Doh!
Whatâs in the log?
Did you reset the bulbs before trying to pair them? I have no problems with the E27 Color and White feom Philips.
I have added
logger:
logs:
pyatv: debug
apple_tv: debug
to the conf but no details regarding apple tv :-/
Right, the error means that Home Assistant failed to connect to the device. First, did you try to reboot the Apple TV? Helps sometimes. Also, do you have any kind of special set up with VLANs and MDNS repeaters?
Just tried a reboot, but no luck.
No special setup, no vlan, same subnet.
An alternative would be to setup Hyperion (either running as a Rpi image with Hyperbian or in Docker). It can control Hue lights and can add a hell of a lot of effects (effect_list: Atomic swirl, Blue mood blobs, Breath, Candle, Christmas, Cinema brighten lights, Cinema dim lights, Cold mood blobs, Collision, Color traces, Double swirl, Fire, Flags Germany/Sweden, Full color mood blobs, Green mood blobs, Knight rider, Led Test, Light clock, Lights, Notify blue, Pac-Man, Plasma, Police Lights Single, Police Lights Solid, Rainbow mood, Rainbow swirl, Rainbow swirl fast, Random, Red mood blobs, Sea waves, Snake, Sparks, Strobe red, Strobe white, System Shutdown, Trails, Trails color, Warm mood blobs, Waves with Color, X-Mas
You can also define your effects, based on the templates above and theyâre loaded into HA.
I have one instance running on Rpi2 connected to a digital led strip (for a Hue Sync Box clone) and another on Docker controlling a set of Hues that can either function independently or act as a receiver for the Rpi2 instance.
For those missing the AVRI integration go to the Afvalbeheer integration in HACS as that one has support for the new platform AVRI is using.
https://github.com/pippyn/Home-Assistant-Sensor-Afvalbeheer
Suddenly managed to do it, HUE lights flashing in color! One needs to first turn_on the light, and then this can be entered in the service_call
flash: long
entity_id: light.kayon
color_name: red
explained a bit more here, so wonât cross poster any further:
some scripts:
lights_flash_color:
alias: Flash lights in color
mode: restart
icon: mdi:alarm-light
sequence:
- service: light.turn_on
entity_id: light.flash_lights
color_name: >
{{states('input_select.select_flash_color')|lower}}
- repeat:
sequence:
service: script.lights_flash_on_color
until:
condition: state
entity_id: input_boolean.flash_color
state: 'off'
lights_flash_on_color:
mode: restart
sequence:
color_name: >
flash: long
- delay:
seconds: 15 # is the time a regular flash cycle takes, 1 flash per second
lights_flash_off_color:
alias: Stop Flash lights in color
mode: restart
icon: mdi:alarm-light-outline
sequence:
- service: script.turn_off
entity_id: script.lights_flash_color, script.lights_flash_on_color
profile: relax # reset lights to a non alarmed color, for next turn_on ;-)
- service: light.turn_off
and a few inputs:
input_boolean:
flash_color:
input_select:
select_flash_color:
icon: mdi:palette
name: Select flash color
options:
- Red
- Green
- Blue
- Yellow
- Purple
- Orange
- White
light.flash_lights is a light group of selected lights being able to be set in colors.
make into this Lovelace bare setup:
- type: entities
title: Flash color
entities:
- entity: input_boolean.flash_color
secondary_info: last-changed
- input_select.select_color
- entity: script.lights_flash_color
name: Flash lights in color
action_name: Flash
- entity: script.lights_flash_off_color
name: Stop Flash lights in color
action_name: Stop
and some fiddling in the customizations:
homeassistant:
customize:
input_select.select_flash_color:
templates:
icon_color: >
return state.toLowerCase();
input_boolean.flash_color:
templates: &flash
icon: >
if (state == 'on') return 'mdi:alarm-light';
return 'mdi:alarm-light-outline';
icon_color: >
if (state == 'on') return entities['input_select.select_flash_color'].state.toLowerCase();
return 'steelblue';
script.lights_flash_color:
templates: *flash
simply keeps flashing away yeah.
