I’m guessing it’s related to my other problem described here.
after clicking on button to restart the system, all I got is an error:
2019-08-17 14:00:32 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall homeassistant.restart (c:3258550e665e442481c1869e4c9bec1b)>
File "/usr/src/homeassistant/homeassistant/core.py", line 1243, in _safe_execute
await self._execute_service(handler, service_call)
File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 265, in async_handle_core_service
errors = await conf_util.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 835, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 151, in async_check_ha_config_file
p_validated = component_platform_schema(p_config)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 267, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 589, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 381, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 204, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 284, in _exec
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 630, in validate_sequence
cval = validate(index_path, value)
File "/usr/local/lib/python3.7/site-packages/voluptuous/validators.py", line 249, in _exec
return func(path, v)
v = func(path, v)
File "/usr/local/lib/python3.7/site-packages/voluptuous/schema_builder.py", line 811, in validate_callable
return schema(data)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 381, in service
if valid_entity_id(value):
File "/usr/src/homeassistant/homeassistant/core.py", line 121, in valid_entity_id
return "." in entity_id and slugify(entity_id) == entity_id.replace(".", "_", 1)
TypeError: argument of type 'NoneType' is not iterable
hardware: RPi3
any ideas what’s up?
EDIT: link
