0.92: HEOS, Somfy MyLink, Genius Hub
0.92.1 has been released. Fixed several component loading issue caused by the Great Migration. If you still have problem to start/restart your instance on 0.92.1, please create separate issue in our GitHub repo. Because although the symptoms might be similar, cannot start, the cause could be very different.
just rolled back to 0.91.3 and everything works, so it was definitively 0.92 issues. I’ll try 0.92.1 asap
can you confirm no error logs were written?
Can’t seem to upgrade to the latest version.
Any hints, as to how I can fix this.
This is the output from “pip3 install --upgrade homeassistant”
Seems like a missing OpenSSL header file.
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting homeassistant
  Using cached https://files.pythonhosted.org/packages/31/0c/b090b882d8ef089c1483a5331ef3cddb9bf15b284cfed6fd048db85f0997/homeassistant-0.92.1-py3-none-any.whl
Requirement already satisfied, skipping upgrade: requests==2.21.0 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2.21.0)
Requirement already satisfied, skipping upgrade: attrs==18.2.0 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (18.2.0)
Requirement already satisfied, skipping upgrade: pip>=8.0.3 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (19.0.3)
Collecting ruamel.yaml==0.15.91 (from homeassistant)
Requirement already satisfied, skipping upgrade: voluptuous-serialize==2.1.0 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2.1.0)
Requirement already satisfied, skipping upgrade: certifi>=2018.04.16 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2019.3.9)
Requirement already satisfied, skipping upgrade: jinja2>=2.10 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2.10.1)
Requirement already satisfied, skipping upgrade: astral==1.10.1 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (1.10.1)
Requirement already satisfied, skipping upgrade: bcrypt==3.1.6 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (3.1.6)
Requirement already satisfied, skipping upgrade: pytz>=2019.01 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2019.1)
Requirement already satisfied, skipping upgrade: aiohttp==3.5.4 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (3.5.4)
Collecting PyJWT==1.7.1 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/87/8b/6a9f14b5f781697e51259d81657e6048fd31a113229cf346880bb7545565/PyJWT-1.7.1-py2.py3-none-any.whl
Collecting cryptography==2.6.1 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/07/ca/bc827c5e55918ad223d59d299fff92f3563476c3b00d0a9157d9c0217449/cryptography-2.6.1.tar.gz
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
    Preparing wheel metadata ... done
Requirement already satisfied, skipping upgrade: pyyaml<4,>=3.13 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (3.13)
Collecting python-slugify==3.0.2 (from homeassistant)
Requirement already satisfied, skipping upgrade: async-timeout==3.0.1 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (3.0.1)
Requirement already satisfied, skipping upgrade: voluptuous==0.11.5 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (0.11.5)
Requirement already satisfied, skipping upgrade: chardet<3.1.0,>=3.0.2 in /srv/homeassistant/lib/python3.5/site-packages (from requests==2.21.0->homeassistant) (3.0.4)
Requirement already satisfied, skipping upgrade: urllib3<1.25,>=1.21.1 in /srv/homeassistant/lib/python3.5/site-packages (from requests==2.21.0->homeassistant) (1.24.2)
Requirement already satisfied, skipping upgrade: idna<2.9,>=2.5 in /srv/homeassistant/lib/python3.5/site-packages (from requests==2.21.0->homeassistant) (2.8)
Requirement already satisfied, skipping upgrade: MarkupSafe>=0.23 in /srv/homeassistant/lib/python3.5/site-packages (from jinja2>=2.10->homeassistant) (1.1.1)
Requirement already satisfied, skipping upgrade: cffi>=1.1 in /srv/homeassistant/lib/python3.5/site-packages (from bcrypt==3.1.6->homeassistant) (1.12.3)
Requirement already satisfied, skipping upgrade: six>=1.4.1 in /srv/homeassistant/lib/python3.5/site-packages (from bcrypt==3.1.6->homeassistant) (1.12.0)
Requirement already satisfied, skipping upgrade: yarl<2.0,>=1.0 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp==3.5.4->homeassistant) (1.3.0)
Requirement already satisfied, skipping upgrade: idna-ssl>=1.0; python_version < "3.7" in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp==3.5.4->homeassistant) (1.1.0)
Requirement already satisfied, skipping upgrade: multidict<5.0,>=4.0 in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp==3.5.4->homeassistant) (4.5.2)
Requirement already satisfied, skipping upgrade: typing-extensions>=3.6.5; python_version < "3.7" in /srv/homeassistant/lib/python3.5/site-packages (from aiohttp==3.5.4->homeassistant) (3.7.2)
Requirement already satisfied, skipping upgrade: asn1crypto>=0.21.0 in /srv/homeassistant/lib/python3.5/site-packages (from cryptography==2.6.1->homeassistant) (0.24.0)
Collecting text-unidecode==1.2 (from python-slugify==3.0.2->homeassistant)
  Using cached https://files.pythonhosted.org/packages/79/42/d717cc2b4520fb09e45b344b1b0b4e81aa672001dd128c180fabc655c341/text_unidecode-1.2-py2.py3-none-any.whl
Requirement already satisfied, skipping upgrade: pycparser in /srv/homeassistant/lib/python3.5/site-packages (from cffi>=1.1->bcrypt==3.1.6->homeassistant) (2.19)
Building wheels for collected packages: cryptography
  Building wheel for cryptography (PEP 517) ... error
  Complete output from command /srv/homeassistant/bin/python3 /srv/homeassistant/lib/python3.5/site-packages/pip/_vendor/pep517/_in_process.py build_wheel /tmp/tmpmjfd8g6a:
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-armv7l-3.5
  creating build/lib.linux-armv7l-3.5/cryptography
  copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-3.5/cryptography
  copying src/cryptography/utils.py -> build/lib.linux-armv7l-3.5/cryptography
  copying src/cryptography/__about__.py -> build/lib.linux-armv7l-3.5/cryptography
