0.99: Withings, Device Automations, launch Home Assistant Cast from Python
You should be able to give permissions per app.
can only find haptic_feedback on a general setting on my android
not for an app, and i use chrome anyway for displaying HA, not an android app
Make sure you update to the latest version of the button card to make sure they are compatible.
I am, would HACS be a reason it can’t read the button card?
@Bram_Kragten Any way to disable the vibration on mobile?
I have a wall mounted tablet that now vibrates whenever used. It’s very inconvenient.
Same… all the sudden my android phone and tablet vibrate and they never did before. (Using HA thru chrome).
How can i disable vibrate?
there is no way to disable vibrate on chrome as of now unfortunately
I have run cast and it seems, multiple-entity-row custom card is also not supported. I am running the one installed like 2 days ago on 99.2.
That one works for me
“Beers after CEDIA with @balloob from Home Assistant and teams from Senic and Neeo.”
Dissappointed - Neeo stuffed a load of people in this community and have not been good company for years. Not my choice of drinking pals - and shouldn’t be yours.
Hello everyone. I’m experiencing an issue with this version (Hass.io on Raspberry Pi 3+). I can’t acces the manage entities page for Alexa anymore (/config/cloud/alexa). Worked just fine before the update.
Does anyone know how to fix this?
Are you casting onto a television? I’m not sure why it says
Cannot read property ‘config’ of null
Are you doing anything special?
Have you cleared your browser cache and logged back in?
Thank you! That did the trick :slight_smile:
I can cast via lovelace but calling the new service doesn’t work.
This:
          - type: entities
            title: Chromecast Control
            show_header_toggle: false
            entities:
              - type: cast
                view: "home_assistant"
                hide_if_unavailable: false
              - type: cast
                view: "weather"
Works
Doesn’t work.
I get an error on the screen:
EDIT: I specified a port as I’m not using 443 and it works ONLY if I specify 0 as the path and then it displays the states page. Any other view says unable to display path x
Tried with a TV and with this config:
type: custom:button-card
entity: binary_sensor.remote_ui
So…is that a no? :man_shrugging:
After update 0.99.2 i dont have any history from my entity’s anyone else have this issue?
