📝 100% Templatable Lovelace Configurations
Is there any way to template the state?
The state is normally for the entity of the row but I would like to set the row to a different entity and have the state be the state for a different entity. This is so when I tap the row I get attributes displaying for a different entity…
example:
The 90% is the rssi for entity 1 but when I tap on coffee I would like it to display a different entity:
Instead of:
I suspect it’s not possible?
Could you give a code for this card?
As I understood:
  1. The first entity (“Coffee”, the very left entity) is now currently displayed in more-info.
  2. You want a more-info for another entity - “90%”. This entity now located on the right side.
Coffee is just text for the entity and the 90% RSSI state belongs to that. I want tapping on coffee to pull up the second entity more info which isn’t currently on that coffee line at all. Basically the different Tasmota entities for the sonoff switch (provided by the integration) make up the Coffee Line and I am writing a status command from MQTT to a Sensor which provides all the more info… so the rssi entity is the entity for the 90% but when I tap it I want it to show the status sensor instead of the RSSI graph.
So I’d likt to use a template to override the state with a state from a different entity… them more info would be the bit I want but the state would still be the RSSI…
Maybe I need to do a collapsed fold-entity-row for the second entity and then tap that to display the more info…
David, I am not a native English speaker and do not have a lot of experience of HA in part of MQTT & Tasmota. A code and a small picture would be more clear for me to help you.
What I could imagine:
  1. There is a multiple-entity-row.
  2. The primary item (the first one) is some entity (“primary entity”).
  3. Other items (“secondary items”) are either another entities or attributes of some entity.
  4. Every item (primary & secondary) has a “tap_action” which is “more-info”.
What you may want is:
  1. Disable the “more-info” for some item (“tap_action: action: none”).
  2. Show “more-info” for another entity. To understand how to do this (or say “not possible”) I need a code for this card (+ explanations like “I need more-info for THAT entity instead of THAT entity”). Using a similar code I may simulate your case on my setup.
No, you can’t specify the state text on an entity row on a core entity row (outside the text row but I don’t think you want that), but you look to be using a custom row so perhaps ask that developer. The other option is to use browser_mod to specify that popup for this row.
I still do not understand the whole task.
Thanks Ian. I’ll take a look at that. I’m not using a custom-row BTW - just a standard entities card with your template card to modify the name. I am only having this problem now because I switched to using the Tasmota Integration as MQTT Discovery for HA seems to be deprecated now in Tasmota…
Don’t worry about it. Thanks for trying to help anyway. It’s probably a language barrier as it’s reasonably clear what I am trying to do and posting my entity config will only confuse you further.
OK!
So thanks to @iantrich for the idea, I ended up using custom:multiple-entity-row which lets me do pretty much what I wanted while also restoring the state card info for my Tasmota devices before I ‘upgraded’ to the Tasmota integration.
Here is what the old card looked like and also the code and what I saw when I clicked on the row…
image image
Card Config:
          - type: 'custom:config-template-card'
            variables:
              - states['sensor.sonoff1_2914_mqtt_connect_count'].state
              - states['sensor.sonoff1_2914_wifi_connect_count'].state
              - states['sensor.sonoff1_2914_rssi'].state
              - states['sensor.sonoff2_3110_mqtt_connect_count'].state
              - states['sensor.sonoff2_3110_wifi_connect_count'].state
              - states['sensor.sonoff2_3110_rssi'].state
              - states['sensor.sonoff5_1083_mqtt_connect_count'].state
              - states['sensor.sonoff5_1083_wifi_connect_count'].state
              - states['sensor.sonoff5_1083_rssi'].state
              - states['sensor.sonoff6_3719_mqtt_connect_count'].state
              - states['sensor.sonoff6_3719_wifi_connect_count'].state
              - states['sensor.sonoff6_3719_rssi'].state
              - states['sensor.nodemcu_lounge_mqtt_connect_count'].state
              - states['sensor.nodemcu_lounge_wifi_connect_count'].state
