked about in this blog post is actually is the only solution that is actually “running under Home Assistant”, that is a so-called native solution (running within Home Assistant runtime), as all the other solution rely on external bridges/gateways/hubs as middleware which converts to a language that Home Assistant understands, just like having a Philips Hue Hub, (main difference between using Philips Hue Hub and zigbee2mqtt or deCONZ is that those can run on the same hardware as Home Assistant while Philips Hue Hub only runs on its dedicated hardware).
To summarize; the ZHA component is a native solution that is fully integrated into Home Assistant and therefore with it you just need to plugin your adapter hardware in the same computer running Home Assistant. With other solutions like zigbee2mqtt and deCONZ you could technically run them on a other computer and have the solution communicate over your local network.
Thank you, resolve my problem.
I am clicking the upgrade button in the Hassio panel, then after a while the system is unresponsive, like usual during update, but when it boots up it is still 0.85.1? Others with same problem?
Same problem here. Log doesn’t help - don’t have any invalid config entries. Dont have any __ in configs.
that whole thing is quite confusing. the post about the zigbee management doesnt say ANYTHING about ZHA.
I do have 2 seperate Zigbee networks (zigbee2mqtt and hue hub) and cant use it. So in the end its only a ZHA management.
Ever since upgrading, I get the following error in my logs when accessing Lovelace via Chrome 71.0.3578.98 on macOS (it works in Safari on my phone).
https://xxxxxx.duckdns.org:8123/frontend_latest/app-3b4bb4ed.js:365:157 Uncaught
TypeError: Illegal constructor
4:40 PM components/system_log/__init__.py (ERROR)
and the following error in Chrome’s console
Uncaught TypeError: Illegal constructor
    at CSSResult.get styleSheet [as styleSheet] (app-3b4bb4ed.js:365)
    at renderRoot.adoptedStyleSheets.styles.map.s (app-3b4bb4ed.js:377)
    at Array.map (<anonymous>)
    at HTMLElement.adoptStyles (app-3b4bb4ed.js:377)
    at HTMLElement.initialize (app-3b4bb4ed.js:377)
    at new UpdatingElement (app-3b4bb4ed.js:344)
    at new lit_element_LitElement (app-3b4bb4ed.js:377)
    at new <anonymous> (app-3b4bb4ed.js:1305)
    at new <anonymous> (8ee9235853b66c6b78f9.chunk.js:1071)
    at new hui_root_HUIRoot (8ee9235853b66c6b78f9.chunk.js:5370)
I am not the only one — someone else mentioned the exact same error (and Chrome version) on Discord.
Which version of Chrome are you using? I am on 71.0.3578.98 and get the same error.
I’ve got a Google Chrome 71.0.3578.98 and got the answer as well : It’s a Google Chrome thing. An experimental feature has to be disabled for this issue.
Try this:
  1. put this : “chrome://flags/#enable-experimental-web-platform-features” in the url bar
  2. Disable the feature.
  3. Wait for the re-launch.
I can re-create the issue by having the feature enabled on a working one.
I installed 0.86.2 today and hey presto the apple tv stuff is back.
I had this error message while updating:
Successfully built ruamel.yaml bcrypt aiohttp
Could not install packages due to an EnvironmentError: [Errno 2] No such file or directory:
'/srv/homeassistant/lib/python3.5/site-packages/ruamel.yaml-0.15.81.dist-info/METADATA'
It doesn’t appear to have stopped Home Assistant from working (it didn’t start up after the update but that was due to a double underscore in one of the entities I had under the customize section), is it something I should worry about or can I ignore this?
for:
minutes: 5
Seems not to work anymore since this upgrade because it seems related to:
Another noteworthy breaking change (sorry!), is that the automation time trigger has been split into two: time and time_pattern . If you had a time trigger containing the keys hours , minutes or seconds , update the platform from time to time_pattern
I used this often in my automations:
  • entity_id: binary_sensor.sensor_2
    platform: state
    to: ‘off’
    for:
    minutes: ‘5’
And now I get an error saying that ‘minutes’ is not allowed in automations.
Lot of troubles last months when updates come available. Is Home Assistant stille the way to go?
can’t update to 0.8.6. I tried woth verios 0.86.1 and 0.86.2 without succes. Bellow what my logs says:
19-01-25 19:22:30 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-01-25 19:23:51 INFO (SyncWorker_19) [hassio.docker] Run command ‘python3 -m homeassistant -c /config --script check_config’ on homeassistant/raspberrypi3-homeassistant
19-01-25 19:24:38 INFO (MainThread) [hassio.homeassistant] Home Assistant config is valid
19-01-25 19:24:38 INFO (SyncWorker_1) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
19-01-25 19:24:51 INFO (SyncWorker_1) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
19-01-25 19:24:54 INFO (SyncWorker_17) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.85.1
19-01-25 19:25:25 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-01-25 19:38:42 INFO (SyncWorker_3) [hassio.docker] Run command ‘python3 -m homeassistant -c /config --script check_config’ on homeassistant/raspberrypi3-homeassistant
19-01-25 19:39:29 INFO (MainThread) [hassio.homeassistant] Home Assistant config is valid
19-01-25 19:39:29 INFO (SyncWorker_15) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
19-01-25 19:39:42 INFO (SyncWorker_15) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
19-01-25 19:39:47 INFO (SyncWorker_8) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.85.1
19-01-25 19:40:18 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-01-25 19:46:53 INFO (MainThread) [hassio.snapshots] Full-Snapshot 3ce4514a start
19-01-25 19:46:53 INFO (MainThread) [hassio.snapshots] Snapshot 3ce4514a store Add-ons
19-01-25 19:46:53 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on a0d7b954_jupyterlablite
19-01-25 19:46:53 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on core_check_config
19-01-25 19:46:53 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on a0d7b954_influxdb
19-01-25 19:46:53 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on core_samba
19-01-25 19:46:53 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on core_mosquitto
19-01-25 19:46:53 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on core_configurator
19-01-25 19:46:53 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on core_duckdns
19-01-25 19:46:53 INFO (MainThread) [hassio.addons.addon] Build snapshot for add-on core_ssh
19-01-25 19:46:53 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_samba
19-01-25 19:46:53 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_configurator
19-01-25 19:46:54 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_check_config
19-01-25 19:46:54 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_mosquitto
19-01-25 19:46:55 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_ssh
19-01-25 19:46:55 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon a0d7b954_jupyterlablite
19-01-25 19:46:55 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon core_duckdns
19-01-25 19:54:40 INFO (MainThread) [hassio.addons.addon] Finish snapshot for addon a0d7b954_influxdb
19-01-25 19:54:40 INFO (MainThread) [hassio.snapshots] Snapshot 3ce4514a store folders
19-01-25 19:54:40 INFO (SyncWorker_6) [hassio.snapshots.snapshot] Snapshot folder share
19-01-25 19:54:40 INFO (SyncWorker_15) [hassio.snapshots.snapshot] Snapshot folder homeassistant
19-01-25 19:54:40 INFO (SyncWorker_9) [hassio.snapshots.snapshot] Snapshot folder addons/local
19-01-25 19:54:40 INFO (SyncWorker_3) [hassio.snapshots.snapshot] Snapshot folder ssl
19-01-25 19:54:40 INFO (SyncWorker_6) [hassio.snapshots.snapshot] Snapshot folder share done
19-01-25 19:54:40 INFO (SyncWorker_9) [hassio.snapshots.snapshot] Snapshot folder addons/local done
19-01-25 19:54:40 INFO (SyncWorker_3) [hassio.snapshots.snapshot] Snapshot folder ssl done
19-01-25 19:57:30 INFO (SyncWorker_15) [hassio.snapshots.snapshot] Snapshot folder homeassistant done
19-01-25 19:58:18 INFO (MainThread) [hassio.snapshots] Full-Snapshot 3ce4514a done
19-01-25 20:02:30 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-01-25 20:18:14 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.86.2
19-01-25 20:18:14 INFO (SyncWorker_1) [hassio.docker.interface] Update Docker 0.85.1 with homeassistant/raspberrypi3-homeassistant:0.86.2
19-01-25 20:18:14 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.86.2.
