I updated through the versions to 2021.10.2. The Pentair Screenlogic integration is broken on all 2021.10.X versions. Went back to core-2021.9.7 and everything is working again. What is the best way to report this issue?
THX
Github issue
As I was reproducing the Screenlogic problem to document it, I found a weird interaction between it and the Netgear integration. Deleted them both and re-added. All fine now.
Move along. Nothing to see here.
Mine too but my HA is also on that vlan (as well as the regular vlan).
Hello, after updating to 10.2, icon appears on the person badge pictures.
How can i remove them ?
Thanks for helping
edit :
I tried icon: ’ ’ but no more picture
Please post an issue on github.
I solved it with
style:
ha-state-label-badge:
ha-label-badge:
.label-badge .value > slot {
display: none;
But yeah, posting an issue on Github would most likely be the correct thing to do :).
The previous message about github wasnt for me…
Thanks, i will try
one has already ben logged
and the fix waiting to be merged
Wow even the devs are unsure what this new version of tuya should be called, its now been reclassed as Tuya again and not tuya_v2
Lets call it v1.99, close but no there yet.
I’m also using Home Assistant Core in a python3 venv on raspberryPi3 and I solved in this way (without updating pip):
sudo apt-get install build-essential libssl-dev libffi-dev \
python3-dev cargo
as suggested here in cryptography docs.
then I made home assistant upgrade and pip compiled cryptography by itself
Honeywell Liryc integration broken with core-2021.10. It says “400, message=‘Bad Request’, url=URL(‘https://api.honeywell.com/oauth2/token’)” after some time…
Also forced to rollback! Bad update!
Bring back the old Tuya!!!
Not going to happen.
no I removed v2 and setup as new it found all devices I had in v2 apart from Aromatherapy machines I had 2 in tuya v2 now it only finds the Aromatherapy light not the machine to spray any ideas
I have removed Tuya v2 and reinstalled the HACS tuya custom which is working fine for now, all my bulbs are using tuya local and thermostat tuya custom which allows you to set the scaling for proper temps.
Use the HACS version, it’s the old version and will work with 2021.10.X
Same here badge seems brocken
Same issue for me