              - states['sensor.nodemcu_lounge_rssi'].state
              - states['sensor.nodemcu_bedroom_mqtt_connect_count'].state
              - states['sensor.nodemcu_bedroom_wifi_connect_count'].state
              - states['sensor.nodemcu_bedroom_rssi'].state
              - states['sensor.sonoff3_0898_mqtt_connect_count'].state
              - states['sensor.sonoff3_0898_wifi_connect_count'].state
              - states['sensor.sonoff3_0898_rssi'].state
              - states['sensor.sonoff4_0851_mqtt_connect_count'].state
              - states['sensor.sonoff4_0851_wifi_connect_count'].state
              - states['sensor.sonoff4_0851_rssi'].state
              - states['sensor.sonoff1_2914_signal'].state
              - states['sensor.sonoff2_3110_signal'].state
              - states['sensor.sonoff5_1083_signal'].state
              - states['sensor.sonoff6_3719_signal'].state
              - states['sensor.nodemcu_lounge_signal'].state
              - states['sensor.nodemcu_bedroom_signal'].state
              - states['sensor.sonoff3_0898_signal'].state
              - states['sensor.sonoff4_0851_signal'].state
            entities:
              - sensor.sonoff1_2914_rssi
              - sensor.sonoff2_3110_rssi
              - sensor.sonoff5_1083_rssi
              - sensor.sonoff6_3719_rssi
              - sensor.nodemcu_lounge_rssi
              - sensor.nodemcu_bedroom_rssi
              - sensor.sonoff3_0898_rssi
              - sensor.sonoff4_0851_rssi
            card:
              type: 'custom:hui-entities-card'
              title: MQTT & Wifi Connections
              show_header_toggle: false
              entities:
                - entity: sensor.sonoff1_2914_rssi
                  name: "${'Coffee' + '\xa0'.repeat(16) + 'MQTT ' + vars[0] + '\xa0'.repeat(4) + 'WiFi ' + vars[1] + '\xa0'.repeat(3) + vars[24] + '\xa0' + 'dBm' + '\xa0'.repeat(3) + ( vars[2] >= 100 ? 'Excellent' : vars[2] >= 80 ? 'Good' : vars[2] >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${vars[2] >= 100 ? 'mdi:wifi' : vars[2] >= 80 ? 'mdi:wifi-strength-3' : vars[2] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                - entity: sensor.sonoff2_3110_rssi
                  name: "${'Toothbrush' + '\xa0'.repeat(7) + 'MQTT ' + vars[3] + '\xa0'.repeat(4) + 'WiFi ' + vars[4] + '\xa0'.repeat(3) + vars[25] + '\xa0' +  'dBm' + '\xa0'.repeat(3) + ( vars[5] >= 100 ? 'Excellent' : vars[5] >= 80 ? 'Good' : vars[5] >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${vars[5] >= 100 ? 'mdi:wifi' : vars[5] >= 80 ? 'mdi:wifi-strength-3' : vars[5] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                - entity: sensor.sonoff5_1083_rssi
                  name: "${'Garage' + '\xa0'.repeat(15) + 'MQTT ' + vars[6] + '\xa0'.repeat(4) + 'WiFi ' + vars[7] + '\xa0'.repeat(3) + vars[26] + '\xa0' +  'dBm' + '\xa0'.repeat(3) + ( vars[8] >= 100 ? 'Excellent' : vars[8] >= 80 ? 'Good' : vars[8] >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${vars[8] >= 100 ? 'mdi:wifi' : vars[8] >= 80 ? 'mdi:wifi-strength-3' : vars[8] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                - entity: sensor.sonoff6_3719_rssi
                  name: "${'Alarm' + '\xa0'.repeat(17) + 'MQTT ' + vars[9] + '\xa0'.repeat(4) + 'WiFi ' + vars[10] + '\xa0'.repeat(3) + vars[27] + '\xa0' +  'dBm' + '\xa0'.repeat(3) + ( vars[11] >= 100 ? 'Excellent' : vars[11] >= 80 ? 'Good' : vars[11] >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${vars[11] >= 100 ? 'mdi:wifi' : vars[11] >= 80 ? 'mdi:wifi-strength-3' : vars[11] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                - entity: sensor.nodemcu_lounge_rssi
                  name: "${'Weather' + '\xa0'.repeat(12) + 'MQTT ' + vars[12] + '\xa0'.repeat(4) + 'WiFi ' + vars[13] + '\xa0'.repeat(3) + vars[28] + '\xa0' +  'dBm' + '\xa0'.repeat(3) + ( vars[14] >= 100 ? 'Excellent' : vars[14] >= 80 ? 'Good' : vars[14] >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${vars[14] >= 100 ? 'mdi:wifi' : vars[14] >= 80 ? 'mdi:wifi-strength-3' : vars[14] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                - entity: sensor.nodemcu_bedroom_rssi
                  name: "${'Bedroom' + '\xa0'.repeat(10) + 'MQTT ' + vars[15] + '\xa0'.repeat(4) + 'WiFi ' + vars[16] + '\xa0'.repeat(3) + vars[29] + '\xa0' +  'dBm' + '\xa0'.repeat(3) + ( vars[17] >= 100 ? 'Excellent' : vars[17] >= 80 ? 'Good' : vars[17] >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${vars[17] >= 100 ? 'mdi:wifi' : vars[17] >= 80 ? 'mdi:wifi-strength-3' : vars[17] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                - entity: sensor.sonoff3_0898_rssi
                  name: "${'Office' + '\xa0'.repeat(16) + 'MQTT ' + vars[18] + '\xa0'.repeat(4) + 'WiFi ' + vars[19] + '\xa0'.repeat(3) + vars[30] + '\xa0' + 'dBm' + '\xa0'.repeat(3) + ( vars[20] >= 100 ? 'Excellent' : vars[20] >= 80 ? 'Good' : vars[20] >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${vars[20] >= 100 ? 'mdi:wifi' : vars[20] >= 80 ? 'mdi:wifi-strength-3' : vars[20] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                - entity: sensor.sonoff4_0851_rssi
                  name: "${'TV' + '\xa0'.repeat(21) + 'MQTT ' + vars[21] + '\xa0'.repeat(4) + 'WiFi ' + vars[22] + '\xa0'.repeat(3) + vars[31] + '\xa0' + 'dBm' + '\xa0'.repeat(3) + ( vars[23] >= 100 ? 'Excellent' : vars[23] >= 80 ? 'Good' : vars[23] >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${vars[23] >= 100 ? 'mdi:wifi' : vars[23] >= 80 ? 'mdi:wifi-strength-3' : vars[23] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
Here is the new card…
Here is the config:
            variables:
              coffee: states['sensor.sonoff1_2914_rssi'].state
              toothbrush: states['sensor.sonoff2_3110_rssi'].state
              garage: states['sensor.sonoff5_1083_rssi'].state
              alarm: states['sensor.sonoff6_3719_rssi'].state
              weather: states['sensor.nodemcu_lounge_rssi'].state
              bedroom: states['sensor.nodemcu_bedroom_rssi'].state
              xcy: states['sensor.sonoff3_0898_rssi'].state
              tv: states['sensor.sonoff4_0851_rssi'].state
              coffeesignal: states['sensor.sonoff1_2914_signal'].state
              toothbrushsignal: states['sensor.sonoff2_3110_signal'].state
              garagesignal: states['sensor.sonoff5_1083_signal'].state
              alarmsignal: states['sensor.sonoff6_3719_signal'].state
              weathersignal: states['sensor.nodemcu_lounge_signal'].state
              bedroomsignal: states['sensor.nodemcu_bedroom_signal'].state
              xcysignal: states['sensor.sonoff3_0898_signal'].state
              tvsignal: states['sensor.sonoff4_0851_signal'].state
            entities:
              - sensor.sonoff1_2914_signal
              - sensor.sonoff1_2914_wifi_connect_count
              - sensor.coffee_maker_firmware
              - sensor.coffee_maker_status
              - sensor.sonoff2_3110_signal
              - sensor.sonoff2_3110_wifi_connect_count
              - sensor.toothbrush_firmware
              - sensor.toothbrush_status
              - sensor.sonoff5_1083_signal
              - sensor.sonoff5_1083_wifi_connect_count
              - sensor.garage_door_firmware
              - sensor.garage_door_status
              - sensor.sonoff6_3719_signal
              - sensor.sonoff6_3719_wifi_connect_count
              - sensor.alarm_firmware
              - sensor.alarm_status
              - sensor.nodemcu_lounge_signal
              - sensor.nodemcu_lounge_wifi_connect_count
              - sensor.nodemcu_lounge_firmware
              - sensor.nodemcu_lounge_status
              - sensor.nodemcu_bedroom_signal
              - sensor.nodemcu_bedroom_wifi_connect_count
              - sensor.nodemcu_bedroom_firmware
              - sensor.nodemcu_bedroom_status
              - sensor.sonoff3_0898_signal
              - sensor.sonoff3_0898_wifi_connect_count
              - sensor.tv_switch_firmware
              - sensor.tv_switch_status
              - sensor.sonoff4_0851_signal
              - sensor.sonoff4_0851_wifi_connect_count
              - sensor.xcy_mini_pc_firmware
              - sensor.xcy_mini_pc_status
            card:
              entities:
                - entity: sensor.coffee_maker_firmware
                  type: 'custom:multiple-entity-row'
                  show_state: false
                  name: "${'Coffee' + '\xa0'.repeat(16) + ( coffee >= 100 ? 'Excellent' : coffee >= 80 ? 'Good' : coffee >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${coffee >= 100 ? 'mdi:wifi' : coffee >= 80 ? 'mdi:wifi-strength-3' : coffee >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                  entities:
                  - entity: sensor.coffee_maker_status
                  - entity: sensor.sonoff1_2914_wifi_connect_count
                  - entity: sensor.sonoff1_2914_signal
                - entity: sensor.toothbrush_firmware
                  show_state: false
                  name: "${'Toothbrush' + '\xa0'.repeat(7) + ( toothbrush >= 100 ? 'Excellent' : toothbrush >= 80 ? 'Good' : toothbrush >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${toothbrush >= 100 ? 'mdi:wifi' : toothbrush >= 80 ? 'mdi:wifi-strength-3' : toothbrush >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                  entities:
                  - entity: sensor.toothbrush_status
                  - entity: sensor.sonoff2_3110_wifi_connect_count
                  - entity: sensor.sonoff2_3110_signal
                - entity: sensor.garage_door_firmware
                  show_state: false
                  name: "${'Garage' + '\xa0'.repeat(15) + ( garage >= 100 ? 'Excellent' : garage >= 80 ? 'Good' : garage >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${garage >= 100 ? 'mdi:wifi' : garage >= 80 ? 'mdi:wifi-strength-3' : garage >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                  entities:
                  - entity: sensor.garage_door_status
                  - entity: sensor.sonoff5_1083_wifi_connect_count
                  - entity: sensor.sonoff5_1083_signal
                - entity: sensor.alarm_firmware
                  show_state: false
                  name: "${'Alarm' + '\xa0'.repeat(17) + ( alarm >= 100 ? 'Excellent' : alarm >= 80 ? 'Good' : alarm >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${alarm >= 100 ? 'mdi:wifi' : alarm >= 80 ? 'mdi:wifi-strength-3' : alarm >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                  entities:
                  - entity: sensor.alarm_status
                  - entity: sensor.sonoff6_3719_wifi_connect_count
                  - entity: sensor.sonoff6_3719_signal
                - entity: sensor.nodemcu_lounge_firmware
                  show_state: false
                  name: "${'Weather' + '\xa0'.repeat(12) + ( weather >= 100 ? 'Excellent' : weather >= 80 ? 'Good' : weather >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${weather >= 100 ? 'mdi:wifi' : weather >= 80 ? 'mdi:wifi-strength-3' : weather >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                  entities:
                  - entity: sensor.nodemcu_lounge_status
                  - entity: sensor.nodemcu_lounge_wifi_connect_count
                  - entity: sensor.nodemcu_lounge_signal
                - entity: sensor.nodemcu_bedroom_firmware
                  show_state: false
                  name: "${'Bedroom' + '\xa0'.repeat(10) + ( bedroom >= 100 ? 'Excellent' : bedroom >= 80 ? 'Good' : bedroom >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${bedroom >= 100 ? 'mdi:wifi' : bedroom >= 80 ? 'mdi:wifi-strength-3' : bedroom >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                  entities:
                  - entity: sensor.nodemcu_bedroom_status
                  - entity: sensor.nodemcu_bedroom_wifi_connect_count
                  - entity: sensor.nodemcu_bedroom_signal
                - entity: sensor.xcy_mini_pc_firmware
                  show_state: false
                  name: "${'Office' + '\xa0'.repeat(16) + ( xcy >= 100 ? 'Excellent' : xcy >= 80 ? 'Good' : xcy >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${xcy >= 100 ? 'mdi:wifi' : xcy >= 80 ? 'mdi:wifi-strength-3' : xcy >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                  entities:
                  - entity: sensor.xcy_mini_pc_status
                  - entity: sensor.sonoff3_0898_wifi_connect_count
                  - entity: sensor.sonoff3_0898_signal
                - entity: sensor.tv_switch_firmware
                  show_state: false
                  name: "${'TV' + '\xa0'.repeat(21) + ( tv >= 100 ? 'Excellent' : tv >= 80 ? 'Good' : tv >= 60 ? 'Fair' : 'Weak' )}"
                  icon: "${tv >= 100 ? 'mdi:wifi' : tv >= 80 ? 'mdi:wifi-strength-3' : tv >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
                  entities:
                  - entity: sensor.tv_switch_status
                  - entity: sensor.sonoff4_0851_wifi_connect_count
                  - entity: sensor.sonoff4_0851_signal
I also started using named variables which wasn’t possible with the old card… but here is the genius of this approach…
If I click on say Coffee I get this:
even though I’m not showing the state it still shows in the state display…
But what if I click on MQTT? Well it brings up a different state card
Wifi? Uninteresting but:
Signal? yep
RSSI?? well of course…
This is WAY COOL and much better than I was hoping for!
Yes, this is a very convenient thing - but now we cannot use a "variable_x" to define a "variable_y" unfortunately - like we could use a "vars[x]" to define a "vars[y]" (Variables: use VARIABLE_1 to define VARIABLE_2 · Issue #47 · iantrich/config-template-card · GitHub). Sometimes it is needed…
For example, with using the old notation the code could be something like this:
variables:
  - '''sonoff5_1'''                           #0
  - '''sonoff5_2'''                           #1
  - '''sonoff5_3'''                           #2
  - '''_mqtt_connect_count'''                 #3
  - '''_wifi_connect_count'''                 #4
  - '''_rssi'''                               #5
  - 'states["sensor." + vars[0] + vars[3]]'   #6
  - 'states["sensor." + vars[0] + vars[4]]'   #7
  - 'states["sensor." + vars[0] + vars[5]]'   #8
  - 'states["sensor." + vars[1] + vars[3]]'   #9
  - 'states["sensor." + vars[1] + vars[4]]'   #10
  - 'states["sensor." + vars[1] + vars[5]]'   #11
  - 'states["sensor." + vars[2] + vars[3]]'   #12
  - 'states["sensor." + vars[2] + vars[4]]'   #13
  - 'states["sensor." + vars[2] + vars[5]]'   #14
entities:
  - '${vars[6].entity_id}'
  - '${vars[7].entity_id}'
  - '${vars[8].entity_id}'
  - '${vars[9].entity_id}'
  - '${vars[10].entity_id}'
  - '${vars[11].entity_id}'
  - '${vars[12].entity_id}'
  - '${vars[13].entity_id}'
  - '${vars[14].entity_id}'
But anyway that is a lot of repeating code.
So it could be better to use a decluttering card:
  decl_XXXXXXXXXXXXXX:
    card:
      variables:
        - .............. [[SENSOR_XXXXXXXXXX]]
        - .............. [[SENSOR_YYYYYYYYYY]]
        - .............. [[SENSOR_ZZZZZZZZZZ]]
      entities:
        - '[[SENSOR_XXXXXXXXXX]]'
        - '[[SENSOR_YYYYYYYYYY]]'
        - '[[SENSOR_ZZZZZZZZZZ]]'
      row:
        entity: '[[SENSOR_XXXXXXXXXX]]'
        entities:
          - entity: '[[SENSOR_YYYYYYYYYY]]'
          - entity: '[[SENSOR_ZZZZZZZZZZ]]'
        unit: .....
        icon: .....
        toggle: false
        show_state: .....
        state_header: ''
        secondary_info: last-changed
How to use:
entities:
  - type: 'custom:decluttering-card'
    template: decl_XXXXXXXXXXXXXX
    variables:
      - SENSOR_XXXXXXXXXX: ..............
      - SENSOR_YYYYYYYYYY: ..............
      - SENSOR_ZZZZZZZZZZ: ..............
    variables:
    variables:
    variables:
Regarding multiple-entity-row - you may use kind of “styles: width: 150px” to prevent these misalignment:
Regarding using spaces:
This will look nice only in case of using a font with fixed width; for proportional fonts it will cause a misalignment:
You may display these “Fair, Excellent etc” words in the "secondary-info" like it is described here (and even colourize it by card-mod like it is described here):
entities:
  - sun.sun
card:
  type: entities
  entities:
    - type: 'custom:multiple-entity-row'
      entity: sun.sun
      entities:
        - entity: sun.sun
          styles:
            width: 60px
        - entity: sun.sun
          styles:
            width: 60px
      unit: ''
      icon: ''
      toggle: false
      show_state: false
      state_header: ''
      state_color: false
      secondary_info: '${states[''sun.sun''].state === "above_horizon" ? "Rise and shine" : "Sleep well"}'
Actually, I thought that you were already using this card - your first pic looks like multiple-entity-row…
No it’s just an entities card.
Yes one of the issues I had is exactly that but I can’t make them form up in columns so open to suggestions for that.
Where would I put that? I see that issue so a solution would be welcome… can you supply an edit of one of my rows to demonstrate that?
I dont see any issue with the new variables… never used the old ones anyway and it doesnt seem to reduce the number required or make it readable anyway. I’m don’t see a point in switching to a decluttering card for this…
Sorry to jump in, just to comment one thing.
Without the decluttering card you’re replicating the same “line code” for each “device”, that’s the redundancy.
If you use the decluttering card, you’ll create a template for the “line” and then you’ll use a variable to pass the device name, which will be applied to the whole line.
So, you’ll have a big decluttering-card “template” and a small “view” for each entry.
If you check @Ildar_Gabdullin code youìll see that the " decl_XXXXXXXXXXXXXX:" your normal card (with all static config which would remain the same across devices) and then the entities card in the view will only call that newrly created template and pass the sensors name you need for that.
I would highly suggest to give it a try, I started to use it and I have to say it makes things way clearer.
:slight_smile:
I will take a look at that. I remember thinking about it.
For displaying these “Excellent” etc words you may use 3 options:
  1. Create a template sensor (not a good thing if you are going to use these words in one place only) and display it in a separate column.
  2. Display these words in the "secondary-info" part (as I described above).
  3. Use this method to create something like this:
    The idea is to display ANYTHING instead of some state.
    Look - this code is under "config-template-card" - but this does not need it since the templating is implemented by card-mod:
type: entities
entities:
    style: |
      :host .entities-row div.entity:nth-child(1) div::before {
        color: orange;
        content: {%if is_state('sun.sun','above_horizon') -%} "Rise and shine\A" {%- else -%} "Sleep well\A" {%- endif %};
        line-height: var(--mdc-typography-body1-line-height, 1.5rem);
      :host .entities-row div.entity:nth-child(1) div {
        color: transparent;
        line-height: 0px;
    entity: sun.sun
    entities:
      - entity: sun.sun
        styles:
          width: 60px
      - entity: sun.sun
        styles:
          width: 60px
    unit: ''
    icon: ''
    toggle: false
    show_state: false
    state_header: ''
    state_color: false
Switching to decluttering is not related with “how to declare & use variables” - it is just about:
  1. Reduce number of lines.
  2. In case of need to change something - change it in the decluttering template only (the basis of using “function”, “procedure” etc in Programming).
I have already used it in the examples above, please check these lines:
        - entity: sun.sun
          styles:
            width: 60px
Ok guys I’m officially annoyed of not making it work!! So, i Have a card like the one in the picture at the end. I would like to change the “Activity” with the name of the work out that comes from strava… How can this be done?
The last one i tried was the code below and i got the “no card or row or element defined”… Any help?
title: Strava
icon: mdi:heart-pulse
cards:
  - type: "custom:config-template-card"
    title: "${states('sensor.strava_0_0')}"
    entities:
      - type: attribute
        entity: sensor.strava_0_0
        attribute: friendly_name
        icon: mdi:calendar-clock
      - entity: sensor.strava_0_1
1
“${states[‘sensor.strava_0_0’].state}”`
I have tried that as well but the problem as i said is that i get the “No card or row or element defined” error…
When looking at this:
title: Strava
cards:
I do not see any "type: " definition here.
But should i define the “custom:config-template-card” there? The other yaml files i have i’ve never set the type there… Also, I tried to put define the type there but no luck
The whole code is wrong.
If it should be Entities card inside the "config-template-card" then it must be kind of this:
entities:
card:
  type: entities
  title: .....
  entities:
With the code below i get “No card type defined”
title: Garmin
entities:
card:
  - type: entities
    title: "${states['sensor.strava_0_0'].state}"
    entities:
      - type: attribute