19-01-25 20:27:47 INFO (SyncWorker_1) [hassio.docker.interface] Tag image homeassistant/raspberrypi3-homeassistant with version 0.86.2 as latest
19-01-25 20:27:47 INFO (SyncWorker_1) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
19-01-25 20:28:22 INFO (SyncWorker_1) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
19-01-25 20:28:23 INFO (SyncWorker_1) [hassio.docker.interface] Cleanup Docker images: [‘homeassistant/raspberrypi3-homeassistant:0.85.1’]
19-01-25 20:29:05 INFO (SyncWorker_0) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.86.2
19-01-25 20:39:10 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home Assistant startup!
19-01-25 20:39:10 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
19-01-25 20:39:10 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.85.1
19-01-25 20:39:10 INFO (SyncWorker_15) [hassio.docker.interface] Update Docker 0.86.2 with homeassistant/raspberrypi3-homeassistant:0.85.1
19-01-25 20:39:10 INFO (SyncWorker_15) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.85.1.
19-01-25 20:43:19 INFO (SyncWorker_15) [hassio.docker.interface] Tag image homeassistant/raspberrypi3-homeassistant with version 0.85.1 as latest
19-01-25 20:43:19 INFO (SyncWorker_15) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant Docker application
19-01-25 20:43:40 INFO (SyncWorker_15) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
19-01-25 20:43:40 INFO (SyncWorker_15) [hassio.docker.interface] Cleanup Docker images: [‘homeassistant/raspberrypi3-homeassistant:0.86.2’]
19-01-25 20:44:02 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.85.1
19-01-25 20:44:42 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-01-25 20:44:42 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.85.1
Any ideas what can i do?
It is a mess because your groups are not loaded, probably because you have an entity in there with a double _ or a _ at the end or beginning.
Same for @tmeringer
my nuc i5 update keeps rolling back, ive even commented out automation and scripts, none of my names have double underscores or at beginning or end
19-01-25 21:40:35 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.86.2
19-01-25 21:40:35 INFO (SyncWorker_16) [hassio.docker.interface] Update Docker 0.85.1 with homeassistant/intel-nuc-homeassistant:0.86.2
19-01-25 21:40:35 INFO (SyncWorker_16) [hassio.docker.interface] Pull image homeassistant/intel-nuc-homeassistant tag 0.86.2.
19-01-25 21:41:07 INFO (SyncWorker_16) [hassio.docker.interface] Tag image homeassistant/intel-nuc-homeassistant with version 0.86.2 as latest
19-01-25 21:41:07 INFO (SyncWorker_16) [hassio.docker.interface] Stop homeassistant/intel-nuc-homeassistant Docker application
19-01-25 21:41:38 INFO (SyncWorker_16) [hassio.docker.interface] Clean homeassistant/intel-nuc-homeassistant Docker application
19-01-25 21:41:38 INFO (SyncWorker_16) [hassio.docker.interface] Cleanup Docker images: [‘homeassistant/intel-nuc-homeassistant:0.85.1’]
19-01-25 21:41:39 INFO (SyncWorker_5) [hassio.docker.homeassistant] Start homeassistant homeassistant/intel-nuc-homeassistant with version 0.86.2
19-01-25 21:51:40 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home Assistant startup!
19-01-25 21:51:40 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
19-01-25 21:51:40 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.85.1
19-01-25 21:51:40 INFO (SyncWorker_1) [hassio.docker.interface] Update Docker 0.86.2 with homeassistant/intel-nuc-homeassistant:0.85.1
19-01-25 21:51:40 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/intel-nuc-homeassistant tag 0.85.1.
I’ve got the same issue. Keeps rolling back every time.
Check all config files, group, customise etc
Upgraded to 86.2 with no issues. Had to make a couple config changes per the release notes but smooth sailing.
try removing groups, customize and automations and don’t forget to look at any packages as well and see if you can updrade then. Then you can look for and find the rogue id’s
well i found 2 rogue devices in my customize with _ at beggining and _ at end i renamed them and now im on 86.2 but now i have shit tons of icons all over the front end and its saying all my groups have errors:
group:
light:
switch:
automation:
and just about every group going
this is a pain :confused:
so you are just going to have to check through them and work the problems… you might find only 1 or 2 errors and that has spurned a whole bunch of errors… Just have to work through.
Use the dev-tools <> to check all your entity names. It is worth looking in packages if you use them as well and look for time triggers in automations… I think also that if you have any entity id’s with capital letters - that will kill it as well…