  copying src/cryptography/__init__.py -> build/lib.linux-armv7l-3.5/cryptography
  copying src/cryptography/fernet.py -> build/lib.linux-armv7l-3.5/cryptography
  creating build/lib.linux-armv7l-3.5/cryptography/x509
  copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-3.5/cryptography/x509
  copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-3.5/cryptography/x509
  copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-3.5/cryptography/x509
  copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-3.5/cryptography/x509
  copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-3.5/cryptography/x509
  copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/x509
  copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-3.5/cryptography/x509
  copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-3.5/cryptography/x509
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat
  copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat
  copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/mac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings
  copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/kdf
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/twofactor
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/serialization
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/ciphers
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/primitives/asymmetric
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ocsp.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/backends/openssl
  creating build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-3.5/cryptography/hazmat/bindings/openssl
  running egg_info
  writing top-level names to src/cryptography.egg-info/top_level.txt
  writing src/cryptography.egg-info/PKG-INFO
  writing requirements to src/cryptography.egg-info/requires.txt
  writing dependency_links to src/cryptography.egg-info/dependency_links.txt
  reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
  reading manifest template 'MANIFEST.in'
  no previously-included directories found matching 'docs/_build'
  warning: no previously-included files matching '*' found under directory 'vectors'
  writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
  running build_ext
  generating cffi module 'build/temp.linux-armv7l-3.5/_padding.c'
  creating build/temp.linux-armv7l-3.5
  generating cffi module 'build/temp.linux-armv7l-3.5/_constant_time.c'
  generating cffi module 'build/temp.linux-armv7l-3.5/_openssl.c'
  building '_openssl' extension
  creating build/temp.linux-armv7l-3.5/build
  creating build/temp.linux-armv7l-3.5/build/temp.linux-armv7l-3.5
  arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-6waWnr/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.5m -c build/temp.linux-armv7l-3.5/_openssl.c -o build/temp.linux-armv7l-3.5/build/temp.linux-armv7l-3.5/_openssl.o -Wconversion -Wno-error=sign-conversion
  build/temp.linux-armv7l-3.5/_openssl.c:498:30: fatal error: openssl/opensslv.h: No such file or directory
   #include <openssl/opensslv.h>
  compilation terminated.
  error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
  Failed building wheel for cryptography
  Running setup.py clean for cryptography
Failed to build cryptography
Could not build wheels for cryptography which use PEP 517 and cannot be installed directly
Just found this one:
Try installing libssl-dev
Either the ffmpg or streaming component eventually stops my front end from responding with the following error last in the log:
TypeError: undefined is not an object (evaluating 'window.webkit.messageHandlers.externalBus.postMessage
Removing ffmpg: and the stream config for my generic cameras seems to have restored stability.
I have the same issue as you.
Do you face any shell command issues? Mine have stopped working ever since 0.92
My shell commands are working.
I am going NUTS.
Fresh install of 0.92 on a NUC.
Flashed the SSD - OK
Started, created the (first user) - OK
When I restart, it does not bring the web interface back!
Then, I delete the entire .Store dir, and I need to create again the user. Then, I restart, same problem.
I did it 4 times, same result.
The log doesn’t say much, except for a warning:
2019-04-27 02:11:00 WARNING (MainThread) [homeassistant.config_entries] Config entry for daikin not ready yet. Retrying in 5 seconds.
Any idea? Should I modify something? Should I do something concerning AUTH?
Please help!
Clearly it does, or you wouldn’t be able to read the log.
Sorry, I edited the post a bit. I realized I was not clear.
Often it is as simple as clearing your browser cache. Ctrl-f5 on chrome.
This is a somewhat cosmetic issue, but on my map I have an mdi exit-to-app icon sitting off the coast of Africa, even more odd I can move it with the mouse cursor, can some others check and see if there map has this issue?
Thanks again!
Keep up the amazing work!
Nothing there for me (or anywhere else).
After update to 0.92.1 - things looks OK
Is not that.
In incognito mode, it does the same
Thanks for confirming its just me. I’ll dig into my config.
I have looked around my config and I cannot find any reference to this location or mdi icon. I would appreciate any guidance on how to figure this out.
After upgrading to 0.92 got these errors stream_worker ??
2019-04-27 13:45:30 ERROR (stream_worker) [libav.rtsp] Nonmatching transport in server reply
2019-04-27 13:45:30 ERROR (stream_worker) [libav.h264] non-existing PPS 0 referenced
2019-04-27 13:45:30 ERROR (stream_worker) [libav.h264] decode_slice_header error
2019-04-27 13:45:30 ERROR (stream_worker) [libav.h264] no frame!
2019-04-27 13:45:30 ERROR (SyncWorker_10) [homeassistant.components.nut.sensor] NUT Sensor has no data, unable to set up
2019-04-27 13:45:30 ERROR (MainThread) [netdata] Can not load data from Netdata
Disregard, I reloaded today and its gone :slight_smile:
