Ahh, you are absolutely right, not sure why this didnât appear when I first tried it? So I concluded that it must be in the customization insted.
Oh well, it shows the mdi icons, too bad that the added hue icons doesnât show up.
And after an update for the hue they show up as well, now thatâs nice!
Update your custom cards and then clear your cache. If that does not work, open the developer tools (F12). Go to the console tab and look at the error. Remove the offending custom card causing the error.
Im having the same issues. Running v.14.0. Cant see a newer version in HACS even though iâve enabled beta versions.
I cant even add new cards. Its like lovelace is locked.
I had an MQTT issue prior to the upgrade and after the daylight changes of the last weekend in Europe. After restart everything it disappeared and not happened again, so for me it is not linked with the update.
Great to see the Tuya integration has been updated to support so much more! This made me finally do the feared upgrade from 2021.9.6. I did notice the state of the covers isnât getting updated. Is that just me orâŠ?
Is anyone else having Homekit integration issues? I tried adding a new device to one of my bridges via the UI and noticed each domain under the domain selector is repeated twice. (see photo). I hit submit and select the new entity (zha switch) in âincludeâ mode. If I hit submit again, I get a âUser Import malformed errorâ and cannot proceed to the next step. Neither integration reloads nor core restarts solve the issue. Any ideas? Looks like others are having the same issue: https://community.home-assistant.io/t/homekit-error-user-input-malformed/353390
Uncaught RangeError: Invalid timeZoneName at Function.a.DateTimeFormat.__setDefaultTimeZone (:8123/frontend_latest/94a4fdf6.js:1) at Array.<anonymous> (:8123/frontend_latest/app.707ed561.js:1243) at s (:8123/frontend_latest/core.bba75532.js:1) at n (:8123/frontend_latest/core.bba75532.js:1) at Object.callback (:8123/frontend_latest/core.bba75532.js:1) at n._handleMessage (:8123/frontend_latest/core.bba75532.js:1) at WebSocket.<anonymous> (:8123/frontend_latest/core.bba75532.js:1)
and
Uncaught (in promise) RangeError: Invalid timeZoneName at Function.a.DateTimeFormat.__setDefaultTimeZone (:8123/frontend_latest/94a4fdf6.js:1) at Array.<anonymous> (:8123/frontend_latest/app.707ed561.js:1243) at Object.s [as setState] (:8123/frontend_latest/core.bba75532.js:1) at :8123/frontend_latest/core.bba75532.js:1
