on 0.97.1 and 0.97.2 [I’m using hassio on rpi3] when clicking the “check configuration” button - there is the spinning circle animation and that’s it. it never ends, configuration never checks. while looked into log file, I’ve found this:
2019-08-16 01:27:57 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 37, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 69, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 228, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 124, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/core.py", line 29, in post
errors = await async_check_ha_config_file(request.app["hass"])
File "/usr/src/homeassistant/homeassistant/config.py", line 835, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 151, in async_check_ha_config_file
p_validated = component_platform_schema(p_config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 267, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 589, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 381, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 204, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 284, in _exec
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 630, in validate_sequence
cval = validate(index_path, value)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 249, in _exec
return func(path, v)
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 811, in validate_callable
return schema(data)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 381, in service
if valid_entity_id(value):
File "/usr/src/homeassistant/homeassistant/core.py", line 121, in valid_entity_id
return "." in entity_id and slugify(entity_id) == entity_id.replace(".", "_", 1)
TypeError: argument of type 'NoneType' is not iterable
I know that configuration is valid [I didn’t entered any “breaking change”, just added one light]. to troubleshoot I even tried different SD card, different power source - with no luck.
is it something bigger or it’s just on my side and I need to investigate my hardware/config further [even if it’s untouched]?
