0.89 netatmo sensor don't work anymore
With 0.89 my netatmo sensors stopped working.
When I check my config I get this
Platform not found: sensor.netatmo
Logs tell:
Error: Unable to find platform netatmo. Search path was limited to path of component: custom_components
I also use this custom component:
When I comment out this
 - platform: netatmo
   station: station_name
   modules:
     room1:
       - temperature
       - humidity
       - co2
than the config check is fine. I think this error is linked to the custom component. But when I comment out the climate section of the custom component I still get the above mentioned errors.
@Baosong_Shan
See this for the fix, if you have the same issue:
