2021.11: Icon picker, device links and entity categories
I wish! I am using the custom integration and the first time i give a voice command it spins and takes a while and some items of my automation work and others not. Second time is fast and everything works as it should. Half an hour later the same thing. Super annoying
I moved to HA from ST about a month ago and did not expect to have this issue
Custom integrations are not maintained by HA, so why would they fix it?
From what i have read nabu case has the same issues it is not just the custom alexa integration
I can confirm, for me at least. I use Nabu Casa.
After I have time to put together more troubleshooting, I’ll try to start a new topic.
Has anyone had success with the Media Control & Roku cards after upgrading the Atomic Calendar Revive to .6? I upgraded, restarted, cleared cache & refreshed but those cards are still missing.
Please help me :frowning:
Make a separate post and be patient
A or B or both?
Read this post: 2021.11: Icon picker, device links and entity categories - #131 by makai
and go open an issue here: Issues · home-assistant/core · GitHub
I have the same issue. Need to call open_cover service to CLOSE my covers and close_cover to OPEN it, for now, I’m just using it like that, just glad it’s back. But it will be great if we can get it fixed.
  • @goyney updated the Material Design Icon to version v6.4.95 ensuring we have all the latest icons available in our new beautiful icon picker.
Our first Baby Human arrived at Home a few Days ago and i love that his room icon now is the fantastic mdi:teddy-bear Thanks for the Update :heart_eyes:
Yes, I have restarted several times but now it’s all ok with Atomic Calendar Revive 6! All cards are visible now!
Would also be cool to launch it with a Hotkey
Something strange is going on. After the update the illumination channels of my 4x HmIP Motion Sensors went to unavailable. I restarted Homematic and Homeassistant couple of times, but then gave up and went to bed.
This morning I found them back working again, but after a while they disappeared again.
Status now, unavailable.
Will need to go back to 2021.10.7
see here Nach Update auf core-2021.11.0 ist der Wert illumination vom HmIP-SMI nicht verfĂŒgbar · Issue #442 · danielperna84/pyhomematic · GitHub
One PR merge is currently missing in the HA release.
Tuya wifi siren, zigbee temperature and humidity sensor devices are not supported.
siren:
temperature and humidity sensor:
many thanks!
Been running for 20 minutes now and still don’t have access to my History or recorder. Think the DB migration failed, or at least the logs think it did:
Database error during schema migration
10:44:35 AM – (ERROR) Recorder
Error executing query: (MySQLdb._exceptions.OperationalError) (1054, "Unknown column 'statistics_meta.name' in 'field list'") [SQL: SELECT statistics_meta.id AS statistics_meta_id, statistics_meta.statistic_id AS statistics_meta_statistic_id, statistics_meta.source AS statistics_meta_source, statistics_meta.unit_of_measurement AS statistics_meta_unit_of_measurement, statistics_meta.has_mean AS statistics_meta_has_mean, statistics_meta.has_sum AS statistics_meta_has_sum, statistics_meta.name AS statistics_meta_name FROM statistics_meta WHERE statistics_meta.has_sum = true] (Background on this error at: https://sqlalche.me/e/14/e3q8)
10:44:35 AM – (ERROR) Recorder - message first occurred at 10:44:35 AM and shows up 3 times
media_player.plex_plex_web_chrome_osx_3 does not support any media_player features
10:44:35 AM – (ERROR) HomeKit - message first occurred at 10:44:35 AM and shows up 17 times
Updating character set and collation of table events to utf8mb4. Note: this can take several minutes on large databases and slow computers. Please be patient!
10:44:35 AM – (WARNING) Recorder - message first occurred at 10:44:35 AM and shows up 3 times
Database is about to upgrade. Schema version: 20
UPDATE: Looks like all of my custom sensors are failing to update:
2021-11-04 13:49:40 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.ac_run_time_today fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 468, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 658, in async_device_update
raise exc
File "/usr/src/homeassistant/homeassistant/components/history_stats/sensor.py", line 221, in async_update
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/history_stats/sensor.py", line 227, in _update
history_list = history.state_changes_during_period(
File "/usr/src/homeassistant/homeassistant/components/recorder/history.py", line 147, in state_changes_during_period
with session_scope(hass=hass) as session:
File "/usr/local/lib/python3.9/contextlib.py", line 119, in __enter__
return next(self.gen)
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 73, in session_scope
session = hass.data[DATA_INSTANCE].get_session()
TypeError: 'NoneType' object is not callable
Update 2:
Reverted to 2021.10.7 without issue. Will stay here until I hear any updates
Hi All,
SInce 2021.11.0 I have problems with Safari and Firefox.
I can login on my HAOS system via web, but logo is spray there for ages
Even with Firefox same issue, but if I change “Privacy and Security” then from standard to custom and disable: Cookies, following, crypto miners, fingerprints I can access HA webui.
For Safari i don’t know how to able to login normal again
cleaning cache didn’ t work
Core: 2021.11.0
Superviser: 2021.10.8
HA OS: 6.6
Possibly this - Home Assistant Alexa Cloud - Device is unresponsive