Hi all ! Happy new year !
First time I cannot update Home assistant on RPI3b+
21-01-08 08:49:04 ERROR (SyncWorker_1) [supervisor.docker.interface] Canât install homeassistant/raspberrypi3-homeassistant:2021.1.0 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.1.0&fromImage=homeassistant%2Fraspberrypi3-homeassistant: Internal Server Error (âGet âhttps://registry-1.docker.io/v2/â: dial tcp: lookup registry-1.docker.io: no such hostâ).
I tried to reload then restart supervisor. I also tried to reboot HA OS 5.9 but no luck.
Any idea to fix this?
Iâm not sure. But there were known bugs of OS 5.8 and may be 5.9.
Maybe these bugs are related to your problem.
I came here to read about all the cool new things for this release and then read the sad news. Even though I didnât know @Villhellm I whish his family, friends and everyone he knew all the best in this difficult time. I guess it doesnât even really matter what happened, 27 is not a good age to go.
Iâm having the same issue, did you resolve it?
Not yet
Neato failed with the error: Error setting up entry Configuration.yaml for neato.
I first deleted all prior vacuum entities that were created from the older username/password config to ensure I was starting fresh. Restarted HA. Created the new configuration with client_id and secret. Restarted HA. The ânew integrationâ popped up, properly connected and said successful. It creates 1 device with zero entities (so I canât do anything). Here are the logs:
Logger: homeassistant.config_entries
Source: components/neato/__init__.py:140
First occurred: 2:10:48 PM (1 occurrences)
Last logged: 2:10:48 PM
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 236, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/neato/__init__.py", line 99, in async_setup_entry
await hass.async_add_executor_job(hub.update_robots)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 239, in wrapper
result = method(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/neato/__init__.py", line 140, in update_robots
self._hass.data[NEATO_ROBOTS] = self.my_neato.robots
File "/usr/local/lib/python3.8/site-packages/pybotvac/account.py", line 41, in robots
self.refresh_robots()
File "/usr/local/lib/python3.8/site-packages/pybotvac/account.py", line 78, in refresh_robots
r = Robot(
File "/usr/local/lib/python3.8/site-packages/pybotvac/robot.py", line 58, in __init__
if self.service_version not in SUPPORTED_SERVICES:
File "/usr/local/lib/python3.8/site-packages/pybotvac/robot.py", line 284, in service_version
return self.available_services["houseCleaning"]
File "/usr/local/lib/python3.8/site-packages/pybotvac/robot.py", line 280, in available_services
return self.state["availableServices"]
File "/usr/local/lib/python3.8/site-packages/pybotvac/robot.py", line 276, in state
return self.get_robot_state().json()
File "/usr/local/lib/python3.8/site-packages/pybotvac/robot.py", line 229, in get_robot_state
return self._message({"reqId": "1", "cmd": "getRobotState"})
File "/usr/local/lib/python3.8/site-packages/pybotvac/robot.py", line 81, in _message
response = requests.post(
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 119, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 528, in request
prep = self.prepare_request(req)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 456, in prepare_request
p.prepare(
File "/usr/local/lib/python3.8/site-packages/requests/models.py", line 320, in prepare
self.prepare_auth(auth, url)
File "/usr/local/lib/python3.8/site-packages/requests/models.py", line 551, in prepare_auth
r = auth(self)
File "/usr/local/lib/python3.8/site-packages/pybotvac/robot.py", line 313, in __call__
key=self.secret.encode("utf8"),
AttributeError: 'NoneType' object has no attribute 'encode'
Tehre has been some issues with Neatos API in returning invalid data. Please check the neato app and possibly reconnect the vacuum and then restart HA and it should fix this issue. There is also an open issue on github.
Finally!
HA OS update to 5.10 fix the issue.
Hope this help
I just updated to the latest version for 2021.1 and my Supervisor screen is still reporting:
Version
2020.12.7
Newest Version
2020.12.7
This has been the case ever since, well, 2020.12.7âŠ
Should this not be reporting the 2021.1.x versions??
