hi,
got this board:
did anyone ever managed to get esp config for it to work on hass ?
i have tried 16xRelay with ESP12F Onboard and two Shift Register (74HC595)
but no luck, buttons show on hass but relays do not switch,
# Example configuration entry
sn74hc595:
- id: 'sn74hc595_hub'
data_pin: GPIO14
clock_pin: GPIO13
latch_pin: GPIO12
oe_pin: GPIO05
sr_count: 2
# Individual outputs
switch:
- platform: gpio
name: "SN74HC595 Pin #0"
pin:
sn74hc595: sn74hc595_hub
# Use pin number 0
number: 0
inverted: false
- platform: gpio
name: "SN74HC595 Pin #1"
pin:
# Use pin number 1
number: 1
inverted: false
- platform: gpio
name: "SN74HC595 Pin #2"
pin:
# Use pin number 2
number: 2
inverted: false
- platform: gpio
name: "SN74HC595 Pin #3"
pin:
# Use pin number 3
number: 3
inverted: false
- platform: gpio
name: "SN74HC595 Pin #4"
pin:
# Use pin number 4
number: 4
inverted: false
- platform: gpio
name: "SN74HC595 Pin #5"
pin:
# Use pin number 5
number: 5
inverted: false
- platform: gpio
name: "SN74HC595 Pin #6"
pin:
# Use pin number 6
number: 6
inverted: false
- platform: gpio
name: "SN74HC595 Pin #7"
pin:
# Use pin number 7
number: 7
inverted: false
- platform: gpio
name: "SN74HC595 Pin #8"
pin:
# Use pin number 8
number: 8
inverted: false
- platform: gpio
name: "SN74HC595 Pin #9"
pin:
# Use pin number 9
number: 9
inverted: false
- platform: gpio
name: "SN74HC595 Pin #10"
pin:
# Use pin number 10
number: 10
inverted: false
- platform: gpio
name: "SN74HC595 Pin #11"
pin:
# Use pin number 11
number: 11
inverted: false
- platform: gpio
name: "SN74HC595 Pin #12"
pin:
# Use pin number 12
number: 12
inverted: false
- platform: gpio
name: "SN74HC595 Pin #13"
pin:
# Use pin number 13
number: 13
inverted: false
- platform: gpio
name: "SN74HC595 Pin #14"
pin:
# Use pin number 14
number: 14
inverted: false
- platform: gpio
name: "SN74HC595 Pin #15"
pin:
# Use pin number 15
number: 15
inverted: false
any suggestion i would apricate,
thank you
m
